have you got a link to these ESCs?Quote:
Originally Posted by mr_turbulence
Cheers
Cheers
Are you going for a Snail Drum design Dave?
Unibody, single tooth drum? Looks like a snail from the side, hence name.
Would the 25A botbitz controller be enough for a gimson motor? What if it ran off 24v?
A 25a ESC for a single Gimson should be fine, but that particular ESC is rated to just 4s, or around 14-15v. I doubt it would much like 24v.Quote:
Originally Posted by Max
well those tz85 hacked esc look very interesting
I'm thinking of using speed 900 but in a 4 wheel drive config (driving each side with one motor through chains with a gear reduction)
Works in my mind but alot of moving parts so to speak :lol:
Do you think the hacked tz85 would be up to 900's under load ?
Also , out of interest, what size wheels and gearbox ratio will you be running?
Depends on a number of things, mainly voltage, but if you're being sensible and follow the specs they're giving you I would say it would.
Just look through the Australian forum and check out what they're running off these escs peeps
PJ- nope, 2 tooth drum machined from a billet with bolt on teeth.
Drums being machined by Kenny soonish hopefully.
Drum machined...weighs just over 3kg, will be going around 15000rpm.... just need to machine some bulkheads out of some alumec next....that takes effort though.
http://i685.photobucket.com/albums/v...s/33f6bf24.jpg
http://i685.photobucket.com/albums/v...s/14fd4a7c.jpg
