How Could I Improve...
adding it theres no use...
finish the challenge belt one, people will see you are capable of finishing a tournament, and theyll see you are improving your battles, that works in your advantage
after you finish the challenge belt just open up a thread and say whatll be happening, what the tournament shall look like and what you want from us, you might wanna look at the opening posts of tournaments like Chrash & Burn and Mechanical Noise for inspiration :)
I wil finish the challenge belt first, no matter how long it takes!Only when the challenge belt is finished will do another tournament:)Thanks a lot
And thanks to AJ for starting this awespome thread-I wish I had read it before starting my original tournament-Robot Coliseum...
http://magmotor.com/brushed/brushed.htmlhttp://magmotor.com/brushed/brushed.html
i have heard of them now. :) still stick with the 300. tried and tested to the max :) :)
Question, just what is the theory behind allowing tracked machines 10KG more?
i blame whoever started that rule in the first place
Tracked machines are supposed to have less speed (in many areas) than regular wheeled robots.
But does less speed warrant an extra 10 kg?
Well consider the speed loss. There should be SOMETHING to make up for that. And no, I dont mean a better driver. :P
Tracks
Are
Heavier
Than
Wheels.
