Do you have a list of the realies already taken?
When With Or Without You was being designed, me and Martijn talked quite a lot about the rules regarding when it would be out or not. Obviously the 50% rule should clearly be used - but from there it is down to the writer to judge what 50% out means. There are a number of scenarios that could happen from the bar hitting an opponent, and Ill give my views on them:
1) The bar strikes but neither is knocked out and the fight continues as normal
2) The bar strikes, the opponent is knocked out and the cluster survives - the cluster wins
3) The bar strikes, the opponent survives and the cluster is knocked out - the opponent wins
4) The bar strikes, and both are knocked out, which is where it becomes a little tricky...
As the opponent is 100% out it is eliminated, and as the cluster is 50% out it is also eliminated. My suggestion here would be to judge the fight up until the bar made contact, and the winner is based on that.
Reallies:
1 Splinter
Axe and pincer robot.
http://www.bugs.nl/media/album/view.php?&path=L3J3L2JvZWtlbG8yMDA0L25sLWthbG0vRFN DTjAxNzcuSlBHhttp://www.bugs.nl/media/album/view....L25sLWthbG0vRF NDTjAxNzcuSlBH
2 Hannibal
FP flipper, A supersized Chaos 2
http://www.bugs.nl/media/album/view.php?&path=L3J3L3V0cmVjaHQyMDA1L2RlLWZsYXRsaW5 lci9mbGF0LXV0cmVjaHQwNS02Mi5KUEc=http://www.bugs.nl/media/album/view....L2RlLWZsYXRsaW 5lci9mbGF0LXV0cmVjaHQwNS02Mi5KUEc=
3 Obsidian
Axe robot.
http://www.computerclub.nl/uploads/obsidian/obsidian12.jpghttp://www.computerclub.nl/uploads/o...obsidian12.jpg
4 Mantis
Crusher and lifter.
http://www.computerclub.nl/uploads/mantis.jpghttp://www.computerclub.nl/uploads/mantis.jpg
5 RCC2
Horizontal crusher, Linear actuator powered, 2 tonnes.
http://www.computerclub.nl/uploads/rcc2.jpghttp://www.computerclub.nl/uploads/rcc2.jpg
6 Blackdevil Warzone
Vertical Drum spinner.
Cant find a picture at the moment. It competed in 2001.
Vapours:
7: Eternia
Weight: 98 kg
Speed: 18 Km/hour
Lenghth/with/height: 120 cm/65cm/35cm
GC: 5mm on the sides, 10 mm on the back and front so it wont run aground on a toothpick sticking out the floor. the flipperarm is pushed flush to the floor with bungee lifting the frontend.
Drive: 2x3 Graupner speed 900 BB torque @ 24V Geared down 20:1 on 15cm wheels.
Weapon: 100mm bore x100mm (4 tons) stroke ram Gravity style flipper with 2 1/2 bsp burkert inlets and a 3mm hole as outlet. A 2 compartment aluminium buffer of 4 Liters being fed by 2 2kg CO2 bottles. The arm levers it down 3:1 giving 1300kg of force at the tip of the arm.
Chassis: Main frame holding the ram and flipperarm is 40x40x4 mm welded box section, the baseplate is 4mm 7075 aluminum and the armour on the sides and top is 40mm HDPE. The flipperscoop is hardox 450 6 mm, the arm itself 40x40x4 box section.
Batteries: 60 GP3700 NiMh cells, 20S3P, giving 11.1Ah@24V. weight of the pack is 4 kg.
Special Notes: All black, with red markings at the sides.
8: GBOD
(Giant Bell Of Death)
Full body spinner
Weight: 99kg
Speed: 10 km/hour
Diameter: 75cm
Height: 45 cm highest point, outer ring 25 cm
Ground clearance: 10 mm all round
Drive: 2x Bosch GPA 750 on 36V with 15cm wheels
Weapon: Full body spinner, outer ring is 6 mm Hardox 450 with 2 Hardox 450 teeth welded in, one if which angled downwards and one straigth out, like Typhoon 2, it spins a maximum of 2000 rpm.
Top is 3.2 mm Hardox with 4 holes cut out to reduce weight.
The disk is powered By a Plettenberg Predator Brushless motor with Jeti Spin 200 ESC at 36V.
http://www.youtube.com/watch?v=gzCDxed4blUhttp://www.youtube.com/watch?v=gzCDxed4blU
I really like that rendering of GBOD, Leo. :)
Really, REALLY good robots Leo, but there are 2 too many realies in your line-up. Apart from that, EXTREMELY good line-up. But get rid of 2+ realies.
Another thing - what shape is Eternia?
Paul, did you know that two of those realies were MADE by Leo? :wink: (Splinter, Hannibal)
You really should let him enter them as 2 more places for vapourbots; even though they are not vapourbots they still belong to him.
(Message edited by kodster on January 11, 2008)
Actually, Kody has a great point - people who have actually build robots are allowed to enter them along with the 2-4 realies.
Leo, I will allow you to keep them!
So the entrants list:
1- TJS
a. Tornado
b. Gravity
c. Wheely Big Cheese
d. Terrorhurtz
e. Killer
f. Counter
g. D-J
h. Bere-y Interesting
2- Chris Mason
a. Orka MK4
b. Die-Ceratops ReInvertus
c. Cyclone Force 2.5
d. Leprosy Infection
e. Mega Masher 2
f. Disc-O-Inferno
g. Iron Awe 2.1
h. Obliteration
3- Martijn Benschop
a. Storm 2
b. Big Nipper
c. With Or Without You
d. ???
e. ???
f. ???
g. ???
h. ???
4- Alex Holt
a. Black Panther Queen
b. Achilles
c. Tengu VII
d. Bodyhammer
e. Recyclops
f. Kali
g. Dante
h. Ramthrax 2
5- Kody Kunz
a. Avarice
b. Wedginator 6.0
c. Seung Mina III
d. Super Gore Evo
e. The Zenith
f. Aftershock
g. Turbulence
h. Tornado Mer
6- Steven McGregor
a. Wedge Devolution
b. Killotine: EVO
c. Metal Sonic Spin Dash
d. Whirligig 4.0
e. Clawdius Decimus Murderous
f. Turbo Tails
g. Chaos 2
h. Pussycat
7- AJ
a. Megabyte
b. Razer
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
8- Martyn
a. Dantomkia
b. Fluffy
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
9- Will Harrison
a. 259
b. Voltronic
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
10- Leo Van Miret
a. Splinter
b. Hannibal
c. Obsidian
d. Mantis
e. RCC2
f. Blackdevil Warsone
g. Eternia
h. GBOD
11- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
12- ???
a. ???
b. ???
c. ???
d. ???
e. ???
f. ???
g. ???
h. ???
Those with ??? still in our reserved. I still need stats from Kody and robots from Martijn, Martyn and AJ.
Thanks everyone, and there are massive spaces left! Sign in and fill em up! :proud:
Ill enter the Infusion family....
Motivation: 4 x 125mm wheels
Speed: 0-12MPH [25MPH under Kinetic Boost]
Clearance: 7.5mm (same inverted) 0mm at the front, the wedge scraps the floor.
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Weapon: The weapon is a 28kg Hardox spinning ring (Ala MDU) powered by a LEM170 @ 36v. The rim rotates at 2000rpm and should spin up within 2 seconds max. The weapon is also a storage device for the drive. The spinning rim is connected to each side of the drive via a car air conditioner clutch, when the clutches are engaged, the 31kg kinetic storage bank(the spinning rim) transfers its energy into the drive train, giving it approximately double torque and speed for 2-3 seconds until the rim starts too loose speed and energy. This extra €˜kinetic€™ boost is used to ram into opponents with the front 10mm thick Hardox 500 wedge (similar to the one on Warrior SKF but wider and less depth to it). The front wedge is rubber shock mounted to ensure it survives the biggest of hits.
Drive: 2 x C40-500 Magmotors on 36v geared 7.5:1. The drive is also assisted via the spinning rim as explain above.
Batteries: 110 x 2300mAh A123 LiNP Cells made into 36v packs. Produces 36v @ 23.0 Amp/Hours
Armour: Front wedge is made entirely out of 8mm Hardox 500, the top and bottom of the robot is made out of 8mm Titanium/Vandium, The ring is made out of 10mm Hardox 400 with inner bracing to the perimeter bearing. Inner bulk heads are made from 20mm polycarbonate and 10mm aluminium.
Notes: Invertible, speed when needed and generally well controlled for a spinner. Ram or Spin, Infusion aims to win!
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Weight: 100kg
Height: 125mm
Length: 800mm
Width: 600mm
Hmm...Infusion looks like it could win...no wait! Infusion would surely outperform Infusion! ah, but Infusion has the upper hand more than Infusion does...
Hmm, tough choice. May as well go for Infusion. :proud:
Infusion FTW!
