I just need to make sure I fine-tune mine to help stay in the mix, but I'm liking the increasing number of drumbots 8)
Why not make a single toothed drum, i don't think there's been one of those before.
with good reason
Yeah i am going for toothless on the drum... being a bit of a pain to draw in cad as im not entirely sure what diamater to have that part on the drum.... im guessing ill work out the PCD as if i was using normal pulleys but turn the one on the drum to the PCD of the larger pulley.... if that makes sense.... trying to do it so i dont need a tensioner.
i think drums could do really well in the future if done right- they do in america... only problem is NST and LS4... building something to take the horizontal impacts is a challenge... thats why the front end has a billet of ali either side wraped in hardox, and all the chassis will be 20mm alumec 89... beefy :)
Yes, it would be deemed to cool to compete 8) .Quote:
Originally Posted by harry hills
Too right! The ali billets will be a good help, but the difficult bit to protect against will be the drum itself. That's what happened in my play-off with Savage Evo back in 2009. I had 16mm of HDPE and 20mm Nylon as my front supports which could cope with anything, but Savage got a hit on the tooth of the drum and pulled it out its mounts.Quote:
Originally Posted by mr_turbulence
I'll probably look at Drumroll and see if there's any way to fit some sort of deflective armour on the front (shaped like the front of a boat, so that horizontal blades deflect down into the arena floor, an idea implemented by one of the Aussie builders) but it's trying to get the right trade-off between not having your drum sticking out too far that it gets hit, and not having it too recessed that it's struggling to hit anything. But I think horizontals in general tend to have the upper hand against verticals.
What material are you planning on using for the radius bits at the back corners, and all round armour for that matter?
EDIT: Scratch that, read your last post and saw Hardox mentioned.
yeah, i shouldnt have that problem as there shouldnt be much flex in the chassis compared to urse...
not going to have too much drum sticking out so there wont be much side purchase... and its going to be on angular thrust bearings to take some of the side load out... so hopefully that'll help..
The side armour is 3.2 hardox im going to TRY to bend out of 2 pieces- 1 per side... if ed lets me pop in and use his hydraulic press at some point.... i wanted something with a bit of flex around the wheels.
...think were going to have break dancing competitions when its finnished jamie :P
We should just spend the full three minutes of a battle doing that. Wonder how the judges would score that one :rofl:Quote:
Yeah there is quite a bit of flex in my chassis come to think of it. Not sure how the pros and cons of that balance out, so will be interesting to see how a more rigid one like yours gets on.
But you've got it well planned out by the sounds of things and it'll probably look pretty shiny and cool as usual, looking forward to build pics in due course :)
I would always err on the side of having more drum showing. I'm not in the arena to proect my opponents from my weapon and I've learned the hard way that having it shielded in various ways just ends up hampering you
What CAD software are you using Dave?
Looks nice a clean, and obviously does 2D. Getting fed up with this fake horizon, random woman at startup, SketchUp crap.
