It all works fine until one of the ESCs browns out. And if you happen to be using very low inductance motors, like I am, this can happen even at very low PWM duty cycle. If the motors are stalled even at low throttle this can cause the input voltage to drop very low and the ESC to reset. As there is communication between the two paired ESCs to ensure they are synced and running properly this means that if they don't reset at exactly the same time or if one powers back up first they can enter a situation where there is shoot through in the ESC causing it to blow up.
Ain't the browning out of the control circuits solvable with a seperate powersource for those?
