Re: featherweight flipper systems
I've got in touch with Trevor so all is good!
I'm having trouble sorting out the thread sizes etc. I have the tank below (with an on off valve and I'm guessing a standard paintball tank thread) and the solenoid valve. I'm confused about the thread sizes etc (will I need adapters etc) and I'll be using the trev reg
http://cgi.ebay.com/PURE-ENERGY-16oz-Co ... 0385014232
http://cgi.ebay.co.uk/Pneumatic-5-2-Sin ... _558wt_922
Also, how much does a trev reg weigh?
a lot less than any commercial version.
I can imagine! But seriously, does anyone know?
not enough to matter probably
i've weighed one but i can't remember how much they weigh . i don't think they are more than 300g
I'm going to be so borderline on weight it's unbelievable!
My Trevor, without CO2 nut, is 112 gram. And I guess I can remove a few more grams if needs be.
Thank you, I've got all the parts on order now so when they all come through, I'll weigh the whole lot. If it's over, think I'll be dropping down to 2wd and hacking two corners of the chassis off!
Just about to order my push fits from technobots and I want to double check a few things. If I want to order a stud for a Trevor reg and I'm using tubing with a OD of 10mm, I'd want a 1/8 10 BSP stud correct? And the solenoid valve is 1/4 BSP so I'd want 1/4 BSP 10 items?
