But Aaron - they all have the same stats! :proud:
I imagine they are all painted different colours. I bet on the red one.
an Infusion vs. Infusion match would made great reading:rofl:
1 - Biohazard
2 - M2
3 - Atomic
4 - Suicidal Tendencies (S5 version)
5 - Quocunque Jeceris Stabit
6 - Son of Wedgie
7 - I would go with Chalkie 3G, but Aaron would prob tear it to pieces as it was designed during the stage where I wasnt feeling straight, but meh
8 - Flipping Mad B2B (stats can be found in Martyns all stars tourney)
5, 6 & 7 can be located here: http://farr.proboards21.com/index.cgi?board=TeamSolarizedStatshttp://farr.proboards21.com/index.cg...SolarizedStats
And for my team name, lets go for Team Jimmie-McGee
Thanks Dave for two reason:
1: Its one extra space filled in. And all spaces completed!
2: Hes reminded me about the team names :proud:
For those people who already have team-names. e.g, Kodys offical one is Team Zlayers. For those with offical team-names, Ill use them.
1- TJS (Team ???)
a. Tornado
b. Gravity
c. Wheely Big Cheese
d. Terrorhurtz
e. Killer
f. Counter
g. D-J
h. Bere-y Interesting
2- Chris Mason (Team Dinowarrior)
a. Orka MK4
b. Die-Ceratops ReInvertus
c. Cyclone Force 2.5
d. Leprosy Infection
e. Mega Masher 2
f. Disc-O-Inferno
g. Iron Awe 2.1
h. Obliteration
3- Martijn Benschop (Team Varying Everyday)
a. Storm 2
b. Big Nipper
c. With Or Without You
d. ???
e. ???
f. ???
g. ???
h. ???
4- Alex Holt (Team Doomforall)
a. Black Panther Queen
b. Achilles
c. Tengu VII
d. Bodyhammer
e. Recyclops
f. Kali
g. Dante
h. Ramthrax 2
5- Kody Kunz (Team Zlayers)
a. Avarice
b. Wedginator 6.0
c. Seung Mina III
d. Super Gore Evo
e. The Zenith
f. Aftershock
g. Turbulence
h. Tornado Mer
6- Steven McGregor (Team Braveheart)
a. Wedge Devolution
b. Killotine: EVO
c. Metal Sonic Spin Dash
d. Whirligig 4.0
e. Clawdius Decimus Murderous
f. Turbo Tails
g. Chaos 2
h. Pussycat
7- AJ (Team Idiot Technology)
a. Megabyte
b. Razer
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
8- Martyn Forsyth (Team ???)
a. Dantomkia
b. Fluffy
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
9- Will Harrison (Team MHF)
a. 259
b. Voltronic
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
10- Leo Van Miret (Team ???)
a. Splinter
b. Hannibal
c. Obsidian
d. Mantis
e. RCC2
f. Blackdevil Warsone
g. Eternia
h. GBOD
11- Dave Sheppard (Team Jimmy-McGee)
a. BioHazard
b. M2
c. Atomic
d. Suicidal Tendincies
e. Quocunque Jeceris Stabit
f. Chalkie 3G
g. Son Of Wedgie
h. Flipping Mad B2B
12- Aaron Knight (Team ???)
a. Infusion Alpha
b. Infusion Beta
c. Infusion Gamma
d. Infusion Delta
e. Infusion Forsa
f. Infusion Helix
g. Infusion Torsen
h. Infusion Faux
I just need the robots revered from the people who still have to send them in, and then I can post up the draw!
I remember when my team name literally was Team ??? :proud: So just to be annoying, Id like to change my team name back to that please. Meanwhile, I will get cracking on some stats, Im working on a few surprises for this tournament. Also, where are Aarons two real robots?! :wink:
To be honest, hes already being a pain by entering 8 vapours, all with the same stats but different names, but since he wants to enter, then Ill let him keep them since I really want to start this!
My team name is Team Predator Bullies.
Here Paul. :)
Wedginator 6.0
Shape: Wedge with scoop at the back.
Colour: Green crocodilian texture.
Weight: 100kg
Speed: 24mph
Armour: 6mm hardox 750 all around the main body except the underside, which is 6mm titanium.
Chassis: 3mm hardox 400 box chassis
Drive: 2 x LEM130 at 36v.
Power: 6 NiCad Battlepacks at 36v
Motivation: 6WD. 6 titanium hubs, with vulkalon rubber for traction.
Ground Clearance: 0mm at front and rear, and 4mm at the sides. There is a hardox plate at the front with the name of the bot there, to aid in getting under skirts.
Diemsnions in CM (LxWxH): 95 x 73 x 35
Weaponry: This is where it gets interesting. Wedginator has an all-around flipper this time around, powered by a single 2.5kg CO2 bottle. How does it work? Well instead of the panel coming up to flip, the entire exterior armour is tilted. As the armour is a little heavy, it will probably only be able to flip about 300kg, and toss 175kg, at both ends. It tilts from the back, so at the front it acts like a front-hinged flipper and at the back the scoop acts like a rear-hinged flipper, so it can fend off attacks at both ends. The armour is attached to the chassis at the front to avoid the armour coming off easily.
Srimech: Flipper
Strengths: Unique design. 6WD, extreme pushing power, speed, and acceleration. Hard to get under. Flipper still good despite slight lack of power.
Weaknesses: No damaging weaponry.
Super Gore Evo
Shape: Rounded box with front wedge/plow/scoop, and spike skirting. See picture for more info.
Colour: Navy blue, with red claws.
Speed: 18mph
Weight: 110kg
Armour: 4mm hardox 600 for the main body.
Chassis: 3mm hardox box chassis
Drive: 2 LEM130s @ 48v. Gives out 18HP altogether. Weigh 6kg altogether.
Power: 6 NiCad Battlepacks @ 48v, weighing 12.8kg.
Tracks: Titanium, with clear vulkalon rubber strips for grip and traction.
Ground Clearance: At the front its a dead 0mm thanks to the front scoop. At the sides and rear its 6mm, but only if you can get by the 4 skirt strips on each side, made of 8mm titanium.
Dimensions in CM (LxWxH): 120 x 90 x 14
Weaponry: Interchange hydraulic pincers, that can exude 4 tonnes of pressure at the tip. The pincers featured in the picture are the clamping onces, not meant to damage, but to get a grip. Those said pincers have more vulkalon rubber attached to the tips to maintain hold, and drag them wherever with the awesome pushing power. The other set of pincers are piercing ones, diamond-tipped, to grab opponents with weaker armour, and damage electronics inside. The pincers themselves are made of 9mm Grade 5 titanium and are firmly attached to the hydraulics system. Between the pincers is a 8mm titanium wedge scoop, with a 5mm hardox 600 plate.
Srimech: Invertible.
Strengths: Fast, powerful, awesome traction, versatile and damaging weaponry, tough armoured, works the same either way up, hard to get under.
Weaknesses: Tossed easily if gotten under, tracks exposed to crushers and axes (but very sturdy nonetheless).
Pics:
Wedginator 6.0 - http://www.geocities.com/kodybluz/Wedginator6.pnghttp://www.geocities.com/kodybluz/Wedginator6.png
Super Gore Evo - http://www.geocities.com/origkody/SuperGoreEvo.pnghttp://www.geocities.com/origkody/SuperGoreEvo.png
Last two will be up later. :)
Wedginator looks awesome! Thanks for those, Kody. Theyre very much apprieciated.
I cant wait to see the last 2! Just one question, do you know where I can find stats for Tornado Mer?
Kody. WEDGINATOR 6.0. IS. AMAZING. That is all.
