Re: How could I Improve pt 2
what Im wondering about Mark, why are these bots unreliable? vapourbots are always considered to be build perfectly and flawless and I dont find anything in the stats that makes these bots extremely unreliable, so why make these bots seem weaker than they are by calling them unreliable?
also, do you mean the entire bar is in front of the wedge or rather in the wedge? the way I see it the wedge doesnt rly serve a purpose anymore if the bar is entirely in front of it
besides all though these bots seem like serious attempts, keep up the good work!
The bar weapon is in the wedge.
Thanks for your constructive criticism. Joey has also been helping me (Through PMs), and once again: here are my latest stats:
Roveress Evo
Weight: 100kg
Shape: Biohazard, with Growler's head at the front.
Colour: Brown, with black and white splotches in some places.
Dimensions: 95cm x 65cm x 30cm
Drive: 4x 24v S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 4 foam filled wheels.
Armour: 5mm Titanium/Vanadium alloy.
Speed: 21mph
Ground Clearance: 0mm at front due to wedge, and at sides and back due to skirts. 5mm at sides and back without skirts.
Turning Circle: 0m
Weapon: The bottom Jaw Is fixed to the ground, and shaped like a wedge with Mute-style barbs on it. Once a robot is stuck on the wedge, the top Jaw, powered by a 2.2kg 1000psi Nitrogen tank, comes down with over 2 tonnes of force.
Srimech: A lifting arm, built into the back of the robot, powered by a Bosch drill motor.
Strengths: Fast and maneuverable.
Weaknesses: The Srimech doesn't always work.
Side Swipe 2
Weight: 100kg
Shape: Panic Attack (S2) with a Tornado style wedge on the front
Colour: Silver
Dimensions: 90cm x 65cm x 35cm
Drive: 2x 24v S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 4 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
Speed: 20mph
Ground Clearance: 0mm at front due to wedge, at back and sides due to skirts. 5mm at back and sides without skirts.
Turning Circle: 0m
Weapon: A titanium 5kg 70cm-in-length spinning bar at the front of the robot, that spins at 2000rpm, powered by a 24v S28-400 Magmotor. The robot has shock proofing to absorb the punishment dealt out by this weapon.
Srimech: Invertible
Strengths: Powerful weapon and good ground clearance.
Weaknesses: None that I know of.
El Camino
Weight: 100kg
Shape: Invertible Cylinder
Colour: Red. The teeth are painted gold.
Dimensions: 80cm x 80cm x 25cm
Locomotion: 2 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
Armour: 5mm Hardox
Speed: 18mph
Ground Clearance: 5mm all around.
Turning Circle: 0m
Weapon: The body spins around at 2000rpm, powered by an E-Tek, and has 4 Hardox teeth approximatly 6cm above the ground.
Srimech: Invertible
Strengths: Deadly weapon!
Weaknesses: A bit unstable.
Bubble Blaster
Weight: 100kg
Shape: Dreadnaut XP-1 (S4)
Colour: Blue. The Crusher is Silver.
Dimensions: 90cm x 60cm x 50cm
Drive: 4x 24v S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Locomotion: 4 Vulkanized rubber wheels.
Speed: 20mph
Ground Clearance: 0mm all around due to skirts. 5mm without skirts.
Turning Circle: 0m
Weapon: A very big 3000psi Titanium/Vanadium alloy crusher. Powered by a Vivoli pump motor, it can come down with over 6 tonnes of force.
Srimech: The domed shape will help it self-right. If that fails there is always the S28-400 Magmotor powered self-righting arm built into the back of the robot.
Strengths: Tough Armor and speed for a robot of its shape.
Weaknesses: Not very maneuverable.
Minesweeper
Weight: 100kg
Shape: Tornado (S6)
Colour: Silver, with MINESWEEPER written on the sides in red.
Dimensions: 90cm x 85cm x 25cm
Drive: 2x 36v LEM-130 motors, powered by 6x NiCad Battlepacks. The motors power the 2 middle wheels, giving Minesweeper extremely good maneuverability.
Locomotion: 6 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
Armour: 5.5mm Hardox
Speed: 20mph
Ground Clearance: 0mm at front and back due to scoops, and 5mm at sides.
Turning Circle: 0m
Weapon: 2 Hardox snowplow-like scoops that can move slightly vertically, like Behemoth's, so I get good pushing power, but 0mm ground clearance at front and back.
Srimech: Invertible
Strengths: Super-reliable and fast. Now more maneuverable.
Weaknesses: Not too much of an offensive weapon.
Cyrilium Mach 3
Weight: 100kg
Shape: Mortis (S4)
Colour: Gold
Dimensions: 90cm x 65cm x 30cm
Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
Speed: 20mph
Ground Clearance: 0mm at front, and 5mm everywhere else.
Turning Circle: 0m
Weapon 1: A diamond tipped rack-and-pinion type pneumatic axe, powered by a 200psi 1.75kg C02 tank, driven by a 70mm bore, 150mm stroke ram. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
Weapon 2: A flipping arm, powered by a 1.75kg C02 tank at 750psi. It can lift up to 250kg.
Srimech: The flipping arm.
Strengths: Twin weapons.
Weaknesses: None as of the time being.
Trojan/Virus/Worm (TVW for short)
Shape: Biohazard
Dimensions: 95cm x 65cm x 25cm.
Weight: 100kg
Speed: 20mph
Ground Clearance: 0mm all around due to skirts, and 5mm without.
Colour: Black
Turning Circle: 0m
Locomotion: 4 solid rubber wheels mounted internally.
Power: 4x 24v S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Armour: The skirts are 4mm titanium, while the body armour is 5mm titanium.
Weapon: A Hydra-shaped axe, powered by 2x 2kg Co2 tanks feeding Co2 to a 70mm bore 550mm stroke ram, which gives it about 660kgs of force. It has the ability to pierce 3mm titanium, and actually scratch 5mm titanium.
Srimech: Due to the power of the axe, the robot can easily self-right.
Notes: Has lots of shockproofing to prevent shock damage.
Strengths: Fast axe to do a lot of damage in a short amount of time.
Weaknesses: Not tough enough to withstand a beating from a major spinner.
Interstate
Weight: 100kg
Shape: El Diablo (Battlebots Series 2.0)
Colour: Blue, with I-35 written on the top.
Locomotion: 4 fully Vulkanized rubber wheels
Armour: 10mm Duralumin
Speed: 19mph
Ground Clearance: 0mm at sides and back due to skirts, 5mm without skirts, usually 5mm at front.
Turning Circle: 0m
Setup 1: A 10kg solid Hardox wedge at the front, 0mm ground clearance, designed to kill spinners where they stand.
Setup 2: a 5kg drum, with 10 tiny Hardox teeth, powered by an LEM-130 at 1500rpm, at the front.
Srimech: invertible
Strengths: I have a choice of weapons.
Weaknesses: Too maneuverable, can sometimes get out of control.
Ninjoid Evo
Weight: 100kg
Shape: Tornado Mer with a skirt around the bottom.
Colour: Black, with red on top.
Dimensions: 95cm x 95cm x 25cm
Drive: 2x 24v S28-400 Magmotors powered by 5x NiCad Battlepacks.
Locomotion: 2 foam filled wheels
Armour: 3.5mm Titanium/Vanadium Alloy
Speed: 20mph
Ground Clearance: 0mm with skirts, and 5mm without skirts.
Turning Circle: 0m
Weapon: A 1.25m 136kj 3000rpm titanium blade, powered by a Combatparts 4-mag gearbox with 4 S28-400 Magmotors. The robot has lots of shockproofing to counteract the force of the blade.
Srimech: The force of the blade can cause it to right itself after a flip. Sort of like Mauler, except it cannot be stranded on its back.
Strengths: Very dangerous.
Weaknesses: Can flip. The inertia is not always strong enough to flip it back over.
Corsair
Weight: 100kg
Shape: All Torque (Series 2) with a wedge at the front.
Colour: Gold, with a black stripe down the middle, and CORSAIR written on the sides.
Dimensions: 95cm x 70cm x 25cm
Drive: 4x 24v S28-400 Magmotors powered by 5x NiCad Battlepacks.
Locomotion: 4 internally mounted fully Vulkanized rubber wheels.
Speed: 17mph
Ground Clearance: 0mm at front due to wedge, 5mm at sides and back.
Turning Circle: 0m
Armour: 4mm Hardox
Weapon: a 12mm thick titanium/vanadium alloy wedge, mounted on the front.
Srimech: an pneumatic flipping arm, built into the back of the robot, powered by a 1.5kg C02 tank at 750psi.
Strengths: At least half-tough.
Weaknesses: Quite slow for a vapour.
Armory
Weight: 99kg
Shape: Big rectangular prism with a wedge at the front.
Colour: Yellow, with blue on the top and bottom.
Dimensions: 90cm x 50cm x 25cm
Locomotion: 2 externally mounted fully Vulkanized rubber wheels.
Speed: 20mph
Ground Clearance: 0mm at front due to wedge, 0mm at sides and back with skirts, 5mm without skirts.
Turning Circle: 0m
Weapon: a 20kg Supernova shaped titanium disc with 2 2kg Hardox Hammerheads, powered by an LEM-200.
Srimech: Invertible
Strengths: Tough, with a dangerous weapon.
Weaknesses: Turns too fast.
Tenderizer
Weight: 100kg
Shape: Imagine Hell's Teeth, with a wedge on the front, and with Thor's Hammer.
Colour: Black
Dimensions: 100cm x 50cm x 25cm
Locomotion: 2 Vulkanized rubber wheels at the front, and a caster at the back.
Speed: 19mph
Turning Circle: 0m
Weapon: A Thor-style rack and pinion hammer, with a 2kg meat tenderizer for a hammer head,
powered by a 2kg C02 tank at 200psi, It can come down with about 1000kg of force, and easily pierce 5mm titanium.
Srimech: The axe can easily self-right the robot.
Strengths: Crushing Weapon.
Weaknesses: None that I can think of, yet.
EDIT: What about this new one?
Darkwing 1.0
Weight: 100kg
Shape: Tornado, you know, that basic rectangular wedged box.
Colour: Black, with DARKWING written on the top in red.
Dimensions: 70cm x 40cm x 25cm
Drive: 2x 24v S28-400 Magmotors, powered by 4x NiCad battlepacks.
Locomotion: 4 Omni-directional wheels.
Speed: 20mph
Ground Clearance: 0mm at front due to Special weapon, 0mm at sides and back due to skirts. 4mm without skirts.
Turning Circle: 0m
Armor: 10mm Duralumin
Weapon: Now here's where it gets interesting. The robot has, at the front, 2 Tornado-like wedges put together. As in, there's one wedge on top with the inclined end facing the ground, and one wedge on the bottom, with the wedge in its normal position. The idea is: A flipper will drive in between the 2 wedges, try to flip Darkwing 1.0 over, and the resulting stress put on the flipper by the top wedge is so much, the flipper's rams will explode, rendering the flipper useless.
Srimech: Invertible.
Strengths: Invertible and quite maneuverable.
Weaknesses: Weapon is untested in combat.
Presenting the latest Gabriel version for your consideration :)
warning: this robot may contain large doses of ears
http://i267.photobucket.com/albums/i...gabriel2-1.png
Gabriel V
DIMENSIONS: 110 x 80 x 25 cm
SHAPE: Elongated triangular pyramid, with a comparatively steep rear and shallow front...and large ears, which are explained below
COLOUR: See the pic, mostly yellow and black
DRIVE: 2 C40-300 Magmotors run at 32v (from 40 x 2.3ah A123 lithium ion cells giving 32v and 9.2ah in four packs), geared 10:1, driving two rear urethane rubber coated 2014 aluminium wheels. No castors, just runs on the nose cone.
SPEED: 16mph
GROUND CLEARANCE: 0mm at the front due to the nose cone, which scrapes the floor, rising to 12mm at the rear underneath removable side and rear 5mm 7075 aluminium skirts.
CHASSIS: TIG welded 2mm wall 25mm stainless steel box section frame
ARMOUR: 4mm Hardox on both sides and the rear, mostly welded into one shell for extra strength. The base is 5mm 2014 aluminium (recessed into the chassis somewhat to protect from low mounted Spin Dash type weapons) and the front nose cone is 10mm hardened S7 tool steel.
WEAPONS: A front hinged full bottle pressure pneumatic flipper, constructed from 5mm stainless steel and fed from two 1.1kg CO2 tanks into an 80mm bore hydraulic ram, giving about 2.8 tonnes of lifting force.
There are two hardened S7 tool steel spikes located at the back of the nose cone as well, one either side, and these are brought into play by spinning the robot around, essentially making it double as a thwackbot.
SRIMECH: The flipper. The rear is at such an angle that stranding there is very difficult (and operating the flipper will unbalance it onto its back)
NOTES: Where possible, Gabriel V's internals have been shock mounted to prevent too much shock damage from spinners and ramming attacks.
The robot sports two removable triangular 'ears' at the back of each side, which are made of 15mm UHMWPE (supported by a bar of the chassis' box section) and designed to stop robots from going over Gabriel from the front and driving over the back and down.
THANKS TO: Martijn Benschop for the awesome renders, Kody Kunz, Andrew Jackson, and Aaron Knight for advice and constructive criticism. :)
STRENGTHS: Can hear the opposition coming from some distance away :P Well armoured, maneuvrable, powerful with an effective and fast weapon.
WEAKNESSES: Loud music, as it can damage the sensitive ears and remove its ability to hear opponents coming.
Please tell me if there's any huge gaping flaws in the design please :talker:
Oh gosh...
I don't see anything. But that is just me...
Well, I have another bot I'd like to have checked out:
Sgt. Pepper
Weight: 100kg
Shape: Sgt. Bash
Colour: Desert Camouflage
Dimensions: 100cm x 55cm x 60cm
Drive: I know this is going to look stupid, but 1 of Shunt's cold fusion engines attached to 2 gearboxes via a chain.
Locomotion: 2 foam-filled wheels. The robot also runs off of the smoothed nose.
Speed: 16mph
Ground Clearance: 5mm at sides and back, 0mm at front due to nose scraping the floor.
Turning Circle: 0m
Weapons: First, there's a katar-shaped rending spike at the front. Secondly, there is a Pussycat-style blade at the rear, powered by an S28-400 at 1000rpm. Finally, there is what appears to be a flamethrower at the top: Instead of flames, however, It shoots out sparks reminiscent of the parks coming out of Matilda in Series 1 and 2 of robot wars. This weapon is purely designed for fan enjoyment, and does no damage.
Srimech: Um... Uh... It doesn't have one.
Strengths: Good pushing power, and turns very quickly.
Weakness: NO SRIMECH!!!
...if you knew it was going to look stupid, why the feck did you put it in the stats Mark? That is quite possibly the stupidest thing I have seen so far this year...and I've seen some of Andy's comments after a night of boozing...
Cold fusion engines do not exist. Shunt, as far as I am aware, ran two Bosch 750 motors at 24v and the 'cold fusion engines' were a fabrication of the marketing department at either the BBC or Mentorn...change it to something sensible and real please.
The spark generator would also not be allowed under current FRA rules I believe, it certainly wouldn't be allowed by me.
Aaron would say cold fusion engines existed... :uhoh:
Okay, here's my new stats:
Sgt. Pepper
Weight: 100kg
Shape: Sgt. Bash
Drive: 2 36v LEM-130s powered by 5x NiCad Battlepacks.
Speed: 16mph
Turning Circle: 0m
Weapons: First, there's a katar-shaped rending spike at the front. Secondly, there is a Pussycat-style blade at the rear, powered by an S28-400 at 1000rpm. Finally, there is what appears to be a flamethrower at the top, but it doesn't do anything except turn left and right.
afaik cold fusion does excist, only in an insanely inefficient way, but it is still labelled as cold fusion afaik, I may be wrong though and its all incredibly complicated... long story short I wouldnt use this type of cold fusion on a robot Mark
do I understand correctly that this Sgt. Pepper is somewhat of an experimental robot Mark? nothing wrong with it if it is but if it isnt you're gonna want a srimech and no flamethrower... actually if it IS an actual flamethrower you may have to drop it or you're gonna be banned from several tourneys, unless it only LOOKS like a flamethrower. With srimech this bot wouldnt be terrible really, the weapons are somewhat ineffective but it has a good drive (whats the RPM of the blade?), not your average rambot, perhaps swap the 10 mm Duralumin for something Hardox?
Yes, I guess it is an experimental machine.
I've modified it once more:
Sgt. Pepper
Weight: 100kg
Shape: Sgt. Bash
Locomotion: 2 foam-filled wheels, covered by the Hardox armor. The robot also runs off of the smoothed nose.
Armour: 4mm Hardox
Speed: 16mph
Turning Circle: 0m
Weapons: First, there's a katar-shaped rending spike at the front. Secondly, there is a Pussycat-style blade at the rear, powered by a 24v S28-400, the blade spins at 3000 rpm. Finally, there is what appears to be a flamethrower at the top, but it doesn't do anything except turn left and right. It is not a real flamethrower.
I also have some old concepts I'd like to bring back:
Wishbone
Weight: 100kg
Shape: Barberous 2'n a Bit, including the little yellow wheel stabilizers(Although they're a different color).
Colour: Gold and Silver stripes across the drum, with black wheel stabilizers.
Dimensions: 20cm(30cm including the stabilizers) x 100cm x 20cm
Drive: 2 S28-400 Magmotors powered by 4x NiCad Battlepacks.
Locomotion: 2 solid rubber wheels
Armour: 4.5mm Titanium-Vanadium alloy
Speed: 19mph
Ground clearance: about 9mm
Turning Circle: 0m
Weapons: First there's a 24v S28-400 Magmotor turning the drum-like outer shell at 2500rpm clockwise. the impact should have enough force to flip a robot into the air about a meter. Also, the drum is divided into 2 parts due to a slot running down the entire middle of the drum. Sticking out from that slot is a 360 degree smacking mace attached to a solid Hardox arm, which won't do that much damage.
Srimech: Invertible
Strengths: The drum can flip robots. The mace might also do some thwacking damage. (Yeah right...)
Weaknesses: Somebody might complain of its resemblance to Kody Kunz's Laertes the 2nd.
Destructophobic
Shape: A long and wide wedge with a rounded back, reminiscent of Roger Plant's The Big Cheese)
Colour: Yellow, with Destructophobic written down the sides. The flipper is gold.
Dimensions: 110cm x 50cm x 15cm
Drive: 2 36v LEM-130 motors, powered by 7x NiCad Battlepacks
Locomotion: 2 solid aluminum wheels, with rubber tyres and Aluminum Boron Carbide hubs.
Armor: 3.5mm Hardox
Speed: 15mph
Ground Clearance: 0mm at front, 5mm at sides, and 7mm at back.
Turning Circle: 0m
Weapon: A rear-hinged flipper built into the wedge, powered by a 1.5kg Co2 tank specially made to use up excess space in the robot's frame. The flipper has a standard 150mm bore 70mm stroke ram powering the flipper.
Srimech: The Flipper can self-right the robot.
Strengths: Low to the ground, very maneuverable, average armor.
Weaknesses: Based on an outdated machine, might not work out.
Any problems with these?
