Just the one buffer tank should be fine.
Ok,Mario said i should have two,otherwise I would only get about 20 hits.
Thanks Woody.
The quantity of liquid co2 in your main tank dictates the number of available shots.
I said that the volume of the Buffertank should be 3 times the volume of the ram, or more.
Less, and youll use up more weight for less advantage.
My take on a buffer tank volume....
Twice the rams volume is acceptable ...three times the rams volume is good.... but anything is better than nothing.
Powder extinguisher bottles etc make light l.p. buffer tanks just check the pressure rating before using.
Ok,I think to start I will have only one 12oz buffer,and a 12oz main.
Is that good?Or should I have a bigger main?
12oz liquid co2 = approx 18 litres of gas @ 10bar.
A 12oz tank has a volume of around 0.5 litre.
Is it enough ....dunno.
Your ram volume is?
Im not sure what my ram volume is.
I havnt got it yet.
80 x 80 ram = 400cc
Ok,so what kind of thickness on my axe head would i need to stand up to the power?
What material do you think would be best?
Thanks.
