Yup, quite compact as usual, and it'll probably get more compact still as the cardboard bulkheads are about 2mm thick, and the actual ones will be 12mm thick which will make it seem a lot more cramped. Total size in that first picture is about 410mm long by 320mm wide, but the internal box bit where everything is contained is 180mm by 220mm. It's much easier having a small Scorpion controlling all the drive functions than two Electronizes, mixer and BEC etc. Combined with the smaller dimensions of the brushless motor and speed controller, it makes it possible to shrink the size down. So fingers crossed for meaty drum and hardox armour :)
