A slightly shorter length Wolf-E? Shedding 4cm in length and moving internals back a bit.
https://68.media.tumblr.com/1812f302...f23o1_1280.png
https://68.media.tumblr.com/c2647598...f23o2_1280.png
So after a late night and lots of maths I've got the current calculated weight of Wolf-E.
The weight is looking to be about 8.8kg leaving 4.8kg to play with. Currently its size will be 25.5cm x 38cm x 10cm.
The previous weight and size was 9.8kg with 3.8kg spare. The size was 29.5cm x 38cm x 10cm.
And a stand alone render
https://68.media.tumblr.com/e70e8e9a...o3_r1_1280.png
Ok time for another question, so as you may have seen Wolf-E's wedge isn't flush with the ground as the side panels are. And was wondering the possibility of making the wedge flush by making the panel long and angle grinding the excess off, like in this picture:
Attachment 6961
I'll have to add a bevel to the wedge to stop it snagging the edges of arena floor panels anyway but I though I ask people more experienced with Hardox.
Make the panel too long and grind off till flush.
I can't do cad so i just do it all by eye lol
Get yourself a solid back door step, works for dave! :proud:
because that's what he does all his engineering on :rofl: Although, he's built more successful robots than me to be fair
6 Renders of Wolf-E showing off the new panel parts to hold the side panels.
https://68.media.tumblr.com/f8c332fe...f23o1_1280.png
https://68.media.tumblr.com/1e902042...f23o2_1280.png
https://68.media.tumblr.com/1f6389e9...f23o3_1280.png
https://68.media.tumblr.com/f360ac55...f23o4_1280.png
https://68.media.tumblr.com/cf5bc446...f23o5_1280.png
https://68.media.tumblr.com/34d619ff...f23o6_1280.png
Are you going to Insomnia? Best get building soon if so!
Small update finally worked out the mounting for the removable link and how the mount fits and is attached to the bot.
https://68.media.tumblr.com/d26d0de4...f23o1_1280.png
https://68.media.tumblr.com/d7520c31...f23o2_1280.png
That looks like my first plan for my removable link. I would have a big hole and was even going to finish the edges so they were nice and neat and looked awesome.
After reading other peoples experiences with removable links they do seem to be a weak point of any bot so tucking it where it couldn't be bashed seemed advisable. Spinners in particular would put it at risk.
Having a pull cable (none live) meant it could be put a bit more out of harms way but kept accessible.
Panels laid out, it could be ready to export as a DXF and time to get a quote from K-cut.
https://68.media.tumblr.com/158ad0b5...f23o1_1280.png
So as the issue has been raised, is there any suggestions on where to place the removable link and how to better protect it? Cause where I placed it in the CAD I though was ok cause it gives easy access for removal.
I think it works where it is but I would add potentially add a raised profile around the edge, so it has a tunnel around it leading to the link (doesn't have to be very tall, just thick I would think to be of benefit). That would help protect it I think.Quote:
To do it you can just get another piece of hardox cut and bolt it on over the existing stuff. It would give that area much more strength, however would a raised profile not just give something for spinners to bite on?
Depends on how big the raised profile is and how thick the raise is. I don't think it'll provide that big a biting point for spinners to hit and if it does hit, without the raise, it could mean the difference between the link staying in and being ripped out.Quote:
The link looks fine where it is. A couple of options to try and prevent it popping out include putting a small hinged cover over the hole that you can swivel down once the link is in place, or even just covering the hole with a piece of duct tape. If you make the loop of wire on the link end out of stiffer wire or a long loop, you can also use that to push against the chassis somewhere inside so that it can't physically pop out.
In all honesty, links popping out in smaller weightclass bots are few and far between. It seemed bad in RW Series 1/8 but people weren't as familiar with the shock forces going through heavyeweights then as it had been a decade since HW spinners last competed, so link mounting methods weren't perhaps as robust or well thought out as they could have been.
Ok thanks for the suggestions guys, I'll look at adding a cover to the hole it looks to be the most straight forward.
Could someone who has used DXF files before for getting parts cut tell me how I'm messing up the orientation of the parts.
I'm told this orientation is the top profile and need the front.
https://68.media.tumblr.com/23e935a6...f23o2_1280.png
But when I orientate it to what I think is the front the profile is still wrong.
https://68.media.tumblr.com/40fa3ec1...f23o1_1280.png
So what the hell am I doing wrong?
Not much help but I output my dxf through emachine shop. 1 file per part
Always worked fine with kcut
is there a way to specify plane when creating the dxf? our Maya specialist at work is away today so cant ask him.
although looking, export dxf from maya is not possible in 2017 but 2018 is. unless uyou have a plugin. perhaps there is a setting within the plugin to orientate output plane?
https://forums.autodesk.com/t5/maya-...f/td-p/6717359
I don't think so, plus I'm using 2015
So it appears that I can't export the DXF with a specific plane selected. RIP me
Can you export it as a step file? Then you can use another program to do the drawing.
I'll have a look.
doesn't have the file format.
I guess your only options are: find a format that can be opened in a CAD program that can generate the DXF files you need, or redraw the parts in a CAD program, using measurements from your original drawings.
Damn, I'm going to need a new CAD software then.
I wouldn't recommend using Maya for CAD anyway, its an animation and modelling package rather than engineering, I recommend trying Inventor or Fusion360
I'll see what I can do but it's looking like I'm not going to get anymore progress.
My experience with Maya (working in animation studio) you should be able to export a file and use some software to change it.
If you want to, send me the maya project file and i can try and export it to something useful.
Send me an email - npoate (hat) hot mail (dotty) com send it via weTransfer and i can take a look
Nat
thanks for the offer Nat but someone has already PMed me about helping me convert the file. I'll email you should I still need help.
no probs :)
