Ben, WHY have you made a 2nd version of a bot that hasnt competed yet??? AND, its exactly the same as the previous version!
Go to the How Can I Improve thread, please. Im sure Dave doesnt want this BS in his thread...
Kody, please dont start
And RH 2.0 is now RH 0.2
(Message edited by neontetra23 on August 12, 2008)
YOU posted something that caught my eye, so you in fact started it. And Ill get a mod to finish it.
And RH0.2 is overweight by a large amount.
what?! 5KG at most
Ben, see my post in the How Can I Improve thread, and DONT POST ANYMORE ABOUT IT HERE.
Ill enter.
Fatality
Weight: 100 kg
Body Shape: Cone.
Colour: Flourescent Blue Body with Turquoise and Green Teeth.
Dimensions: 96 X 96 X 42 cm.
Drive: 2 X S28-400s @ 24v powered by 4 X NiCad Batteries.
Top Speed: 15 mph.
Tyres: 2 X Vulkanized Tyres.
Ground Clearence: 7mm all around. It has to be.
Armour: 6mm Hardox FBS shell, 6mm Polypropylene Base.
Turning Circle: Zero! Need I say more?
Weapon: A very nasty 36kg, 1500RPM FBS shell with 2 X 2kg Hardox Teeth and small Tungsten Carbide-tipped teeth all around, powered by an LEM-130 @ 36v. This can reach top speed in 2 seconds, and brings out about 80kJ. The teeth are curved, jagged, and barbed. Has a buttload of shock proofing inside to stop it from self-destruction. Holes drilled into it to reduce weight.
Srimech: An extremely blunt spike that comes out at the top, powered by 1 X 2kg CO2 Tank.
Strengths: Deadly Weapon, Fast Srimech.
Paralyzation 2
Weight: 100kg.
Body Shape: Low Box ala Tetanus Booster.
Colour: Interchangable Panels: One is desert yellow and the other one is pure gold. :proud:
Dimensions: 100 X 78 X 20.
Drive: 2 X LEM-130s @ 36v powered by 4 X NiCad Batteries.
Top Speed: 15 mph.
Wheels: 4 inner, Tightly Foam-Packed Wheels with Asmaprene Urethane on them.
Armour: 3.4mm Hardox 500.
Ground Clearence: 3.5mm all around.
Weapon: 19 kg Drum powered by a LEM-130 Lynch, spinning at 5000 RPM. There are 8 teeth, which are all curved upwards and jagged to rip and flip opponents.
Srimech: Invertible. Side spikes prevent it from getting beached.
Strengths: Deadly Weapon, and a Great Pusher.
Weaknesses: Exposed Tyres although very strong.
Weaknesses: Weak Base Armour, able to shoot only 15 times with the srimech
Right, I have all 30 robots, excellent.
Samual: Could you please provide I picture or Tetanus Booster ? the robot escapes me.
Ill be posting the random draw shortly
It was beaten in the Heat E Final of Series 7 of Robot Wars by Tornado.
Paul: I dont have any stats for your robots, please provide them, and realistic, cheers.
Infero (http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=39 4http://strickenone.proboards99.com/i...n=display&thre ad=394
Heyght (http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=30 2http://strickenone.proboards99.com/i...n=display&thre ad=302
Tetanus Booster
http://uk.youtube.com/watch?v=i7pP39W6ITEhttp://uk.youtube.com/watch?v=i7pP39W6ITE
sorry, not paul, Ben, I need stats from Ben
And thanks for the info Paul on Tetanus Booster
I need sleep.......zzzzzzzzzzzzzzzz
With all except Ben, there are 22 robots signed up so far:
1: No Exceptions
2: Phoenix Down
3: Sideswipe
4: Symmetry
5: Baldur Gamma
6: Slammer VI
7: Bad Temper Jnr
8: Spring-bok!
9: Noo Monsoon
10: Supreme
11: Flick of the Wrist
12: Sheer Heart Attack 2
13: Wedge Devolution
14: Whirligig 4.5
15: Macduff 3rd
16: Tira IV
17: Heyght
18: Inferno
19: Brutalis
20: Systematic Shocker
21: Paralyzation 2
22: Fatality
8 more robots (4 more people) and Ill run those numbers through a RNG to determin who enters when in the rumble
So, i had to edit my post because i realized that the weaknesses are in the wrong place.
Fatality
Weight: 100 kg
Body Shape: Cone.
Top Speed: 15 mph.
Paralyzation 2
Weight: 100kg.
Top Speed: 15 mph.
With the Addition of AJ, I need 6 more robots (3 more people). I am waiting on Ben, so really we only need 2 more. Come on, I wanna write this fight already!!
STATS: Robo-Goat
Shape: A wedge with angled sides
Colour: Grey-White
Speed: 20MPH
Weight: 100KG
Armour: 7MM Titanium
Drive: 2 C40-300 Magmotors @ 48V
Power: 5 NiCad Battlepacks @ 48V
Locomotion: 2 Vulkalon coated wheels
Ground Clearance: 0MM at front, 1-2MM on sides, 3MM at back
Turning Circle: 0
Dimensions: 110X40X25
Weapons: 1) A angled front-hinged flipper powered by 3 100X80 rams
2) 2 Linear actuated hardox goat horns to hold opponents in place
Srimech: The flipper
Strengths: Powerful flipper, Quick
Weaknesses: Not good at pushing
Robo-Hedgehog:
Shape: Box
Colour: Yellow and Black danger stripes
Speed: 25MPH
Weight: 110KG
Armour: 5MM Titanium
Drive: 4 LEM130s @ 36V
Power: 8 NiCad Battlepacks @ 36V
Locomotion: titanium tracks with a vulkalon coating
Ground Clearance: 0MM at front, 4MM everywhere else
Turning Circle: 0
Dimensions: 120X70X20
Weaponry: 1) A 15KG pointed sledgehammer, powered by pneumatics that comes down in 0.8 seconds
The next three weapons are interchangeable
2) A static Hardox wedge at the front
3) 5 static Hardox forklift arms at the front
4) A hinged Hardox scoop
5) 8 rows of 5 curved teeth, the first 6 rows face the rear and collapse when you drive forward and become rigid and damage the tyres of other robots when you drive backwards, the last row faces the opposite way and are fixed in place
Srimech: Axe, can run inverted if axe is taken off
Strengths: powerful weapons, weapons synergy and is capable of 1 or 2 hit KOs
Weaknesses: Thin armour, easily flipped and sides and rear are vunerable
Ben: Robo goat seems...plausable, so Ill enter him, just curious about the goat horns. Do they go over the top of the robot or beside the flipper (IE: to hold the robot in place so you can flip him whenever, like close to the wall or the pit) ?
Robo-Hedgehog is a little confusing. First, which set up will you be using for the rumble ? Second (and only answer if you plan to use it): can you elaborate on the curved teeth a bit ? Not sure I understand, and third: your batteries; 8 packs @ 36v = 2 sets of 4, 9v batteries. I am guessing the extra set for capacity benefits, but I dont think you can make a 9v pack from Nicads. You can get 9.6v Nicad packs. Up the operating voltage to 38.4v, then its based on real packs.
Cheers
deleted.
(Message edited by leorcc on August 17, 2008)
Oh yeah, aiall add 20kg extra of NiCads to both my bots
Ben, would you mind me doing some CADs for you? (the robots you entered here for starters...)
Thats great Martijn, I was hoping someone would offer
For the CAD Ben, I have the same questions Dave had. Can you describe the goat horns a bit better? Are they part of the flipper or part of the main body? And can you describe setup 5 of the Hedgehog please?
On Robo-Goat the horns are part of the body
on Robo-Hedghog I think that I have described setup 5 to the best of my knowledge
Is that 8 teeth high 5 teeth wide or 8 teeth wide and 5 teeth high? Teeth in vapourbots are mostly meant to describe those things you use on your disc, blocks of metal mostly. Are they curved blocks of metal? How do they face the rear (they are on the front of the robot right?) and if they face the rear than what does the rest face?
The way I have interpreted the weapon is...
the teeth are similar to Mutes barbs, in that they can trap opponents when they are trying to drive off the front wedge. However, according to Robo-Hedgehogs stats the shape is a box so I dont see how they would work...
and research told me goat horns face backwards, lol
no, they face forwards, they do not get in the way of the flipper, they are more for use when i face invertible or robots able to self-right, thay are used to grab and hold while I drive towards the pit and then pit them
http://i74.photobucket.com/albums/i268/_MadBull_/goat.jpghttp://i74.photobucket.com/albums/i2...Bull_/goat.jpg
Ben?
Nice CAD, reminds me of Seung Mina III :)
myeah, theyre both long wedges, I wanted to go into abit more detail but decided to strictly follow the stats to make sure I got what Ben had in mind, thanks Liam :)
nice, but I think its a bit thin
I used the dimensions you gave it, you indeed made your robot quite thin :lame:
whoops, that was a typo, it was supposed to be 110X80x25
Ill see if I can fix it, expect Robo-Hedghog to be done somewhere next week btw, running short on time here
http://i74.photobucket.com/albums/i268/_MadBull_/goattt.jpghttp://i74.photobucket.com/albums/i2...ll_/goattt.jpg
w00t
ok, width is now fine, but the horns should be a little longer
... couldnt you have said that after seeing the previous CAD? it had the same horns after all...
Demanding much...
sorry, I suffer from short-term memory loss
