Re: Team Avenger build diary
Avenger of blood
Deuteronomy 19:6
Otherwise, the avenger of blood might pursue him in a rage, overtake him if the distance is too great, and kill him even though he is not deserving of death, since he did it to his neighbor without malice aforethought.
Originally Posted by psychostorm
Avenger of blood
Deuteronomy 19:6
this is why your a robot avenger ceri! :proud:
How about Parca? It means Grim Reaper in Spanish.
ive got various options but now im trying ti figure out what sort of internals to put into it.
ive so far got:
either bosch 750's at 36v or 400's at 24v
no idea on esc
a123 packs
either envy style (but rear hinged) LP system of a HP system
SO... MUCH...CHOICE!
not heard back about it yet, still waiting on that
Jamie and I were trying to fit some 4QD's into Eric at the weekend and they might be a touch too big, so if you're stuck for an ESC we might be tempted to part with them.
i couldnt send a message quick enough :lol: :lol: :lol:
Haha they're not going anywhere else, no hurry.
Just to cross one option off of your list, Bosch 400s will most likely not work on 24V. Probability of frying them is high.
I would go 18v then since I stand less chance of frying them
i have a name for my Hydra clone
MAAAAAAAAAAAAAAAAAAAARRRRRRRRRMALADE!!!! (those who have played Dragon Age: Origions will get the joke :proud: )
Gotta get some parts then :lol:
Anyone suggested The Grim Rimmer ?
Can a self loathing holographic robot get much grimmer?
its cold outside, theres no kind of atmosphere....
im trying to comprise a parts list for grimreaper so any opinion are valid.
im thinking now:
750w motors
4qd's
3700mah nimh packs
HP pneumatic system
the :x face was for......
It annoys me that most of the questions you're asking you have asked atleast once before! And most of this info can be obtained by looking through the heavyweights section!
i got bored so i started making a new parts list and if anyone has opinions on it then say. i hardly call that repeating, the old one was a bit vague so i needed to make a more refined one
I'm not talking about that specific instance
ye, i know i have done because i always forgot to save thing into files etc so i need to ask again and retain the info
im thinking now:
750w motors
4qd's
3700mah nimh packs
HP pneumatic system
good
alright, a bit big and hefty but they'll get you moving
how many packs? discharge rates?
good
i'm planning;
bosch 750's
wotty
a123 packs, maybe nimhs
fp pneumatic system, 2-3 burkerts, aiming for about 1l volume ram
well i was unsure of battery size so i just went for the same that my drive packs on my FW are.
im using 2 burkets but with a 100mm bore, 120mm stroke ram
100mm bore 120mm - 0.95l, i was more thinking 75mm bore 200mm stroke modified hydraulic cylinder. nimhs i'd say 10ah+ though you might get away with less depends on the discharge rates that the cells have.
my thinking was toon raider uses 3000mah nicad.
and i have looked into a mod hydraulic ram but i need to find one at a good price
You'll rip the chassis to pit with a ram that size, and no point if your only having one burkert feeding it. See if you can find out what size it had in before and aim around that, i would guess something like a 63mm bore 200mm stroke (same as Merlins). Why see what weight you have available and just use some cheap SLA's.
what size ram did knightmare have in it? i was think something along those lines
ah crap, ye, good point alan, i could probably push to 75mm but i dont think much more than that
Knightmare had the same 63x200 was never very good though due to the angles on the arm, was very in-efficient.
picked up my finished claw today for ReAvenger and connected them with any bolt i could find and they seem to work fine although the corners need rouding off but it should be mechaniclly finished (if all goes to plan) by saturday evening so then i just need to do the graphics then practise since my last bot, i had about 30 seconds drive before it went into the arena :lol:
matt, have you got grim reaper yet?
Ah ye, been so busy working on my feather I ain't put it up here. Ye, it's here, need to replace some of the chassis and grind off all the surface rust but it's structurally very sound :)
I'll pop some up tomorow.
I'm replacing the blots before Kidderminster but the real hard work on it will start after the event. Should be driving by whitwick and flipping by the end of next year :)
feather is almost done, now i just need to practise
and ive decided to change the name of 'Avenger' to 'Reaper' in orger to fit more with the original name
although it might be slightly confusing having 2 green robot in the arena beginning with R, but that's a long way off yet
Hooray, we have the biggest build diary thread to date :mrgreen:
Whoops, 2nd biggest i guess
well then thats my cue to go spam ours :crazy:
