Spinner Weapon Motor Discussion
Looks like a bog standard 850 sized motor to me. the 850 isnt twice the size of a mini EV though, it has virtually an identicle casing. They run ok at 12v, but Ive also tried at 18v - it smelt pretty bad then.
Go for an HTI or similar (24v drill motor perhaps?) if you have the space to gear about 4 or 5 to 1 (will get better torque/speed to weight ratio then), otherwise a lower revving motor like a gold/fan motor as James suggested would be good.
The Johnson i mention was about twice the size of a normal drill motor , and it even says 24V on the side or it , It is my luck that i have 2 24v drill motors that came from hammer drills that could be useful .
woud this be a good spinner motor?? http://img206.imageshack.us/my.php?image=dsc017714ul.jpghttp://img206.imageshack.us/my.php?i...sc017714ul.jpg
its a 12v bosh motor from a car fan,
yeah car fan motors are usually quite good.
Alister, what happened to the pancake motor I sold you?
How many HTI motors do you guys burn out? We have 6 dead ones here.
I think you are better off going with mini-EVs. The are cheaper and when run off 14.4 volt they go just as well as a HTI. With the added bonus the you only need 14.4V worth of batteries which will save weight over 24V.
2 mini-EVs made Prancing Queen a damn scary robot. And the one in Vertical Limits is also impressive. They deffently have a much better combat record here then the HTIs.
Gary , sold it to James Baker , didnt fit into my new design
As of now none. We run the HTIs from a astroflight speed controller. We have took readings of the voltage the motor pulls at different stick positions. We run it at 12v for most apponents but give it full stick for the robots with Ti or Hardox Armour. And up to now we have not burned a motor out.
yeah gary, i bought the pancake from alistair so that with the 3 you sent me id have 4, shame eh? thanks to parcelforce ill be stuck with just 1, unless they loose that one too... sent it yet alistair?
James, did you not get my email about your neighbour?
yep, did you gt my reply?
they are trying to fob you off.
no house on my estate has a name, they are all numbered.
if they had left it with a neighbour there is a box on the delivery note to say so, never got one.
the motors had no address on them, so how were they delivered without the hardox? if sent specially they would have told us, or taken them to the po i picked the hardox up from.
and finally, if the neighbour has it, they do not need to pay up on the insurance.... thats why they are saying it. ask for the address off the neighbour, ask for a signiture, and ask for the time and date of this supposed delivery.
my neighbours know all about my robot stuff deliveries, and would have told me if they had anything, they always do.
they are trying to pull a fast one.
