Its not just the 30 seconds thing, its the slim odds of Take Me Out landing in a position to be able to self right back in... Twice.
As much as I hate (or have hated) the guy for everything he did to me, I have to back Matt up here...It just doesnt seem correct.
quote:
In the midnight hour, the almighty fallen will rise once more to take back all that he had lost
Heat L Final, Part 2
Take Me Out vs. Behemoth (27)
Due to a rethink and lots of complaints made by the general council of vapourbottering, I have decided to go against the original fight and do a rewrite.
3
2
1
Activate
Both robots are off the line, as Matt is looking to make his first semi-finalist, after being flipped out of the arena in part 1, as Take Me Out comes around. The more controlled Behemoth slams straight into the front wedge of Take Me out, and lifts it off the ground, lifting the front wheels off the ground by lifting up the scoop.
Matt pushes Take Me Out backwards, the wheels spinning on the arena surface to get grip, but the axe comes down, pinning Take me out on the front scoop of the 27th seed. The pit release has been opened, as Matt doesn€™t want to make the same mistake and flip Take Me Out over the wall, he wants to end the fight as soon as he can, as Behemoth hurries across the arena, lifting up the scoop.
Martyn can not do a potato as he is pushed backwards, the flipper fires, but all it does is rise the front end up a bit higher, as Take Me Out drops down 6 feet on it€™s rear end, and falls down on it€™s 4 wheels. Behemoth spins around; Matt is smiling, as he knows he has caused more chaos and creation in the back garden, which by the way is a great album.
Cease
Behemoth wins over Take Me Out via TKO in 0:47
Behemoth now faces Achilles in round 4
I could of geused i would lose that fight, but whatever i probly didnt deserve to win the first fight but whatever
Thank you Dave, you did the right thing.
Behemoths tactics:
Against Achilles, Ill have to avoid the front, and focus my attacks on the side, flipping it with the scoop and pushing it around, and make sure that it cant get away to try an attack, get it down the pit with the first chance possible.
Im basically a mroe finessful and nimble version of behemoth, so Im not too worried, Ill use pnuematics and get round the side and ram and flip. Im also lower to the ground which is good.
Double post Alex.
Repeated (the orginal has gone into the archives) Message to Chris M:
Ram-Raider is 6kg over the Featherweight Walker Limit (24 kg) whereas RR is 30 kg. Please can you swap robots with either another FW (CFL or Realie) or Ram-Raider will be kicked out.
You have till tomorrow to decide
OK, THIS ISNT FAIR! You warn everyone (EVERYONE) else about weight problems AT LEAST a month before the fight. Why warn me the day BEFORE the fight? Why do I have to be the outcast in EVERYTHING?!
And I cant kick Ram-Raider out because its the only featherweight Ive got. And most of the good ones have been taken.
The only thing I can do is do what Team Razer did, and start drilling those holes.
