Although, if I didnt, I would have the fastest ever track robot.
(Message edited by corsair_lightning on March 31, 2008)
Yes, but it would be next to impossible to turn it at any speed.
If there is a sprint competition, I will use the 4 TWM3Rs.
you would only be driving in a straight line or turn on the spot, and eat amps in any attempt to turn. Aiming to line up is right out the door, your robot would be worse to drive than InTriVerter.
Fu-Ma Ninjabot
Shape: Hazard with skirts on the sides and back.
Weight: 100kg (Wheeled)
Colour: Red
Dimensions: 100cm x 78cm x 17cm
Speed: 25mph
Turning Circle: 0mm
Ground Clearance: 0mm all around, but 5mm at sides and back if there are no skirts.
Movement: 2 Vulkalon wheels at the back.
Armour: 6mm titanium
Power: 2 TWM3R Team Whyachi gearboxes connected to 2 S28-400 Magmotors, powered by 7 NiCad packs.
Weapon: A 3m titanium sharpened blade powered by a Tornado Mer weapon gearbox. It spins at 5000rpm.
Srimech: none, since the weapon is long and low so no robot can get under without suffering major damage.
Notes: Updated bot from Team ZlayerZ RPG: Identity Theft.
OK, we KNOW youre incapable of coming up with a sensible robot design. So now youve resorted to stealing OTHER peoples designs?
YOU STAY AWAY FROM ORKA AND DIE-CERATOPS!
Seriously, youre not trying.
Kody never finished full stats for this bot, so I finished it for him.
I would never take the stats of those 2 bots.
Im serious.
this is an RPG-robot, they dont need full stats, neither do house robots IMO
still, its KODYS RPG-bot!
Why did you decide to improve other peoples designs without asking their permission?
Its got to the point where Im running out of patience here, weve tried to help you and you dont seem to be taking any of our advice.
sorry a 3 meter spinning bar? are u taking the mick?
a) 3 meter is too big, its outside the size limits for robot wars and FRA
b) that will never get upto speed
