Velociraptors Fanfic Tournament - Series 6!
Finally a battle that showed the full extent of the straifing ability :) W00t!
For against Hypertension, Im going to raise the RPM level to 1000rpm and will keep straifing out of his way, making him crash into the wall and not hitting me. The idea here will be to dodge/straife to the side, allowing him to half pass me and then slash the sides throwning us apart and letting me maintain full RPM. If i can dodge long enough, Im going to let it get up into OVERDRIVE mode for maximum damage. I dont see him box rushing me in time as for him to traverse a minimum of 4m will take him at least 1sec which is enough time for me to be already cruising at 500rpm, which is plenty of speed to knock an opponent away and let me get up into the peak RPM levels. Having blades only 20mm from the floor helps me catch any wedges before they can get under, so no flipping should happen, if by some fluke chance I get flipped, Im not concerned as Im invertible.
Will be interesting this battle.
Agreed:proud:
Hmm. If Aarons cranking this much power out of the thing Ill go with Hypertension to win after MDU self KOs itself.
Once again, the heat final is seeded robot territory? But which seeded robot is about to become a semifinalist - Mass Disctruction Ultimate 3.1 or Hypertension Mk2?
3, 2, 1 - ACTIVATE!
Mass Disctruction Ultimate 3.1 again started spinning, while Hypertension Mk2 barreled towards it! The former champion strafed, but still glanced the front of Hypertension Mk2, sending it spinning to one side! Hypertension reversed straight towards MDU3.1, only to go straight past another strafe! MDU3.1 came towards Hypertension, but had to dodge again when the 24th seed looked ready to use its flipper - unfortunately, Hypertension caught up as it did so, the blades on MDU3.1 hitting the flipper as it fired! As Hypertension Mk2 skimmed away, the 8th seed flew upward, bouncing on its side as it came down and almost hitting the wall! Inverted, it spun up and dodged the charging Hypertension again, causing it to go smash into the wall, so it could have its right side assaulted! MDU3.1 dodged the flipper and hit the right side again, knocking Hypertension Mk2 against the wall again, and glancing its rear as it escaped! Hypertension spun around, while MDU3.1 was reversing away, and charged, but missed again as MDU3.1 strafed, then had a blow in the left side! Escaping MDU3.1s attack, Hypertension Mk2 swerved round again and managed to use its flipper again, spinning itself off but causing MDU3.1 to bounce off the floor, into the wall, back to the floor and away!
Hypertension Mk2 followed it, but MDU3.1 eventually landed, strafed the attack and began spinning again, striking a glancing blow on Hypertensions rear to add insult to injury! Cornering Hypertension over the closed pit, MDU3.1 mashed it again, denting the Hardox! Managing to escape with another brief touch on its rear, Hypertension Mk2 rushed at MDU3.1 as it was close to the wall and gave it another ram, missing the flip but causing MDU3.1 to hit the west wall and skim across the floor! Spun against the wall, Hypertension recovered and went after MDU3.1. Again, MDU3.1 was spinning just enough to knock it, but not before Hypertension had flipped! Hitting the wall, MDU3.1 came down on its side, and settled onto its wheels, strafing Hypertension Mk2 again, and hitting it as it reversed! Unfortunately, it was still close to the wall, and Hypertension rammed it in, causing the 8th seed to bounce off after the already spinning 24th seed! Spinning again, MDU3.1 missed hitting Hypertension Mk2 on the rear, and ran away from the wall while Hypertension chased it! Strafing, MDU3.1 whacked Hypertension on the side once again, chased it as it spun, but ended up meeting the flipper! Hypertension was spun into a corner and couldnt follow MDU3.1 as it bounced away again!
The two robots came towards each other quickly again, MDU3.1 again dodging and slicing Hypertension Mk2 along the side, but the Hardox armour still held up, while Hypertension went head first into the wall and MDU3.1 could hit it again! Backing up, Hypertension missed MDU3.1 as it dodged again, but was hit on the rear again, and then glanced on the side! The 24th seed backed up again and came in more carefully, following MDU3.1 as it strafed and getting in another flip, sending the 8th seed away across the floor! MDU3.1 bounced against the floor and glanced the west wall, slowing the spinner, and finally Hypertension Mk2 managed to follow and catch it! It immediately turned MDU3.1 around, rammed it against the pit release, and a moment later, Mass Disctruction Ultimate 3.1 was denied a reclaiming of the title as it was consigned to the pit! Despite the pummeling it received, Hypertension Mk2s valiant efforts had paid off!
CEASE!
HYPERTENSION MK2 GOES THROUGH TO THE SEMI FINALS!
Next time on VFT6, sixth seed SD IV will try to make life saw for Aces & Eights, Scimiter and Supernova!
And 22nd seed Dervish V/ will try to be a whirling dervish against Mega Masher 2, Total Bast**d and Wind Chiller!
Scott, can I have the stats for Total B*****d please?
Another shockaroonie courtesy of Mr S!
HEAT N
1) Aces and Eights VS SD IV (6) VS Scimitar VS Supernova
A&E and Supah both share high ground clearances, so these two will be the saws targets in this particular clash. Avoid Scimitar to be double-extra-super-safety sure :wink:
2) Dervish // (22) VS Mega Masher 2 VS Total B*****d VS Wind Chiller
Cant say much without Total Bassas stats, but Im certain that Private Sticklers spinner will prevail reguardless :)
Fancy a team-up, Steve? Aces and 8s has exposed wheels IIRC so you can slice them up nicely while I can get under SuperNova fairly easily and safely thanks to the long blade. Ill first prop it up, then lift it over and might be able to do some nice damage to the light looking armour for a quick kill, then help Steve finish off the battlebot if needed.
Sorry, I thought Id posted these, but then I realised I mustnt have, since I couldnt find the file on my computer.
NAME- http://img.villagephotos.com/p/2004-...-stard.JPGT.B.
Wind Chillers Tactics:
Team Up with Total B*****d. Ill go after Mega Masher 2, and quickly pit it without being damaged too much, then Scotts machine can go after Dervish \/ /, and it should be able to rip it up pretty badly, and once Dannys machine is beaten, Ill send DV/ straight down the pit. This should hopefully work, if my tactics go according to plan. :)
STAY AWAY FROM WIND CHILLER, IN THAT CASE, AT ALL COSTS!
