Re: How could I Improve pt 2
Killophobic (Active)
Weight: 100kg
Shape: Lightning (S7), essentially a wedge with highly angled sides and rear. It looks a bit like an angled flying saucer.
Colour: Gold. The flipper is dark blue.
Dimensions: 90cm x 80cm x 35cm
Drive: 2 24v S28-400 Magmotors powered by 4x NiCad Battlepacks.
Locomotion: 2 foam-filled urethane rubber wheels with aluminum boron carbide hubs.
Armour: 3.5mm Hardox monocoque
Speed: 20mph
Ground Clearance: 0mm at front, 0mm at back due to torsion-sprung titanium skirt(5mm without skirts), and 5mm at sides.
Turning Circle: 0m
Weapons: A rear-hinged flipper, powered by a 2.2kg 750psi Co2 tank. It can flip robots up to 1000kg using a 70mm bore 300mm stroke ram.
Srimech: The flipper. If it lands on its side, the rather interesting shape will allow it to fall back onto its flipper.
Strengths: Good weapon, excellent body shape, strong armor, extra rear weapon.
Weaknesses: Controversy. Nah, there never was any controversy.
Bio: The sequel to a clearly ripped off robot, Killophobic is essentially an updated version of Lightning, of who's team I am an honourary member of. The robot should do well in combat.
Dalmatian (Active)
Weight: 100kg
Shape: Storm II, basically a box with the sides angled inwards, with Growler's upper jaw(Shaped like the top of a bulldog's head) above the front wedge. The top of the robot slowly rises like a wedge to stop at the back of the Growler head.
Colour: White with black spots.
Dimensions: 90cm x 70cm x 25cm
Drive: 4x 24v S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Locomotion: 4 foam filled Vulkanized rubber wheels.
Armour: 5.5mm Titanium/Vanadium alloy.
Speed: 20mph
Ground Clearance: 0mm at front due to wedge, and at sides and back due to 4mm titanium skirts. 5mm at sides and back without skirts.
Turning Circle: 0m
Weapon: The front wedge has Mute-style barbs on it. Once a robot is stuck on the wedge, the Jaw, powered by a 3kg 750psi Co2 tank, comes down with about 1 tonne of force. The weapon is designed to grab, not to crush.
Srimech: A pneumatic rear-hinged lifting arm, built into wedge-shaped top of the robot, powered by a the weapon's Co2 tank.
Strengths: Powerful motors, revised srimech.
Weaknesses: Average armor, and limited Co2 for the srimech.
Bio: Roveress Evo was mostly overhauled and became Dalmatian. The shape was switched to a modified Storm II shape, but the weapon was kept and improved.
Bandwagon (Active)
Weight: 100kg
Shape: A quite complex box-wedge. The box shape itself is angled 10 degrees towards the wedge, which itself is angled at 45 degrees. The entire shape's edges are rounded to protect against spinners, while the back is rounded to prevent stranding.
Colour: Chrome. The flipper is red, while the skirts are blue.
Dimensions: 100cm x 80cm x 30cm
Drive: 4x 24v S28-400 Magmotors, powered by 7x A123 Battlepacks, giving me an average of about 18hp.
Locomotion: 4 solid rubber wheels with Aluminum Boron Carbide hubs.
Armour: 5.5mm Titanium/Vanadium alloy, with 7.5mm of Vulkanized rubber on top to prevent axes from doing damage. If need be, the rubber can be removed and placed under the titanium for shock absorption.
Speed: 20mph
Ground Clearance: 0mm at front due to shape, 0mm at sides and back due to 5mm titanium torsion-sprung skirts. 5mm without skirts.
Turning Circle: 0m
Weapons: A powerful rear-hinged flipper, powered by a 1000pi 2.5kg nitrogen tank, and utilizing 2 70mm bore 300mm stroke rams to power the flipper. The flipper can flip up to 500kg about half a meter into the air.
Strengths: Jumping on the bandwagon.
Weaknesses: It can only flip, push, and move at 20mph. Not much else.
Bio: Bandwagon was a robot with a design based on the very successful Alex Holt vapour Achilles. After seeing Kody Kunz and his robot Seung Mina V, I realized I also needed an Achilles-type robot.
Tallit (Active)
Weight: 150kg
Shape: Elongated triangular pyramid with steep rear and very shallow front, like Gabriel
Colour: White, with thin Gold and blue stripes.
Dimensions: 120cm x 90cm x 35cm
Drive: 2 36v LEM-170 motors, powered by 9x NiCad Battlepacks, giving me an average of 26hp.
Locomotion: 2 Drillzilla-style shuffling feet at the rear, giving Tallit good traction and pushing ability. The robot also has a caster underneath the nose to allow maximum traction on the floor.
Armour: 5.75mm Hardox monocoque
Speed: 20mph
Ground Clearance: 0mm at front due semi-wedge shape, and 0mm at sides and back due to 5mm titanium skirts. 5mm without skirts.
Turning Circle: 0m
Weapons: A rear-hinged electric lifting arm, powered by 2 36v LEM-130 motors. It can lift 200kg 50cm into the air.
Srimech: The lifting arm.
Strengths: Shuffler, uses weight advantage, has an actually powerful electric lifting arm.
Weaknesses: Could have major faults.
Bio: The first ever vapour specifically designed to represent Israel in the World Championships, Tallit is a shuffler, and is prepared to do a whole lot of flipping with its actually powerful electric lifting arm. The reason it represents Israel: I hope to go there some day and see the places mentioned in the Bible.
American Oil (Active)
Weight: 110kg
Shape: All Torque (S2), which is a long box with a wedge on the front and back. However, the wedge at the front is extended all the way to the ground. The sides are also slanted 10 degrees inward, like a wedge, to prevent stranding.
Colour: Chrome with 3 stripes: one red, one white, and one blue running down the middle. The sides are black.
Dimensions: 90cm x 70cm x 20cm
Drive: 4 24v S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Locomotion: 2 70cm x 10cm x 10cm rubber tank tracks.
Armour: 6.5mm titanium/vanadium alloy
Speed: 17mph
Ground Clearance: 0mm at the front due to extended wedge, and at the sides and back due to torsion-sprung 5mm titanium skirts. The springs are wrapped around a foam rod to prevent shock damage. 5mm without skirts.
Turning Circle: 0m
Weapons: A 750psi rear-hinged flipper with 20 flips mounted on the front, powered by a 2.5kg Co2 tank. The robot uses an 80mm bore 300mm stroke hydraulic ram to counter for the increased pressure, and the rear wedge should prevent me from flipping myself.
Srimech: The flipper. Luckily, the slightly modified All Torque shape prevents it from being stranded on its side.
Strength: Tough, uses the 10kg track advantage wisely.
Weakness: Tracks Controversy
Bio: This robot was previously a newcomer in both Robot SMASH and AJWars. While it performed lacklusterly both times(being beaten by Liar 2 and Infusion respectively), I have decided to be possibly stupid and revive it, mostly due to me not properly exploiting the tracks weight advantage. If you need to know, this robot was formerly Cyrilium 2.
Son of Tenderizer (Active)
Weight: 100kg
Shape: Simply, a box with 2 wedges at the front: one on the left, and one on the right. There is 20cm of width in between the 2 wedges for the Tenderizer to come down, like Wedge of Doom
Colour: Black.
Dimensions:90cm x 70cm x 20cm
Drive: 4x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Locomotion: 6 externally mounted solid rubber wheels with aluminum boron carbide hubs.
Armour: 5mm titanium, except the front wedge which is 8mm titanium,
Speed: 25mph
Ground Clearance: 0mm at front, and 5mm at sides and back.
Turning Circle: 0m
Weapons: A powerful axe, with a 3kg meat tenderizer for an axehead. The tenderizer's blades are diamond tipped, and it can hit an opponent and do damage when the axe springs back to its rested position, like Terrorhurtz. The axe itself is powered by a 2.2kg 750psi Co2 tank feeding gas to a 90mm bore 400mm stroke ram which pushes the axe forward, giving near 600kgs of force.
Srimech: The axe self-rights the robot. If it gets stuck on its side, repeatedly firing the axe will cause it to land on its back or right way up.
Strengths: Powerful axe. Also very maneuverable.
Weaknesses: Exposed wheels and average armor.
Bio: The sequel to Tenderizer, the name was originally Tenderizer's Revenge, but Richard Southworth already has a robot named that. Son of Tenderizer is a modification of the old Hell's Teeth-shaped design. The axe is still there, tough.
Negativity (Active)
Weight: 100kg
Shape: Right out of Robot Wars: Arenas of Destruction. A Flat Disc.
Colour: Dark blue, with silver lightning bolts on the top.
Dimensions: 70cm x 70cm x 20cm
Drive: 4 24v S28-150 Magmotors, powered by 6x NiCad Battlepacks.
Locomotion: 4 solid Vulkanized rubber wheels.
Armour: 7mm titanium/vanadium alloy monocoque
Speed: 18mph
Ground Clearance: 5mm all around.
Turning Circle: 0m
Weapon: The weapon is a 100cm-in-length 15kg Hardox spinning bar that spins at 1300RPM, powered by two 36v LEM170 motors. The bar is spun up to full speed in 3 seconds, but will cause damage in 1 second. The blade is mounted on top of the robot.
Srimech: The spinning weapon will self-right the robot if it manages to flip itself via a reverse mauler dance performed numerous times by Tornado Mer and Killer Byte.
Strengths: Dangerous blade and tough armor.
Weaknesses: Not fast enough to chase most new robots.
Bio: This robot was designed after the retiring of my previous spinning blade robot Ninjoid Evo. The silver lightning bolts are a tribute to Team Lightning.
ARC Welder (Active)
Weight: 100kg
Shape: A reverse Kill-O-Amp(Triangular prism on its side) with rounded edges and a scoop at the front. The sides and sharp edges are rounded to cause spinners to bounce off me, rather then tear me up.
Colour: The bluish colour of a blowtorch's hot flame, with the name written on the sides in chrome.
Dimensions: 85cm x 75cm x 25cm
Drive: 2 24v S28-400 Magmotors, powered by 5x NiCad Battlepacks
Locomotion: 2 solid Vulkanized Rubber Wheels with Aluminum Boron Carbide hubs
Armour: 15mm Titanium/vanadium alloy monocoque. beneath that is 5mm of Vulkanized rubber to protect against impacts.
Speed: 15mph
Ground Clearance: 0mm at front due to scoop, and at sides and back due to 4mm titanium torsion-sprung skirts.5mm without skirts.
Turning Circle: 0m
Weapons: A solid 8mm thick Hardox scoop, designed to survive powerful spinners. This specific scoop weapon should be tough enough to kill Mass Disctruction Ultimate 4.1. The robot also has a massive amount of shockproofing to protect against impacts on the sides.
Srimech: Invertible
Strengths: Strong armor, tough scoop.
Weaknesses: Can't really do anything except hopefully survive, weak drive for the weight, average speed.
Bio: After my revision of the TJS-bot Counter failed, I decided to try once more to build a MDU-proof bot. ARC Welder was the result. The rounded edges should cause a spinner to bounce off, while the rubber and shockproofing should protect against shock damage.
Minesweeper 1.1 (Active)
Weight: 100kg
Shape: Tornado, basically an invertible box on wheels.
Colour: Gold on top and bottom, Silver on the sides, with MINESWEEPER written on the sides in red. The scoops are bronze.
Dimensions: 90cm x 85cm x 25cm
Drive: 4x 24v S28-400 Magmotors, powered by 8x A123 Battlepacks. I should get about an average of 18hp from all of them.
Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
Armour: 6mm Hardox monocoque, underneath that is 5mm of Vulkanized rubber to absorb impacts.
Speed: 20mph
Ground Clearance: 0mm at front and back due to scoops, and 5mm at sides.
Turning Circle: 0m
Weapon: 2 solid Hardox snowplow-like scoops that can move slightly vertically, like Behemoth's, so I get good pushing power, but 0mm ground clearance at front and back. The robot also has a bunch of shockproofing around the belts, electronics, and motors, due to the fact that it was originally designed as a spinner killer/rambot.
Srimech: Invertible
Strengths: Super-reliable and fast. Now more powerful.
Weaknesses: No real offensive weapon.
Bio: Minesweeper was overhauled with slightly lighter armour and lower speeds. However, it managed to regain its powerful pushing power via 4 Magmotors. The scoops remain, and the robot is still invertible. It's shape was slightly modified, but it's still ready to defeat opponents with good pushing power.
Spanikophobia (Active)
Weight: 100kg
Shape: Firestorm(A refined wedge with rounded sides and rear). The crusher is at the far rear of the robot.
Colour: Tan. The Crusher is silver, as usual.
Dimensions: 80cm x 60cm x 30cm
Drive: 2x 24v S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 2 solid Vulkanized rubber wheels.
Armour: 6mm Titanium/Vanadium alloy
Speed: 15mph
Ground Clearance: 0mm at front due to wedge, and at sides and back due to 4mm titanium skirts. 5mm without skirts.
Turning Circle: 0m
Weapon: A rather unusual crusher. Instead of the shape being sharp, the shape is flat, wide, and blunt, very much like the crusher of Leo Van Miert's Holepunch. Using a Vivoil pump powered by a 24v S28-400 Magmotor, it can come down with over 6 tonnes of force.
Srimech: The robot's shape causes it to roll onto the back/top of the crusher, which then retracts back and flips the robot right way up again.
Strengths: Tough armour. The crusher can help it dominate the match. Also very maneuverable.
Weaknesses: Slow self-righting and low top speeds.
Bio: Bubble Blaster was totally overhauled with a new shape. The only thing even remotely familiar is the differently shaped crusher.
Me Name is Death (Active)
Weight: 150kg
Shape: An unrefined wedge, similar to the Italian robot Mastiff.
Colour: The bare metal, plus ME NAME IS DEATH written on the wedge in red.
Dimensions: 110cm x 50cm x 50cm
Drive: 4x 36v LEM-130s, powered by 10x 36v A123 Battlepacks.
Locomotion: 4x Drillzilla-style shuffling pads, giving the robot a good top speed, and high pushing power.
Speed: 15mph
Ground Clearance: 0mm at front due to wedge, 0mm at sides and back due to skirts, 8mm without skirts.
Turning Circle: 0m
Weapon: A front-hinged flipper, powered by a 2kg Co2 tank at 350psi. Yes, this is a low-pressure flipper, but it can flip at least 200kg, enough to flip any competitor. It has about 25-30 flips, give or take the weight of the enemy.
Srimech: The flipper. it can't get stuck on its back or sides because the skirts will make the robot's flipper at least partially contact the floor.
Strengths: Fast, and uses the weight advantage of shufflers. Has good pushing power.
Weaknesses: The unrefined shape.
Bio: My first ever shuffler. The design is based upon the basic unrefined wedge shape, and incorporates a flipper to boot.
Any more problems?
As for the Torsion-springs with foam rods: The spring is coiled around the foam rod, so when the area where the spring is gets hit, the shock will be transferred to the foam. An example is Liam; he had Apocalypse II's torsion springs break numerous times in VRW3.
yeah well Mark... that tourney was written by Mark Elam so realism isn't really a factor... :lame:
oh wait... :rofl:
Not really. If a skirt is hit properly, then the impact transferred due to the spring might be able to break it.
And don't tell me you aren't happy about being in 3rd Place... :mrgreen:
The great Elven gods are displeased with this, your feeble offerings to the Shrine Of Describing Robot Shapes.
-MARK STOP
DESCRIBE YOUR BLOODY THINGS SHAPES STOP PLEASE STOP IT ISNT THAT DIFFICULT STOP IN WHICH CENTURY ARE YOU GOING TO GET IT THROUGH YOUR HEAD THAT PEOPLE MIGHT NOT HAVE SEEN THESE MACHINES YOU SPEAK OF STOP THEY MIGHT THINK THAT FIRESTORM REFERS TO A DIFFERENT ROBOT CALLED FIRESTORM STOP OR AN ACTUAL FIRESTORM STOP PLEASE PLEASE JUST DESCRIBE THE SHAPES STOP IT MAKES IT EASIER FOR US STOP
FROM JOEY STOP
PS: PLEASE PLEASE PLEASE STOP
Joey mate, that was awesome :rofl:
Hey Jamie! Good to see you again. Remember me? Liam's mini-tourney, you had Dr. Acula, beat me on a judge's decision, and I believe lost to Do or Die.
...thanks Jamie, I guess :proud:
Is it? Well happy birthday then.
Happy birthday, Elliot!!!
And now, the replacement for Minesweeper 1.1(Which was more of a freshening then an overhaul...)
Sweep Mines, or Die!!!
Weight: 150kg
Shape: A basic invertible box on wheels with scoops at the front and rear, however the sides are slightly rounded.
Colour: Dark Grey, with SWEEP MINES, OR DIE!!! written on both sides in what I call Blowtorch Flame Blue.
Dimensions: 90cm x 60cm x 20cm
Drive: 2 72v Perm 132 motors, powered by 9x NiCad Battlepacks.
Locomotion: 2 Drillzilla-style shuffling fleet running through both the top and bottom of the robot, making it invertible.
Armour: 5mm Hardox, with 10mm of rubber underneath for shockproofing.
Speed: 15mph
Ground Clearance: 0mm at front and back due to scoops, 5mm at sides.
Turning Circle: 0m
Srimech: Invertible
Strengths: Shuffler, uses weight advantage, ENORMOUS pushing power, tough armor.
Weaknesses: No active weapon...
Bio: The previous incarnation was nothing more then a freshening. After looking at Chezza's Do or Die, I realized that, well... my pushing power actually sucked. Therefore, I went overkill and decided to use Perm 132 motors to power shuffling feet: a dangerously powerful combination.
