Re: EYE OF THE ROBOT - Extreme Edition
Eye of Ran II vs. Gehenna
hi Andy! *waves*
As Kody has pointed out, due to my unceasing incompetence I am using EoR II here. My strategy is fairly simple, really just use the back wedge of the robot to keep Gehenna away until the blade is spun up, which should take about two seconds, and then hit it repeatedly until such a time as further hits become unnecessary or impossible. Good luck Andy ^^
Right guys, WAZZZZZZUUUUUUP! Yes, I have been watching the Annoying Orange, I'm so cool :proud:
Guess what? First Challenge Belt battle! Guess what else, sadly I am an impatient being and thus I have cleared Parassyte's place due to not only getting no robot but also not a name or location - THAT takes a piddle a bit too much :? And guess what else, another Challenge Belt space is open, but also the same number of All-Star places STILL available - come on guys, PLEASE!! :sad:
Anyway, enjoy, and sign-up please :talker:
Challenge Belt:
Gehenna 2 vs. Eye Of Ran III
??? vs. The Servants Assistant
??? vs. Munch
??? vs. Flick Of The Wrist
??? vs. Delirium Tremors
??? vs. Macduff The 5th
??? vs. Exotherm
??? vs. [Open entry]
From Bourne, Lincolnshire, Gehenna 2!!
Entered by AJ
The grandson of Ripper, here comes a machine continue the family tradition: kicking ro-butt! Here we have n interest wedge shape with slanted out sides to make getting underneath from the sides that little bit trickier than the standard wedge. The machine is also packing a punch, both with the 16mph speed coming from motors providing great push against it€™s competitors, and with the weaponry it possesses: here we have a front forward-hindged flipper used to push robots great distances across the floor in a beautiful flying arc that many rear-hindged flipper would be jealous of, as well as the drum at the rear, useful for deflecting opponents away with it€™s 5kj output. Finishing this robot off is 6mm thick Titanium/Vanadium alloy, making it hard to get into, but a 10mm rear clearance is open for any flippers strong enough to get underneath.
From Pontefract, Eye Of Ran II!!
Entered by Joey McConnel
Where does this robots name come from? I dunno, but if you see Eye Of Ran, you better start running! This T-shaped robot of doom is equipped with a deadly bar weapon: a deadly 30kg metre long spinning bar that blends Flywheel logic - by using weight reducing holes to make the outer edge of the blade heavier - with a bar€™s raw power to hit hard and fast - spinning at 2500rpm - and giving off 106kj per hit from those curved teeth shaped hammers at each end of bar! This robot has speed as well, being at 12mph and capable of fantastic acceleration away from it€™s predator, as well as towards it€™s prey, and the 2 wheel drive with both wheels mounted at the front make it easy to keep the blade pointed towards it€™s target! But even if it€™s caught, the 4mm Hardox shell with Polycarbonate overlayer over a Ti/V box section chassis make this a tough not to crack. Rear/side wedges serve as additional weapons to push with, and it€™s nearly impossible to attack this robot without being hit by the blade, but underneath the blade is a 5mm ground clearance and in a straight pushing match this robot could find itself staring defeat in the face.
Booth #1: AJ
Booth #2: Joey M
Roboteers, stand by!!!
3€¦2€¦1€¦activate!!!
And the first Challenge Belt contest is underway€¦and AJ is straight out of the traps here, the drum spinning, driving in as Joey faces his rear wedge towards Gehenna 2, and powers on as the blade spins: they collide, but GEHENNA IS UNDER AS THE BLADE HITS THE FLOOR! And it€™s a beautiful sight, as Joey machine flies away across the arena as the blade makes sparks fly up from the arena floor! AJ€™s got off to a good start and aims to keep this up as he speeds off after the Challenger at slightly greater speed€¦but the blade is now fully spun up, making a doodlebug noise of doom! AJ charges as Joey turns around€¦BOOM! Oh my days!! The front flipper of Gehenna is nearly peeled straight off from that hit! This weapon on Eye Of Ran is mighty! Already into this battle the Challenge Belt holder - the mark of a warrior - is on the backfoot! But Aj isn€™t giving up as he goes in once more, this time attacking the side of panels€¦but this plan is hard for AJ to make work; Eye Of Ran€™s turning system is making it hard to get at the sides, as Joey constantly turns around - using the bar as a point to turn round - to keep AJ in front of him. It€™s now Joey€™s turn to attack, as he lunges at the side of Gehenna€¦but nothing as dramatic as the first hit, just a long deep cut forms in the side plate, but the nearly torn off front is still serious hurt caused here. AJ turns once more and comes on a brave - or foolish - headlong charge, but the bar is spinning at full speed once more€¦BANG! And there goes the front flipper plate, as well as AJ most effective tactic ploy; the armoury around the front is still there but all the mechanics on display through a great hole in the Ti/V front! But does this stop AJ, you bet it doesn€™t as he comes ramming back in, this time using the rear drum: and whilst it isn€™t quite the same weaponry power as the bar AJ is using it well on the sides of the T shaped machine, as he stratches away on the side wedges the way a cat scratches on a scratch pole. Not greatly terrifying, and AJ€™s more powerful robot can€™t seem to push Eye Of Ran; whenever AJ reverses in for a shove he just seems to ride up the side wedge a bit, taking away his traction€¦but AJ€™s losing control here, as he rams in, but rides up the wedge€¦HE€™S GONE ALL THE WAY UP IT! HE€™S STUCK! AND JOEY TURNS HIS BAR SPINNER AROUND TO THE EXPOSE UNDERBELLY€¦A sickening tear, and the rubber tread of a wheel flies off - it€™s urethane rubber, meaning it€™s been torn clean off the wheel hub of Gehenna€¦and now Gehenna is near weaponless, and already nearing the countdown! But Joey€™s not finished! He rams in on the rear! SMASH! Another clean cut in the rear panel, but in he comes again! SMASH! And now the plate is gone€¦but something€™s flown out with it - it looks quite small€¦it€™s the safety link!! And now the Challenge Belt holder has to already give it up, as the highly impressive Eye Of Ran powers down, eyed up by the audience€¦and the future challengers!
10€¦9€¦8€¦7€¦6 €¦5€¦4€¦3€¦2â ‚¬Â¦1€¦cease!!!
Result:
Gehenna 2 needs another remodel!
EYE OF RAN II STEALS THE CHALLENGE BELT!!!
MATCH: TWO
Eye Of Ran II vs. The Servant€™s Assistant
Send in tactics, predictions, comments and a number - 8) from 1 to 10, 10 being the best 8) - on how cool I am for opening this post with an Annoying Orange mention :proud:
Nice battle, Paul, and well done to Joey for the win. :)
FYI, I believe that Parassyte is Mr. Nick Schuch of North Carolina.
I think Eye of Ran II will hold on to the Challenge Belt against The Servant's Assistant.
Yeah, gotta agree with Andy here. Eye of Ran to keep the belt. Brilliant battle there, btw. :)
If you would like me to, I can fill in those gaps you have in for you! ^^
That's... a Challenge Belt and 2 All-Stars, yea? I believe I have just the things for it...
Throw V'Ger in Challenge Belt, Mobile Failure in the All-Stars. If you want it RIGHT full, throw SOTAR in too. ^^ (I think they both fit the qualifications as such, orz...)
You may find all them here!
Brooks, Alberta, Canada represent~ (I moved recently and am too lazy to change my location to the box of info to the left, so sue me. :P)
Hey Tracy, thank you! Sadly tho, it is one All Star replace per contestant. However, with the tournument structure currently in place, I can make it work with 9 robots as opposed to 12 - the latter made it sound that bit more exciting :proud:
I'm guessing your stats are on the same board as mine (strickenone), so I'll look them up.
btw, because you put Mobile Failure first, I'm gonna put that down as your All-Star Entry, if you have no complaints. And also, screw waiting for an extra 3 ppl, the All-Stars line-up will be posted AFTER Tracy has given me an indication that Mobile Failure is REALLY the All-Star she wants.
btw Tracy: THANK YOU :proud:
Having read the latest fights after getting back from holidays, I have to point out that Metallic Doom actually won the annihilator based on the judge's decision :P
Although the fight was really good, Axe To Fall's score actually adds up to 56, and he was scored incorrectly for aggression (4 x 4 equals 16, not 20), so Axe To Fall actually scores 52 next to Metallic Doom's 53 :)
Not trying to rain on anyone's parade, just pointing out a human mistake :)
Crap, you're right. If you think that's bad, two additonal points: I've got a B in GCSE Maths :lame: and also I should've notice my total judges scores are 105, and both the robots scores added to 110. :lame: x2
So, oops everyone. Correction here:
Result:
Axe To Fall has fallen down€¦hard!!
METALLIC DOOM WINS THE E.O.T.R ANNIHILATOR!!!
Yes, thank you Lewis. Hope you had a great holiday, and looking forward to reading your battles in MM :proud:
I'll get the next battle up asap, and also the All-Stars line-up once I've got full confirmation from Tracy.
Seeing as SOTAR was an afterthought, I don't think she would cry if it was left out. :P
Quite right. ^^ I only mentioned SOTAR in case you wanted to fill more spots or something!
Mobile Failure is the one I initially had in mind. ^^
(And it's no problem! :) )
