Whats the difference between the battlekits and the Zeobots?
I am more familiar with the speed controllers with the little arm on it. How would I wire the battery and the motors to the electronic speed controller?
Is it just me, but is Ampflow and Robotec the same?
Mr Stu
The Ampflow is the Roboteqs big brother - capable of 160amps rather than 120amps of the standard Roboteq.
Ed
hmmmm those battle kits look nice but i think they are a bit pricy and just a bit too powerful (for the UK anyways :))
the main differences between the two kits are the motors used etc.
The battlekits use much more powerful motors and speed controllers although this is not necessarily good as repairs are therefore more expensive.
Although I am sure you said that you are based on the other side of the pond Kevin so therefore it may be easier to get hold of the battlekits.
The connections are usually made with crimp connectors or something similar.
I could buy the Zeobot if I wanted to. I will I will. But not the flipper Zeobot, just the chassis.
Paul doesnt sell outside of the UK anymore.
Oh well then.......
kevin if you really wanted one of the zeobots then i am sure that you could find someone willing to send it out to you.
