My first REAL tournament... ROBOBASH!!!!
Sorry, Kody, but youve been saying how good MeCannibal is, and know youre going to say itll blow up on firat impact when in its last load of battles, it has stood up to other spinners and to its own hits. Here this Samuel - MeCannibal WILL live up to its own hits!
Fault of the writers. :P
Huh? :S
(Message edited by kodster on May 23, 2008)
Is this the old MeCannibal or the new one?
for what its worth, I dont think it will detonate instantly, but it had better not need lots of hits to KO its opponents, or come into contact with arena walls, because then it most likely will.
It certainly wont kill Manic Monsoon. Its friggin fast as hell, and MeCannibal being a shuffler wont help either. Itll get rammed too much.:P
And honestly, I dont ever remember saying anything good about it. I still think its overweight. :P
More overweight than most of our (and even some of your other) vapourbots, that is, Paul. :proud:
Edit: But who am I kidding? Panic Attack will die anyway!!! :proud: :P
You did once say:
Missing batteries...
And youre definitely not going to be able to reach a speed of 20mph with S28-400s on shufflng pads! Lower it to around 10-15mph.
Other than that, a giant improvement. :-)
Id call that something good, wouldnt you? :)
Sorry guys, it might take a while posting up these fights. My internet got disconected suddenly.
From Team Chevron, Gabriel!
Gabriel is the angel from HELL! It€™s got a nasty high pressure flipper on the front, and some spikes on the side to cause max damage. Its armour is not the best, however.
From Team Unknown, Exertion!
Exertion has 15 mph top speed, an S24-800 powered lifting scoop and a good pushing power. It€™s also invertible, but being invertible always means that the wheels are exposed from the top.
Entered by Team Iron Diamond, Gemini!
Gemini was the first clusterbot ever in Robot Wars, and it inspired a lot of other roboteers to do the same thing. It has a good flipper on it, and of course, the nasty attitude that all combatants have. However, if one part of the robot goes out, then this means that the whole robot goes out.
Roboteers, Stand By!
Booth 1: Gabriel, Exertion
Booth 2: Gemini
3€¦ 2€¦ 1€¦ ACTIVATE!
So, Gemini immediately separates, and Gabriel and Exertion takes care of Gemini 1 and 2. Exertion lifts Gemini 1 and slams it into the wall!
WHAM!
Now Gabriel comes in and flips over Gemini 2, and it self-rights directly! Now, Gabriel just slams into Gemini 1 and pushes it towards the hammers! The 50kg hammers come down!
WHAM!
OH!!!!!! Gemini€™s getting crumpled! That armour is not going to last very long if the hammers come down again, but luckily, it escapes just in time. Now, Gabriel gets under Gemini 1 again and flips it over! Exertion now lifts Gemini 2 and pushes it towards the saws! BZZZT! Now, Gemini is in all sorts of trouble! Gabriel comes in again and yes, after 29 seconds into the fight, Gabriel gets under Gemini, carries it to the wall, and€¦
FLIP!
€¦out it goes!
CEASE!
That wasn€™t even a battle.
Gabriel and Exertion go through!
From Team Britespark, Manic Monsoon!
Manic Monsoon is here to whip up a storm! It€™s got 5mm Hardox Armour and a lifting arm like Bio-Hazard that can lift 200kgs. It€™s nippy at 28 mph, but it€™s difficult to drive when it is at full speed.
Entered by Team Iron Diamond, Panic Attack!
Panic Attack won the 2nd Series of Robot Wars. Anyway, It has lifting forks and a rear srimech, but it€™s coloured yellow so it can be easily seen€¦
From Team Insanity, MeCannibal!
MeCannibal has a scary name, and a nasty weapon. It has a 30kg spinning ring which spins at 3000RPM, powered by two LEM-130 motors. This will be able to give out 195 kJ! However, it€™s just a bit hard to control.
Booth 1: Panic Attack, Manic Monsoon
Booth 2: MeCannibal
So, Panic Attack immediately drives away, and goes for Manic Monsoon, and so does MeCannibal. Spinning away, and it hits Manic Monsoon right in the side!
CRASH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
OH!!!!!!!!! Those skirts rip away like paper! Now, Paul smiles devilishly and smacks into the other side of Manic Monsoon!
OH!!!!!!!!!!! The other skirt comes off! Now, Panic Attack comes in, catches Manic Monsoon by the rear end, lifts it, and drags it front first right into MeCannibal! Manic Monsoon raises the lifting arm by mistake!
OH!!!!!!!!!!!!!!!!!! The lifting arm is BENT!!! No more weapon! MeCannibal now spins down, and crashes into the pit button. The pit yawns open and now MeCannibal starts spinning again! Manic Monsoon slams into Panic Attack, and pushes it towards the wall!
WHAM!
OH!! Nice attack there by Manic Monsoon! Now, MeCannibal spins up again and CRASHES into Manic Monsoon!
CRASH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
OH!!!!! A small chunk of armour flies off from the side! Now, Manic Monsoon€¦ OI! Manic Monsoon, WHAT ARE YOU DOING?! Manic Monsoon just drives into the pit!
CEASE!
Manic Monsoon gets downgraded to a light wind.
Panic Attack and MeCannibal go through!
Round 2 Line-Ups
Gabriel VS Panic Attack
Exertion VS MeCannibal
Send in tactics, predictions, comments and a new sofa please.
*wheels in brand new sofa*
Ill start by spinning, and I reckon that if I hit the sides when spinning I can break the skirts and get in underneath , and from there its wall - flip - clap clap - cheer cheer - whistle whistle - lots of beer. :P
If that fails, PA has lots of clearance either side of the forks, so just get in there.
Ive reread the fight (I need to actually read fights more often :P) and I have to say it could use some more detail...actually, quite a bit more, rather than just sentences interspersed with exclamation marks.
(Message edited by joeychevron on May 30, 2008)
I dont think everyone will be happy about Manic Monsoon pitting itself... Ah well, Im not in this tourney so Im not complaining
*Hands new sofa*
Gabriel v Panic Attack
Sorry PA, my welsh buddy! PA doesnt go well with front hinged flippers, so Joey has an easy route to the heat final here.
Exertion v MeCannibal
AJ through (sorry Paul!)
(Message edited by Robot_Warrior on May 30, 2008)
Im...sorry, but I didnt like the way that fight was written.
I can tell Ill be yelled at, so Ill just shut up and keep the reasons to myself. :P
I think personally that Samuel in this is biased towards the spinners. Look at the semi-final line-up so far:
Leprosy Infection (A drum spinner)
Aftershock (A drum spinner)
Archangel Of The Abyss (A full-body spinner)
Pure Evil: ROTD (A full body spinner)
Tira III (A vertical disc)
Whirligig 4.0 (A full-body spinner)
Dennis The Menace (A drum spinner)
And I think that you believe that 52kj is enough to damage anything at all (You stated it in one of your designs) its not true - thats possibly why Nitro-Gene with a 5mm Hardox shell was ripped to micro pieces by Whirligig.
Im not going to post effective tactics for once - my plans just to rip the lifter off and shock-kill Exertion, as its probable that I WONT get through the armour.
Not to destroy my own victory, I think that last fight was biased to go AGAINST Manic Monsoon, and even though MeCannibal is lethal, it wouldnt tear 5mm Hardox that quickly - the skirts maybe. But for the while, Im not going to say much except look further than spinner effectiveness. Go on things like armour strengths, weapon designs, traction, power, shapes and other things.
If this sounds like a vicous attack, Im sorry - Im just trying to give advice.
lol, if hes biased towards spinners, then next series, Ill put in Tira IV, Aftershock, Kracko, The Curse for vapours, and Shrederator, Megabyte, Surgeon General, and Tornado Mer for realies. :proud:
If hes biased towards spinners, Im screwed! Only 4 of my 14 robots have rotary weapons on them.
Paul...attach small hole saws to the side of your wheels. Hole saws are rotary weapons...
«MeCannibal vs. Exertion»
Perfect! Its the classic ring-spinner meets spinner-killer here. Simple tactics are to be relentless - keep driving in and ramming MeCannibal over and over again. If I can pin it against the wall, my job will be made even easier. The more I ram, the less it can spin up and attack me and score any points. Shove it around into the hazards and preferably the pit. If MeCannibal does get up to full speed, I am willing to sacrifice my scoop. After a couple of hits, MeCannibal will suffer from the effects of its own overkill energy output.
About the previous battle, I wrote it at 3:30 AM. :lame:
What an excuse. :P
Well, maybe I shouldve said earlier, Tactics, comments, predictions and a reminder to NEVER WRITE A BATTLE LIKE THIS AT 3:30AM PLEASE. :lame:
Right, I apologize for the last battle. I wrote it at 3:30 AM, and my mind was just full of crap.
Anyway, lets get on with the remaining battles.
Booth 1: Gabriel
Booth 2: Panic Attack
Gabriel is spinning away to its top speed. Danny drives Panic Attack€™s forks straight into the spinning Gabriel!
WHACK!
OH!! Nice hit there by Gabriel there. It sent Panic Attack flying! Now, Gabriel tries getting under the ex-champions of Robot Wars, and flips it! Panic Attack self-rights, lifts Gabriel up, and SLAMS it towards the wall!
WHAM!
OH! Nice hit there by Panic Attack! Now, Gabriel gets under Panic Attack and flips it! Panic Attack immediately rights itself, and attacks Gabriel! Gabriel gets lifted from the side and€¦
WHAM!!!
OH! Right into the wall it goes! Joey can€™t take it anymore, so he drives Gabriel€™s flipper straight into Panic Attack, and pushes it towards the wall! Now, it€™s time to say good-bye, Danny!
FA-LIP!
OH! Panic Attack gets out of the arena and onto the camera tracks in less than 50 seconds!
CEASE!
Panic Attack should really see a psychologist.
Gabriel goes through to the Heat H Final!
Come on Exertion! :proud:
MeCannibal VS Exertion
Booth 1: MeCannibal
Booth 2: Exertion
MeCannibal immediately starts spinning up, and now, it crashes into Exertion!
CRASH!!!!!
Sparks fly but there€™s only a big scratch in Exertion€™s scoop! Exertion now slams into the FBS before it gets up to full speed! Now, Exertion lifts up MeCannibal. MeCannibal has a collision head to head with the pit button!
WHAM!
OH!! Nice hit there by Exertion! Now the pit descends, and Exertion lifts up MeCannibal again and€¦
WHAM!
OH!! Nice hit there by Exertion again! MeCannibal escapes and begins to spin up again! Now, with all its might it CRASHES into Exertion!
CRASH!!!!!!
There€™s another big scratch in the scoop, but no REAL damage is caused. AJ now drives Exertion scoop-first into the spinning ring of MeCannibal, which has already spun up!
CRASH!!!!!!
OH!!!!! There is a huge gash in the scoop, and now, AJ can€™t take it anymore, and drives Exertion€™s scoop right into the spinning ring of MeCannibal, lifts it, and drags it towards the wall!
WHAM!
OH!!! There€™s another good attack by Exertion! This is a very even battle here so far, and now, Exertion crashes into MeCannibal again, and pushes it near the pit! MeCannibal tries to escape, and they do, luckily. But Exertion pushes MeCannibal ever so close to the pit again and€¦ BOOM! Down goes MeCannibal!
MeCannibal is not so scary now, is it? :wink:
Exertion goes through to the Heat H Final!
Tactics, Comments, Predictions, and a cold, refreshing cup of orange juice please. :proud:
*pours a cold, refreshing cup of orange juice...on Samuels head*
Tactics? It cant do much to me, so flip.
LOL. :rofl:
Teh fites will bee in shortly after teh brake! :proud:
Exertion VS Gabriel
Booth 1: Exertion
Booth 2: Gabriel
So, the heat final commences now. Gabriel presses the pit button. Now, Exertion comes in from behind, and crashes into Gabriel. Now it€™s pushing Gabriel towards the wall!
WHAM!
OH! That€™s a nice attack there by Exertion! Gabriel flips over Exertion by getting underneath from the rear end. Exertion is overturned but it is invertible. Gabriel pushes Exertion into the hammers!
WHAM!
Even though the hammers are 50kg each, that caused minimal damage to Exertion. Now, Gabriel just SLAMS into Exertion again, and€¦
FLIP!
OH!! That flip sent Exertion almost out of the arena! Now, Exertion comes back into play by pushing Gabriel towards the wall!
WHAM!
Now, Gabriel pushes Exertion and€¦ OH! Exertion almost got into the pit! Now, Gabriel pushes Exertion towards the saws!!! BZZZZT! Sparks are flying, and the crowd wants some more carnage! Gabriel flips Exertion over again, and this is a very even battle so far. But now Gabriel pushes and shoves Exertion€¦ and now, Exertion is very near the pit of doom, and€¦ BOOM! Down goes Exertion!
CEASE!
Exertion uses up all its power.
Gabriel goes through to the Series Semi-Finals!
Heat I
Matador VS Scarmanga VS WORCK
Megabyte VS Wheely Pure Evil 2 VS Intrigue
Send in tactics, comments, predictions and a Bacon Egg McMuffin from McDonalds please.
Scaramangas tactics - let the robots self guidance do its thing...
Heat I
Matador VS Scarmanga VS WORCK: Scarmanga has near-to-no control factor, as it has the self-guidance which will hinder it. Matador is flippable and I will target it. Neither 9of these two worry me greatly, but Matador does, so go after him.
Good luck Alex and whoever entered The Matador :proud:
Megabyte VS Wheely Pure Evil 2 VS Intrigue: The E.O.T.R 4 Champ to advance easily, with Megabyte following, due to WPEs ABC armourment.
Of course the benefit of a guidance system is of course that while on the one hand it may be less creative with its movements, on the other it means it has far faster reaction speeds and can make more precise movements. Especially when you cant see through the smoke...
This is the old Intrigue, isnt it. :proud:
Megabyte wont have such a nice time hitting me anyway due to my sloped/curved sides and wedged front/rear, so treat it like the most dangerous hazard in the arena. :proud: Wheely Pure Evil doesnt seem to have a wide area to use its weapon so it doesnt worry me much. Grapple Mr. Evil and shove him into Megabyte. If I smack a wheel, then w00t. :proud:
As for the other fight, I think Scaramanga will crash out.
Hey! After all the times I said I liked Intrigue! :sad:
Kill....Intrigue....
*CHANGE OF PLAN!*
After talking to Kody on MSN, we have decided to gang up against Megabyte. Its self righting is not the most reliable, so Intrigue will go in and box rush it, stallign the weapon enough for me to come in and flip it around, hopefully OOTA. If it falls in the arena, Intrigue will carry on pushing it around, axeing the underbelly of the FBS whilst I open the pit release. Megabyte. Pit. Smoke. Done. :proud:
(Message edited by Team_Britespark on June 17, 2008)
Oh yeah, forgot about this :P sorry...but WOOT! I won! Yay :proud:
I think Pure Evil and Matador will bite the dust here.
lmao
Last minute team-up on MSN.
Me and Dan are going to kill Megabyte. :proud:
Ill ram it, you flip it.
From Team Inertia-Labs, Matador!
Matador has a bloody powerful flipper, and it is built by the builders of T-Minus and Toro, Alexander Rose and Reason Bradley. However, it€™s got limited gas on board like all the other flippers and they€™ve never been in an arena like this before.
From Team Doomforall, Scarmanga!
Scarmanga has a brilliant flipper, and a nasty attitude. It€™s got a smokescreen thingy to distract other robots, as well. However, it€™s got limited CO2.
From Team Insanity, WORCK!
What€™s this? ANOTHER flipper?! YES! Paul Cuomo has built a wonderful machine, and it€™s got a forward-hinged flipper running on a single 750PSI ram running on CO2. It€™s a bit slow, however.
Booth 1: WORCK, Scarmanga
Booth 2: Matador
Scarmanga immediately goes off to smoke, and slams into the Matador, and flipping it!
FLIP!
OH!!! Nice flip there by Scarmanga there. It sent Matador flying 5 feet into the air, and now WORCK comes in, and€¦
FLIP!
WORCK now flips over Matador, and Matador self-rights with a 540 degree spin! Now, Matador attacks WORCK and tries to get under it, but fails to do so. WORCK has a grip on Matador, and Paul smirks devilishly as he flips Matador over!
FLIP!
OH!!!! Another nice flip there, and now Scarmaga is coming into the action and flips over Matador! Now, Matador immediately self-rights, and€¦
FLIP!
€¦ flips Scarmanga over but it self-rights directly, and now, WORCK crashes their party and crashes into Matador, and carries it to the wall! Now, after 38 seconds into the fight, WORCK tosses Matador over the fence!
CEASE
Matador wasn€™t able to stand up to the two €œbulls€Â, get it?
WORCK and Scarmanga go through!
Im sorry for not posting any fights. I was in a vacation in Alberta.
Sorry guys, I wont be able to post any fights for quite a long time. My parents are forcing me to go to summer school.
Just leave it be, then, and come back to it when you are ready. :)
-The guy who makes sure people dont post hypotheticals for no reason :proud:
(Message edited by kodster on July 08, 2008)
I am not going to do any hypotheticals or any cancellations.
