have the steel rim go into the aluminium centre more on the opposite side of the tooth. on omen i have a section milled out of the tooth and surrounding area, this could be hard to implement on a rim style disc though.
So it will balance with the opposite tooth profile inside the rim? yes
Yeh
Really nice looking machine there!
You will need a bit more than just the equivalent tooth on the inside of the rim because although they would be the same mass, the inner tooth is closer to the pivot and so isnt balanced. Will need a little bit more. If you email me your drawing and dimensions Il produce a 3d cad version with the counter balance single tooth design. james(at)robochallenge.co.uk
Keep up the good work!
Thanks James I thought that would be the case, measurements emailed
so here are a few updates
and some more pics
and just because its fun, and i have a surplus of parts. I will be starting on another feather, with some exciting lifting bits, it will change shape during the bout
That's an unique looking machine, Im eager to see the weapon tests :)
more pics work is coming along :)
