Just while we are on the subject I would just like some quick advice....
EV Warrior, 2Kg Spinning weapon, Requires efficient torque transference, Chain or a type of Belt drive?
Chris - http://www.featherweights.org/forum
Microship ues EV Warrior on a heavy disc, over 1kg, proberly 2kg not sure. A V Belt Drive like he uses would be near enough perfect. It seemed to get up to speed very quick without slipping. Was very good.
Mr Stu
meant microCHIP - cant be assed to edit post.
Mr Stu
....but was assed (sic) to do whole new post :)
I cant afford to finish off micro-maul, let alone buy an astro at the moment :sad: Ill see how it goes for now, luckily I should have quite alot of testing time before Magna
Oh, Ive just had a brainwave... Does anyone know what motor Tantrum and that nasty looking vertical spinner use? (both I saw at RC Wars a few months back)
I have an EV warrior motor with two custom CNC mounts (without the heatsink)
http://www.robotcombat.com/marketplace_mounts.htmlhttp://www.robotcombat.com/marketplace_mounts.html
...that I could sell or swop. Im looking for 3mm hardox, Ti sheet 1mm, and speed controllers (after blowing up my H5s in Aberystwyth)
I use that weapon set up in microCHIP and its very powerful @ 24v
Team Vertex featherweight, Vertical Limits has a 200mm 3.45+kg flywheel powered by a 300psi compressor (Mini EV) and it spin up pretty fast (under 5 secs for 63%).
If anyone wants to see a video of it against a concrete brick, just email me at: knightrousoxide (at) gmail.com
Picture also on my profile.
Ewan,
Tantrum and Wayne cummings feather (think it was called preditor?) both used the same type of car fan motor, Very powerfull ones. Carnt remeber what they are from but Ill let you know...
Dave, its ok, Jamez has told me
Im going forward with tests on the 12v Gold for now. Ill post vids on my website in a couple of weeks.
Yeah but Andrew - you guys are cheating as your all using 13.6kg - cheats! LOL!
Mr Stu
Andrews my team mate :proud:. We went to 13.6kg since the US manage to run some international event and a lot of us would like to jump the pond once in a while.
VL was made for under $50AUD excluding IBC and Radio gear. If we had a few $$$, VL could make the 12kg limit.
thats a thing i have been wandering . Is there any news on the feather weight , weight limit . Is it still 12kg or aare we moving with the changes and making it 13.6 kg ?
Speaking to alot of the UK roboteers - i personaly think it sounds like it may stay at 12kg - the true feather weight - weight limit.
Mr Stu
Any possable changes to the weight limit are due to be discussed at the next FRA committee meting, due to take place on 12/02/05.
We will let you all know the outcome shortly afterwards.
If you want your views on this subject to be taken into account, please contact your regional rep before the meeting. (contact details are on the FRA web-site)
Part your regional reps job is to pass YOUR views on to the committee, so please use them and make sure that YOU have YOUR say as to how our sport should develop.
Geoff Smith
Chairman,
Fighting Robot Association.
robot name: Kang
Power: 1x 12v cp2400scr nicad pack and 2x resoldered 12v drill packs
Drive: 2x 12v Drill Motors/gearboxes at 12v with 125mm wheels and a hub made from the guts of a drill chuck.
Controller: two 12amp custom made drill trigger servo controllers.
Weapon: 240mm saws, either 72 tooth or 50 tooth version powered by an ev warrior size motor at 24v (has a flat plate on it). speed is about 5000rpm ~
Armour: 10mm 5083 aluminium lid with 4mm steel armour, 10mm lexan in low stress areas
Frequency: 29.885MHz with a silvertone (http://www.silvertone.com.auwww.silvertone.com.au) military reciever
Status: just needs armour.
piccy of the early version with no armour or batteries mounted (and old version controllers) http://www.robowars.org/forum/album_pic.php?pic_id=606http://www.robowars.org/forum/album_pic.php?pic_id=606
Robot Name: ZERO
Drive: 2x 12v Drill Motors/gearboxes at 12v with 150mm wheels and a hub made from the guts of a drill chuck.
Controller: 2 x electronize 15A and mixer
Weapon: 2.5kg spinning drum powered by 12v drill motor. Approx speed 4000rpm.
Armour: 5mm Ali with 3mm polycarb on top.
Chassis: 15mm S/S box
Status: just needs Electronize and weapon wiring completed
I will be taking ZERO to Brighton on Sunday to gage reaction and get some feedback then will be looking to get to live events! Hoorah!
Sorry Pic of ZERO on profile. :)
Got some of my CNCd components now- pics on profile. :)
Zero looks great Glen. Look forward to seeing it at Sheffied.
Hey if Zeros going to Sheffield it can meet up with Conundrum Mk1. Zero looks like a good base to start with, wish i could have built mine as good as Zero.
Robot name: Little Hitter
Power: 1x NimH pack 33.6volts +600g C02
Drive: 2x 30v Drills motors 75mm dia wheels
Controller: 1 Technobots h bridge dual channel.
Weapon: Pneumatic axe. 80mm bore 50 stroke 16 bar ram(mounted vertically), paintball reg and buffer tank. 12mm pipes + 1/2BSP valve(3/2).Axe Shaft+head grade 5 ti.
Armour: 1.5 mm front, 1.2mm sides, 0.6-1.6 back all grade 5+ ti.
Chassis: 30mm nylon milled to 8mm in middle.
Weight: 12KG
Status: Finished. Going to sheffield.
Pic on profile
Robot name: Little Flipper
Power: 1x NimH pack 19.2 volts +600g C02
Drive: 2x 12v Drills motors 75mm dia wheels
Weapon: Full pressure flipper. 50mm dia 60mm stroke hydraulic ram.1/2inch Burket,enough pipework for buffer/area of ram.
Armour: 1mm - 1.5mm all round,1.5mm where electrics are. 3mm flipper. All grade 5+ ti.
Chassis: 12mm Nylon + 0.6mm ti.
Weight: 11.9 KG
Pic on profile
nice:)
2 new feathers building. (1) Noname. 18v drill motors for drive. linier actuator with a 400kg pull/push for lifter. 2 x 12v 3000 nicads 2mm stainless steel and 4.5mm polypro armour. Will be at Magna.
(2) Ram bot with wedge Gold motors 6-1 reduction chain drive. 2 x 12v 3000 nicads. polypro and steel armour.
Im just starting the build of my new robot a push bot feather weight this time. See pic on profile.
Robot Name: Dont know yet havent decided. Maybe Mini Mayhem?
Power: 24V 3Ah NiCads
Drive: 2 drill motors powering 4 80mm dia wheels
Steering: Traditional skid steer
Armour: 3-5mm thk steel
Status: Design complete just starting build.
Richard
Team Mayhem
Oh forgot
Speed controller: IBC
Features: Drive train suspended from body to allow adjustment of scoop height & protect from distrotion in chasis.
Richard
Team Mayhem
pics look very good
Flipper
Current Version
Speed: 14Kph
Power: 1x 14v 3000mAh soldered NiMH Pack
Drive: 2x 9.6v Drill Motors
Controller: 2 x 30amp Electronize with external Relays
Weapon: High flow rate low pressure 10bar Pneumatic Flipper
Armour: 6&10mm Polycarbonate
Frequency: 40.685MHz
Status: Complete, Pic on Profile
Flipper
Upgraded Version (Parts are here but are not in the robot yet)
Speed: 18Kph
Power: 1x 16.8v 3300mAh soldered NiMH Pack
Controller: 2 x 30amp Electronize with External Relays
Notes: Should drive in a Straight Line!
Status: Needs to be assembeled.
Latest pics of noname on profile
bit of a change to kang, changed most of drive over to two ride on kiddy car drives with collosal drive motors and big wheels, speed is average but pushing power = OMG!
bit of a progress picture.
http://www.robowars.org/forum/album_pic.php?pic_id=663http://www.robowars.org/forum/album_pic.php?pic_id=663
wedge is mounted, saw is mounted, most of the guts are done (mounted to the lid) but the side and front armour still needs doing.
also some pics of the kiddy car gearboxes which are pretty nifty, lighter than drills too and stronger. much slower tho :)
http://www.robowars.org/forum/album_pic.php?pic_id=665http://www.robowars.org/forum/album_pic.php?pic_id=665
http://www.robowars.org/forum/album_pic.php?pic_id=666http://www.robowars.org/forum/album_pic.php?pic_id=666
Heres a vid of the testing of G3 FP.
http://homepage.ntlworld.com/m.a.young/g3fp.wmvhttp://homepage.ntlworld.com/m.a.young/g3fp.wmv
And how long would you have been grounded if it went through the conservatory doors without opening them first? :)
V. nice though
vertigo pic on profile (as of last friday)
new stats-
plain old drills for drive this time, hobby motors have been sold
scorpion jr style disc mounting with weight saving yet to be done
3mm grd5 ti front and back with 10mm poly chassis
still 4wd
astroflight 40 at 2:1 ratio on disc
hardox discs (if they ever arrive!)
deBiel
4x 12v drill (2 in each wheel)
Stinger stile inertia axe, 1.2mm Gr4 Ti, hope it doesnt bend.
2x Bugs rc-relay
Relay drive, hence uncontrollable, have to work on those speedos
2x 2.5Ah 12v hawker cyclon battery
12mm HDPE tube armour (19 cm diameter) in schock absorbers
20mm HDPE axe handle
16mm steel axle
PC internal support structure
1:1.5 reduction timed belt drive
23cm wheel diameter, est. 14 Km/h top speed
http://www.bugs.nl/media/album/view.php?&path=L3Byb2plY3RzL2Z6bjEvSU1HXzI2MjdiLmp wZw==http://www.bugs.nl/media/album/view....SU1HXzI2MjdiLm pwZw==
http://www.bugs.nl/media/album/index.php?path=L3J3L2J5ci9tYXJjby1tcnQyMDA1L25sLWJ 1Z3Mvhttp://www.bugs.nl/media/album/index...cnQyMDA1L25sLW J1Z3Mv
Ewan, I being very serious here for a moment..If your hardox disc is anywhere near the size /weight of the disc I saw at Magna then you will need a good bit more that a 2:1 reduction on your Astroflight 40!..Trust me on this one Ewan, I know that motor inside out and I guarantee that at 2:1 you WILL cook it very quickly!
Ill talk to you about it at Denbigh at the weekend.
Geoff.
we cooked one in san fran, interesting smells come out of it. That was with a 5kg disc at a 4:1 reduction if i remember correctly for 3 minutes.
hmm, im still learning, what are the specs (weight, reduction, size ect) on scorpion jrs weapon?
Stefan nice bot and no offence but is there any stats on the little pinser/crab like bot on the photo album?
http://www.bugs.nl/media/album/view.php?&path=L3J3L2J5ci9tYXJjby1tcnQyMDA1L25sLWJ 1Z3MvSU1HXzI1ODYuSlBHhttp://www.bugs.nl/media/album/view....1HXzI1ODYuSlBH
http://www.bugs.nl/media/album/view.php?&path=L3J3L2J5ci9tYXJjby1tcnQyMDA1L25sLWJ 1Z3MvSU1HXzI1ODUuSlBHhttp://www.bugs.nl/media/album/view....1HXzI1ODUuSlBH
Chris - http://www.featherweights.org/forum Click Here For More Information
Geoff?
edit - ok, ive found out now
