If you have 0 ground clearance at the front and back, then you won't be able to move. :proud:Quote:
Originally Posted by corsair_lightning
*Cough*FAIL!!!*Cough*Quote:
Weapon: 2 solid Hardox snowplow-like scoops that can move slightly vertically, like Behemoth's, so I get good pushing power, but 0mm ground clearance at the front and back.
...and what exactly are they powered by? :P If they are not powered by anything, they will most definitely be static and will most definitely have a permanent ground clearance of 0, and you will most definitely not be able to move. :P
Far be it from me to defend Mark, but he is right on this rare occasion...it's perfectly feasible to just have the scoop supports moving freely on bearings, which would give you 0 ground clearance at front and back (although any major damage to the arena floor would jam the scoop against it and prevent movement in that direction, possibly restricting the robot somewhat)
Well he still didn't put them in the stats. How are we supposed to know that? For all we know, he just may be throwing stats together like he usually does. :P
(this is why you are suppose to be clear in your stats, Mark)
I was thinking of that idea, but I really couldn't get it laid out enough to put it into the stats...
EDIT: The stats have been fixed to more precisely detail how the scoops do what they do.
lian walsh: welcome back to crazy bots
let the 4th battle BEGIN
pod 1: kody/anarchy
pod 2: mark/minesweeper
3!!!!!! 2!!!!!! 1!!!!!!!
ACTIVATE
here we go
minsweeper charges across the arena at anarchy and pushes anarchy from the side into the wall, now anarchy comes back for
an attack, but minesweeper rams them again against the wall and comes in again, ooh that was close anarchy scuttling away
just in time and minsweeper in now stuck on the arena wall and anarchy comes in with the axe again and again and again how
is minesweeper gonna get out of this, down comes the axe again, now in comes shunt and lifts then off the wall, but not
before shunt gives them an axe blow, now minesweeper is away and now pushes anarchy into the pit realease button and now
minesweeper pushes anarchy into the pit, but four of anarchys legs are touching the floor and scuttles out to carry on
minesweeper now pushing them into the wall again, anarchy gets away and hits the top of minesweeper, OUCH theres a
massive hole in the top of minesweeper but its unshaken from the blow and comes back again and anarchy puts another hole in minesweeper
but this time the axe is stuck in the body work of minesweeper now anarchy has got them where he wants them and nows pushes towards the
pit and is almost in but minesweeper burns rubber and pushes back and shoves anarchy into dead metal, oh dear here comes the saw BZZZZZZT! cutting into the side but anarchy turns round AND FLIPS DEAD METAL and escapes the cpz but minesweeper is waiting and charges
but anarchy flips them up and over now minesweeper lacks pushing power and is pushed into the cpz with shunt and down comes the axe again
now minesweeper is moving very slowly and so is anarchy but there saved
as CEASE is called
now we go to the judges now for the scores
minesweeper
damage style control aggression
7 9 7 10
total 33
anarchy
10 7 8 9
total 34
anarchy wins by 1 point coming next the heat final
Well well well, because I was such a goddamned arse yesterday I didn't think I'd win. But I did anyway. Meh. Apologies to Joey and Mark and whoever I offended. I seriously had a bad day yesterday. Soz.
Apocalypse II vs. Anarchy
Well I'm boned now. :P Meh, flip it and axe it, all I can do. :P
Aside from the fact that his axe ripped a hole clean through 7mm hardox, and Anarchy unlikely crawled out of the pit, it was a half-decent fight...
And I accept your apology, Kody.
Isn't that a little hypocritical of you, seeing as you run VRW? :PQuote:
