One word: Owch:sad:
One word: Owch:sad:
Im going for a shock, Mega Masher 2 to ram the very wide Dervish 5 into the pit, via ramming around the rear end, it cant turn easily at full power, so that it has a disadvantage at once.
Daniel Stickler and Chris Mason both already have one robot each in the semis - will Dervish V/ be celebrating with Manic Monsoon, or will Mega Masher 2 be going for celebratory drinks with Orka Mk3?
3, 2, 1 - ACTIVATE!
Dervish V/ began backing off again to allow itself spinning time, and as Mega Masher 2 came at it, it turned for a side hit! Mega Masher 2 was tilted like Scimiter, and looked like it might rest on its side! Dervish V/ stopped that by hitting MM2 in the underbelly and throwing it against the wall! As MM2 began sliding onto its wheels, it was struck by the 22nd seed again, but the wall prevented it from really tilting, so it was able to run away, inverted and getting a clip from Dervish in the rear! A moment later, MM2 came back at its opponent, its inverted wedge shoving one wheel! Unfortunately, this aided Dervish in turning around and striking the 5mm titanium, doing it no good! It did Mega Masher 2 some good, though, allowing it to fall back onto its wheels - when Dervish attacked again, it hit the rear disc and took a scratch! Mega Masher 2 reversed at Dervish V/ with the disc, hitting the drum and right wheel hub! Dervish tried to attack but was smacked on the wheel again, although it managed to turn into Mega Masher 2s side with its other wheel and hit! Almost settling on its side, Mega Masher 2 became inverted again, and its side armour became even more slashed by Dervish V/ seconds later!
Mega Masher 2 again escaped at this point, running away from Dervish V/ and using its bar to selfright, so its wedge was in play! It swerved round as Dervish V/ approached, then ran round its opponent and tried to ram it into the wall! The wedge hit the drum and both robots bounced back, then ran at each other again! In trying to reach the side, Dervish V/ ran up the wedge and hit the side top, giving itself and MM2 a knock! Going for MM2 again, it just managed a nick before Mega Masher 2 was off again and trying to ram in the side, but Dervish V/ took advantage and got in another side bash which tilted the box wedge! Another hit sent MM2 rolling all the way over, and taking another strike before it could run away, tilting it again and causing it to finally rest on its side! Fortunately, it could use its bar, and even more fortunately, it had righted itself before Dervish V/ could hit the bar - but the 22nd seed could still hit the armour, and tilt Mega Masher 2 again, to slash the underbelly! MM2 bounced a little and began coming down onto its wheels, and again it was struck! It landed on its wheels after the hit and ran away to right itself again! Dervish V/ faced Mega Masher 2 down as it rushed in to ram, and swerved round to hit the side and bounce off again! Mega Masher 2 also bounced back, but did no more moving after that - the repeated attacks of Dervish V/s drum on the armour had taken its toll! Another victory spin was in order for Dervish V/!
CEASE!
DERVISH V/ GOES THROUGH TO THE SEMI FINALS!
Next time on VFT6, fourth seed Killotine Evo will give Mother Of All Bricks 2, Terrorhurtz and Wrecktangle a good axing!
And twentieth seed Typhoon 2 will try to get another trophy, but first it needs to beat Ringmaster, Well Buy You A New One Tomorrow Mrs Brown and Ymir!
Dont think that was for kicking me in the shin, Chris - I was wearing shinpads! You need to keep safe in the pits, after all!
Winner of the Heat: Mother of All Bricks 2 :proud:
HEAT O
ROUND 1
1) KILLOTINE: EVO (4) VS Mother of All Bricks 2 VS Terrorhurtz VS WreckTangle
For this bout, I suggest that Aaron bludgeons WreckTangle into the Pit while I slip under Hz12 and see if we cant deshell the Lord of the Axes :proud:. Once a good grips on the polycarb, drag it off to the Pit.
2) Ringmaster VS Typhoon 2 (20) VS Well Buy You A New One Tomorrow, Mrs Brown VS Ymir
Ill pick the two spinners to beat the cluster via KO and the hammer-on-wheels via a judges decision
More wootiness from the Rich Man! :proud:
Wrecktangle will team up with Terrorhurtz and well act as a Tag Team throughout the whole battle. That way...
1:EITHER well cause a big shock
2:proud:R well both go out and both favourites will go through.
Team up with Stevo and send them all down the pit...
Kill the spinners, by pushing them down the pit.
Killotine Evo (4) vs Mother Of All Bricks 2 vs Terrorhurtz(me) vs Wrecktangle
Break Killotines hammer & keep away from Wrecktangles weapon, as for the other, Rich can decide how I take it on
PREDICTIONS:
1) Mother of All Bricks 2 and Killotine Evo
2) Ymir and Ringmaster
WINNER: Ymir
300TH POST!!! :proud:
Team Gore - revolutionizing the vapourbot world
