Antweight Database
Speed: No idea what so ever
Power: 11,1V 300mAh (12 att fully charged)
Drive: Graupner C141
Weapon: FBS (Full Body Spinner)
Amour: Aluminium and 3mm lexan
Status: Building. Hope to get it ready for AWS20
Note: It is a walker and weights just over 120g!
http://i3.photobucket.com/albums/y89...efinished2.jpg
Antweight Database
Speed: unknown
Power: 4.8v Ni-MH
Drive: 2 x GWS Pico servos
Weapons: axe
Armour: Moulded plastic (Tornado pullback chassis)
Status: building
Name: F.I.N (Four Inch Nails)
Speed: Unknown
Power: 4.8v Ni-MH
Drive: Naro HP/BB servos, speed hacked
Weapon: side-swiping double ended nails (FBS in effect)
Armour: 0.5mm - 2mm lexan (I think)
Status: Building
Antweight Database
Speed: fast
Power: 7.4 lipo
Drive: 2x sanyo 50:1 motrs with 2 scorpion minis
Weapons: ploughy wedgy thing
Armour: 3mm carbon finre and some o.5mm titanium
Status: finay
Speed: fast
Power: 7.4v lipo
Drive: 2 x JR s136l servos speedhacked and with a sozbots board for more control
Weapons: carbon fibre front plate
Armour: 1mm poly carb and 3mm carbon fibre
Antweight Database
Re Update of Anto XP1HP
Name:- Anto XP1HP
Speed:- 11.3m/s
Drive:- 2x modified Brushless Outrunner motors
Weapon:- shear speed, spin on the spot, electric tale to tilt front into the floor.
Armour:- 1mm titanium 4mm polycarb and 0.5mm spring steel
Status:- awaiting new Rx and will be finished
Antweight Database
Wow. Sounds real impressive! I miss seeing so much of the old robot wars stuff and antweights and whatever else. I must get more involved in it all again!
Antweight Database
Hi Guys. Well, for those who attended AWS 19, both my robots were built, but F.I.N and Baby Hell have undergone rebuilds:
F.I.N: shorter, allowing the thick armour to go right over, also allowing weight for side armour, switch has been taken out to allow more weight where required, and all the batteris now on top of the servos and under the receiver, and heavier nails, providing a more substantial flywheel effect.
Baby Hell: Everything is inside the robot now ! lol. I took off the problematic wheel guards and have 2mm polycarbonate offset from them, so no more rubbing. Plus, the axe has had its position changed, so it has a longer swing, may well change the head back to a screw, as the spike doesnt appear to do much
Antweight Database
Well, Ive been doing ants for years now, so its about time I posted here.
Speed: 1.5m/s
Power: 7.4v 360mah Li-po
Drive: GWS Park (speed hacked)
Weapon: Flipper, powered by GWS HPF X servo.
Amour: 1mm polycarbonate & carbon fiber.
Status: Active. Some slight mods needed for the next event.
Speed: 0.8m/s
Power: 7.4v 140mah Li-po
Drive: 4 x 220 rpm motors
Weapon: None - pusher
Amour: None!
Status: About to be retired to make way for something more ambitious.
Speed: 1 m/s
Drive: Naro Max servo (speed hacked)
Weapon: 75mm diameter titanium disc spinning at 18,000 rpm
Weapon Motor: AirPower 300DF Brushless
Amour: 0.7mm Carbon Fiber.
Status: Active. Some new servos for the next event.
Name: The Nightmare of Milky Joe
Speed: 0.3m/s (Walker)
Power: 11.1v 360mah Li-po
Weapon: 85mm diameter cutting disc spinning at 25,000 rpm
Amour: 2mm polycarb.
Status: Being rebuilt so its more reliable.
Pictures in profile.
(Message edited by Duff on May 09, 2006)
Antweight Database
Ive built way too many ants to post em all up. But people can see all mine by going to http://www.buildersdb.comwww.buildersdb.com and searching team name Die Gracefully Robotics if theyre interested.
Antweight Database
Jesus! Dave? 44 results returned?!
Antweight Database
Yup, sounds about right. lol. Cept one of them is the feather of course. :wink:
