My crusher.
My crusher.
Exqueeze me? How does one lift with a crusher? Magic?
and where did this crusher suddenly come from for that matter?
quote:
Position:Defence midfielder
Weight:99kgs
Dimensions:2X1X2
Weapons:A bi-rotational axe which spins upward and it has safety cameras to protect the opposition and my own team
Speed:21MPH
Drive: 4 S28-400 Magmotors at 36V.
Armour:Titanium
Transmission:Chains
Additionals:Boots on the axe
no really... where?
Hades Machine
Weight: 100kg
Dimensions: 140x100x60 cm
Weapons: Lemco motor powered axe (run through gear box) that can deliver an axe blow of 3 tons (according to my calculations) and rear linier actuator operated lifting arm that can flip 600kg
Srimech: Side arms and rear arm
Speed: 15mph
Transmission: a 4 wheeled Tornado set up(36v and same gearing), but with a pair of Mag C40€™s in place of the Bosch motors, and a set of NiMh in place of the heavy Lead Acids the real thing uses.
Turning Circle: 0m
Ground clearance: 0 at the scoop and wedge edge, 2mm the rest of the way around
Wheel Type: Go-kart
Body Shape: scoop fronted, wedged back
Armour: 8mm Grade 5 Titanium and 2mm stainless steel
Colour: Black with flame face on scoop and name in blood writing on side, devil head on rear wedge
Strengths: Enormous pushing power (About 12hp), EXTREMELY powerful axe, relentless in attacking (until a robot is immobile)
Weakness: Dislikes spinners, doesnt like weapons that use carbon
Dimensions: 120cm x 80cm x 40cm
Weight: 100kg
Shape: steep wedge front, elongated wedged tail (not used as a weapon)
Weapon: 1000psi 2 pivot pneumatic flipper that can generate enough momentum and force to throw a 100kg robot 25ft up and 20ft across
Top speed: 18mph
Transmission: just like Razer€™s
GC: 0 at the front, 2mm down the side, 4mm at the back end
Turning Circle: 0cm
Armour: 6mm aluminium and steel alloy
Strengths: Can win with one weapon shot
Weakness: None
Notes: 4 wheels, the rear two of which are Razer type, so the flipper is always facing its opponent
In case youre wondering, the forum wont lt me put H-word on here
I wonder why it wont yet you post the oposite of heaven?
Yes, what the [-]311?
http://www.fightingrobots.co.uk/discus/messages/8/5234.html?1142087941http://www.fightingrobots.co.uk/disc...html?114208794 1
here ya go, some words have been censorised...
when posting my strategies against I.D.S.F.A, I couldnt even write I.D.S.F.A apostrophe s, cause it would include the a-word
a serious downfall for team Hades it seems
(Message edited by MajinB on March 12, 2006)
Either change the name to Team Hades or change it to team [-]311? All I got.
Martijn, youve got Etek motors, a hydraulic lifting system, and 6 mm Ti armour... Somehow I dont think theres enough spare weight to make a blade capable of damaging much of antyhing :p
And by the way. This new profanity filter extracts the urine.
Cool. Ive been feeling like taking a p- I mean, urine extractionation or something like that..
