And question to Paul, which set-up are you using on Knyfe?
For this, it has to be...
5: A 15mm Hardox wedge angled at 42* with an extension, perfect for deflecting vertical spinners and getting under other robots.
Im going to ram Fairground Killride and TVW into oblivian, and I may suggest that Kody with his 106kj goes for Woody. According to basic vapourboteering, a big disc + Wooden robot = :blush:
And against Dannys robot?
Its second post in the August 08 Archive.
Jaws for slammer, pnuematics for achilles
Some questions
Questions about the 6isc
Is the disc mounted onto the main axle?
How is the disc driven (chain/belt/direct gearing?)
Are the wheels protected from a lucky front on attack?
In the picture, there looks like a gap in between the 2 semi-circular wheel protectors, is this true oris the gap filled?
How are the wheels driven?
What voltage do you run the disc motor at?
Systematical Shockerlarity
Can the drum run in reverse if you end up on your back?
How is the drum driven (chain/belt etc?)
Fling:
Wouldnt a shape at the rear be better than a ?
Tire 4?
Are the teeth a part of the flywheel (like 6isc)?
How is the disc driven with both motors?
Can you squeeze in another battle please?
Because Ive just realised a grudge I think I wish to have, and get my own back for Nitro-Genes first defeat.
Nitro-Gene 4.0 vs. The May Tracks Has You (Rematch of the Here I Go Again Grand Final)
Drum can run in reverse and is chain driven
Paul, only if Frank agrees to it
Are we talking about the hardox bar part here? If so, not directly, its mounted onto the outer axle, which is mostly mounted onto the inner wheel hubs and theyre mounted to the main axle:proud:
Direct gearing
That would be impossible while maintaining proper invertability, so no.
The gap isnt filled.
Dirtect gearing.
Thought Id put this in the stats, sorry. 36 V
May Tracks will gladly take on Nitrogene again.
