All top armour now painted now for the rest of the robot. pic on profile :proud:
Ill have to send you one of my robots to get the paint done :D
Not sure what the FRA will make of that skeleton on the back :S In antweights, you arent allowed any artwork that is offensive or distaseful, dunno if its the same for HWs
I kind of miss playing with the heavies, so Ive been thinking about knocking together a heavyweight version of Pillow Torque.
Still working on specs for the drive, but lets just say its starting to look interesting :wink:
Watch this space!
New pic of Carnage on profile
really good tony
ee e e e ee e e e e e e e e ee eeeee e e e e e ee e e e eeeee e e e e ee e e e e WHACK missed
What we need here is a better mouse trap!! :)
Making an axe, got most the bits now just need the time :)
Name: dunno, blitzkrieg or 180 or turbine or somthing..
Motors: bosch 750 Motors
speed: 18mph?
Batterys: 36v A123s
Weapon; variable pressure via remote LP axe (16bar)
Size: 650wide. 700long, 350high
chassis: 6mm water cut and key wayed 6082
Armour; 5mm hardox front with 12mm grade 5ontop around the bottom, sides are 4mm hardox with 5mm grade 2 titanium over the top, 4mm hardox back and top, top hopefully will have some pretty thick polycarb ontop aswell
Speedo; Vantec 47e
Wheels: 4 wide very grippy chain driven customs
notes: has a pneumatic tail.. and im trying to make it not look too much like THZ lol
Ill post pics as it comes together
Carnage page added to web site
http://www.teamdragon.org.ukwww.teamdragon.org.uk
The Saint with its halo :proud:
Pic on profile :)
What have you got driving that?
Just a little Perm! :)
very good. i like it :)
Four horsepower....Im scared, and I dont even have a robot :P
ay up
a spinner :)
im liking it
Yep Im doing it for Craigs event, I have been told WAR HEAD is coming so you will see my robot all over the arena €¦. Must remember dustpan and brush. :proud:
Carnage weapon test.
http://www.youtube.com/watch?v=uqH9JwTWYD8www.youtube.com/watch?v=uqH9JwTWYD8
Before anybody asks there was two steel spikes driven into the ground so the bot could not move.
tony, i heard a phrase on the vid you said, and i agree,,,,,
thats scarey !! :)
Looking good Craig any videos of it running.
Yep Jonno it is impressive you should here it live sounds like a gale is blowing with the air displacment.:mrgreen:
Sorry no videos yet I still have lots of bits to do on it before August (mostly drilling holes!). I hope to bring it to Guildford as a static WIP
http://www.youtube.com/watch?v=6z7EapPpKtchttp://www.youtube.com/watch?v=6z7EapPpKtc
Thought ill see if it still runs, may build the disc into Knightmares old chassis for Craigs event.
The more spinners the better :proud:
I love the sound of a petrol engine spinner :)
Lol Tony youre dam right, surprised you stood that close!
Dose anyone have a contactor for 24 volts to control the spinner motor for The Saint, It€™s a Perm 1.5Kw so I think about 180 amps should do it.
Thanks
Give these a shout Craig
http://www.albright.co.ukhttp://www.albright.co.uk
Albright for me for such an application.
Fightin Torque...Heavyweight Pillow Torque,
Dimensions 830mm X 525mm X 155mm
Weight 98Kg +/-
Drive, 2 X Mag C40-300, 2 stage 2Mod gearboxes ratio 6.5:1, final drive 8mm pitch X 20mm HTD timming belts.
Control, Spectrum 2.4Ghz, Roboteq HE with variable rate giro.
Power, 4 X 3000Mah Ni-cad packs.
Armour, various thickness of Hardox/titanium/nylon laminate, shock mounted in critcal locations.
Due early 2009
sounds good geoff- 4wd?
Of course Dave!
155mm high St Hammer will run right over that!
:proud:
Can it drive out of the pit?
:uhoh:
I know this thread has not been updated in a while but I just thought Id do it seeing as I have HW and that I was bored as well:proud:
Storm Force
000000>Weight : 87kg
Height : 52cm
Length : 62cm
Width : 55cm
Speed : 11mph
Cost : £1200
Status : Active
Armour : 3mm Aluminium
Power : 2 x Bosch 400w motors
Weaponry : CO2 Powered Flipper & Axe
Strengths : Multiple Weaponry and Srimech
Weaknesses : New Driver!
Gratz on getting storm force. Just curious what speedo do you run and what voltage do you run the bosch 400s?
That must of been one heavy christmas present.
Thank U! It was a great xmas present to open in the morning as well! The speed controller I think is DC Contacts Im not sure, it says that on the RR Database. Not sure about the voltage that the motors run on Im afraid. Ill have to ask either John Findlay or David Bewely.
Regards
Liam Bryant
hiya,
Yes it uses DC contactors, running at 24v.
John
Well done Liam on getting the robot Storm Force.
Another round shaped robot Hope you have lots of fun hitting those Flippers!!!
:wink:
Cheers Craig! I reckon as long as I dont get flipped out the arena, Ill be OK!
Apocalypse (2009 version)
Unarmoured Weight: 66Kgs
Final weight: ??????Kgs
Speed: 15mph (theoretical)
Drive: Bosch GPA 750W @ 24V
Power: 3 x 3AH 24V Bot packs
Speedo: Wotty 360
Weapon: Full pressure flipper
Chassis: 20mm Alumec 89 Bulkhead
Wheels: Same as Fightin Torque but blue.
Armour: 4mm Hardox, 3mm MS and 3mm Titanium
Cost this year: £100 ish
Cost overall: Who knows!
Estimated Completion date: Thursday 5th Feb, about midnight.
Most internal components are the same as the old one, just in new better armoured chassis.
