that depends :)
that depends :)
James, we just ran out of webspace last year, couldnt fit the whole video on the net.
I did put our video on the net. Just checked and its still there, all 500MB of it. Not been updated for a long long time.
ftp://http://www.bignipper.no-ip.orgwww.bignipper.no-ip.org
(was it 2003?)
Ok, the news gets worse as not only is B.I.O not attending the event but Conundrum Mk1 is not going to be running, as we require its batteries after a couple of places are waiting for cells. So we have had to pull the x2 12v 3000mAh NiCad packs out of Conundrum Mk1 to put in Conundrum Mk2 to get that running for the event, and im not a happy bunny.
Chris - http://www.featherweights.org/forum
Chris, Try http://www.overlander.co.ukhttp://www.overlander.co.uk every pack of batteries weve ordered has arrived within 2 days and usually next day, got some for Little Flipper this week.
Guys,
I Fired the new arena flipper yesterday for the first time.... Scarey :)
I need two volunteers. a heavy weight and a feather weight which will be coming early ish on saturday to be the first guinee pig.
I need to test it with no public to see where robots end up.
Any takers...... plllleeeeaaaassseeee :)
JOhn
Roaming Robots
Jonno, Ill volunteer Pillow Torque for your test. We should be there fairly early.
Jenny
we will need to run our heavys before the show, so you can use one of the them.
...hold on why dont you just use your own robot????? :)
cause hes not daft!
