The Legends Tournament
First Ill start off as fast as possible so I dont get caught in the speed bumps. Then Ill line up and go through the gates as soon as possible. And finally when comming round the corner Ill line up with the ramp and carefully, but quickly go over the top, go round the corner and finish. Ive got decent speed and great manouverability so there shouldnt be any problems driving through to each area. Once at the areas I should be able to pass them all easily, the hardest should be the ramp but the traction should help get me over no problem.
Please say if you want to remove any skirts/weapons/wedges for this round and any other info (ie go in backwards/upside down) and if you want to avoid any the areas taking the time instead (ie low wedge with low power + ramp, 2 wheel drive and road-bumps).
And Andy has removed his drum
Well, thats a joke. Im asleep, and all six are filled. How the hell am I meant to enter if I cant because Im in a different timezone?!?
^^^ *Puts up sign~ Tom Roper ~ Professional Whinger* ^^^
Thats the main problem with limited entry events, whatever time you put them up, at least some people will be in bed, either Aussie Land, Uk or america.
Tom look at the mentorn thingy 2005 it filled up in just over 2 hours (bl00dy school.
For this i will run invirted to help with getting over the ramp, i will hopfuly get throguh quickly the only trouble point i c is the 3 point turn
Martyn, I missed out on that too. Dont have a go at me, I didnt make it into that either.
And Matty, my point was, why have it like this because although I took maximum points from the first round, Ive got near zero chance of winning overall because of the fact that Ill probably only make 2 of the events.
Thats where your wrong Tom...
...not giving anything away, but everybody in the league table will have something done to make it all fair.
In that case, I could not enter again and win on handicap seeing as I would have taken maximum points from all 1 events I entered in. :rofl:
Damn, I forgot about you and your factor.
Besides the last two have 8 places each and so I will open up signups for half in the morning and the other half in the afternoon, so that you and aaron can get in early, and the people from Arc can enter in the afternoon.
