AJ is still working on stats (told me over MSN) so Im patient enough to wait for him. Martyn, I need your final two bots please.
JimBob eh? Yeah why not. Sounds alright! Sorry for the late reply, PC died and I just got a new one.
*cue evil laugh*
So I count we will be waiting until Christmas 2017?
Its Martyn we have to watch for. :proud:
Who is this Martyn character? Would hate to be waiting for stats from him.
Martyn, do you actually want to compete in this or not? :P
I guess not, as Martyn has told over MSN that if somebody is ready to enter then let them. So Martyn is out.
But still, no Mark Elam or Andre Ydolly. I DONT CARE, YOURE NOT GETTING IN. :P
Liam Eliot, you are welcome to if you can bring together 8 good robots/vapourbots. :)
And where are Tony and Alex M&W? :P
Ill enter Kody!Thanks so much, I have some proper vapours now, Ill type the stats up now, gimme a minute. The vapours Ill enter will be:
Gulp
System Shock
Marwolaeth
Hatchet
LockJaw
Henry VIII
Alpha-Rex
Ill pick 1 realie.
-2>quote:
What if Timothy James Silley made a grand return? :uhoh:
Id consider it. :proud:
Anyway yeah, Liam, you are in (just need stats and that real robot), and paired with Jamie. You guys now need to suggest between each other a team name, and pairings for your pairs of 8 robots.
Also, AJ popped in to tell me that his bots will be worked on and done after this week closes out.
Can I replace all the robots I entered and have since updated with their updated versions?
Since the line-ups are not posted yet, you may.
Right, thanks. They should be all in your forum somewhere.
Stats:
Gulp
Weight: 110kg
Shape: Tank
Dimensions: 95 x 70 x 45
Ground Clearance: Effectively 0 all round due to skirts, 10mm all round behind them.
Turning Circle: 0
Power: 4 x S28-400 magmotors running at 24v
Weaponry: Tazbot-style 360 degree turret with 50cm hardox lifting arm. The turret is spun by 1 x LEM-130 to give it reasonable effect when spun like a spinner. The arms lift/crush capabilities are powered by another LEM-130, should lift/ crush with 200kgs of force. I dont expect it to crush any armour, but it can stop a bot self-righting. The sides of the arm are spikes and tungsten tipped at the bottom.
Motivation: 2 x steel tank tracks
Armour: 4mm hardox on all sides, 1mm titanium skirts, 3mm titanium base, 5mm titanium top and turret.
Srimech: The arm can right the robot in any direction.
Colour: Camouflage
Top speed: 10mph
System Shock
Shape: Invertable box
Weight: 100kg
Dimensions: 80 x 80 x 25
Locomotion: 2 x steel tank tracks
Power: 4 x LEM-130s at 36v
Armour: 4mm hardox all over, skirts are 1mm titanium
Weaponry: 3mm thick hardox front scoop, ala Tornado
Ground Clearance: Effectively 0 due to skirts on sides and rear and scoop on front, 8mm behind them.
Turning Circle: 0
Top Speed: 10mph
Colour: Light blue with the name painted on top in yellow.
Marwolaeth
Weight: 110kg
Shape: Invertible box
Dimensions: 80 x 100 x 20
Ground Clearance: Effectively 0 due to skirts on sides and rear, 8mm behind those and at the front
Turning Circle: 0
Power: 2 x S28-400 magmotors running at 24v
Locomotion: 2 x Drill-Zilla style feet (shufflepads)
Weaponry: 50 x 50cm 3mm thick hardox horizontal spinning disc powered by 2 x LEM-130s at 36v. Can get up to 1500rpm in 3 seconds. 2 large wild thing (series 5) style blades placed adjacent to each other. 97kj hit when spinning at top speed.
Top Speed: 12mph
Armour: 6mm titanium on top and base, 1mm titanium skirts and 4mm hardox sides.
Srimech: Invertible
Colour: Red
Hatchet
Weight: 100kg
Shape: low box with stiff tail
Dimensions: 60 x 60 x 20
Locomotion: 2 x go-kart wheels
Power: 2 x LEM-130s running at 48v
Ground Clearance: 8mm
Turning Circle: 0
Top Speed: 25mph
Weaponry: 1mm titanium front scoop and 50cm long, 3cm wide hardox tail with two tungsten tipped spikes in different directions (T shape). When the robot spins this can deliver a 65kj hit.
Armour: 5mm hardox all over.
Srimech: Invertible
Colour: Gold with name painted in red on top
LockJaw
Weight: 100kg
Shape: Axelbot, like Stinger but with a vertical claw instead of a bludgeon.
Dimensions: 55 x 70 x 60
Ground Clearance: 0, as its an axlebot. 0 at the claw front as well.
Turning Circle: 0
Weaponry: Vertical hardox claw, top end powered by 1 x M-Mac 400 motor running at 36v, bottom half powered by another. About 100 speed holes and it has serrated edges.
Armour: 4mm hardox
Top Speed: 15mph
Colour: Gold wheel hubs, silver claw.
Henry VIII
Shape: Low box
Weight: 100kg
Dimensions: 85 x 85 x 20
Ground Clearance: Effectively 0 due to skirts and scoop, 6mm behind them.
Turning Circle: 0
Locomotion: 4 x vulkalon tyres
Weaponry: Tungsten tipped axe, powered by co2 at 750psi, 3mm thick titanium static scoop at the front.
Armour: 4mm thick hardox top and sides, 1mm titanium skirts, 4mm titanium base
Top Speed: 20mph
Colour: Black
Srimech: Axe
Alpha Rex
Weight: 100kg
Shape: Box
Dimensions: 85 x 90 x 35
Power: 2 x LEM-130s running at 36v
Ground Clearance: 0 at front due to flipper, 8mm everywhere else.
Turning Circle: 0
Weaponry: 1000psi nitrogen flipper with 1 x 100m ram, 2 x 3kg bottles, can flip 1600kg.
Armour: 6mm titanium flipper, front, rear, sides and top, 3mm titanium base.
Srimech: Flipper, titanium spikes on sides and back stop it getting beached.
Colour: Gold
Notes: MWA-HA-HA-HA written on base.
Ill take Robochicken (S7) as my realie if hes avalible. Thanks for letting me enter Kody!
I plan to make a few updates as well Joey, as due to Aarons recent entry list (:proud:) and the number of other spinners, Ive chosen some updated robots (Ive redone Nitro-Gene, MeCannibal and D.V.D as well, and Ive also brought out a new robot to give some others the pain - The Rock, and you Cant Stop The Rock (Great Song :proud:)
Nitro-Gene 4.0 - The Quaestor
MeCannibal 2.0 - Pheonix Down
Autoism 2.0 - No Objections
D.V.D: The Sequel - 147
Tri-Tainium - Gabriel II
WORCK - Nidhogg
The Rock - Life And Death
Storm 2 - 13 Black
NITRO-GENE 4.0
€ WEIGHT: 100kg
€ ARMOUR: 5mm Hardox for the body. 6mm Hardox flipper. Inside the body, there€™s 1cm of Vulkanised rubber on the sides and rear, with 2cm on the front to help fight powerful spinners
€ SHAPE: Low invertible box with pointed sides and rear. At the front is a 42* wedge to aid in getting underneath other robots. All the lines have been curved over to make it harder for a spinner to grab onto a panel and rip.
€ MOTORS: 4 x LEM 130€™s at 36V = 36HP
€ LOCOMOTION: 4 Vulkanised Wheels.
€ DIMENSIONS: (L) 90CM (H) 17CM (W) 70CM
€ COLOUR: Black all over with the flipper coloured red.
€ WEAPONRY: A full pressure Nitrogen powered flipper at 1000psi, using a single 80mm ram at 1000psi. The flipper is mounted in the middle of the robot, and is 20cm wide and runs 30cm up the body. Using a 3cm long Titanium strip underneath the flipper, and a heavy flipping arm, the flipper runs completely along the ground. Running on a ratio 2.2:1, the flipper produces 1600kg of force at the tips, allowing me to launch anyone away! This version has 2 x 3kg Nitrogen bottles, giving me 25 flips!
€ SPEED: 22mph
€ GROUND CLEARANCE: 0MM-2CM. At the front, it is completely 0mm. On the sides/rear, its 2cm. The orginal weakness of Nitro-Gene (its high ground clearance) has been seen to by the skirts on the sides/rear. They are 5mm Titanium skirts and are joined together like BioHazard - at the corners. To avoid them breaking off, they are held in place by Hardox hinges.
€ STRENGTH: Pushing power and weaponry.
€ WEAKNESS: High speed may mean difficult driving
MeCANNIBAL 2.0
€ WEIGHT: 110kg (Shuffler)
€ ARMOUR: 6mm Titanium on top and bottom.
€ SHAPE: Invertible low cylinder
€ MOTORS: 2 x S28-400 MagMotors at 36V = 12HP
€ LOCOMOTION: 2 x Shuffling pads
€ DIMENSIONS: (L) 80CM (W) 80CM (H) 20CM
€ COLOUR: Black with scary human face with over sized teeth coloured red.
€ WEAPONRY: Ring spinner, made of 10mm Hardox, weighing 30kg, powered by 2 x LEM130€™s at 36V to give it spinning speed of 3000rpm and producing 195KJ per blow with a spin-up time of 3 seconds, but is lethal in 1 second. It 2 big teeth made of Hardox that curve out. The teeth are inserted into the body and have rows of Tool Steel spikes on the teeth to dig in. These teeth 5kg each and are designed to send all the spinning energy into one spot rather than small amount into multiple spots. It also has 3 Inches worth of Titanium shock-proof Foam and 1cm of Vulkalon rubber to stop it self-destructing.
€ SPEED: 15MPH
€ GROUND CLEARANCE: 0mm-8mm. It has a full-bodied 5mm Titanium skirt running completely along the ground that rises when the shell is spinning, but drops when the shell isn€™t spinning. This is powered by a simple 750w Bosch 36V motor and runs at the same time as the spinner.
€ STRENGTH: Scary name and weapon
€ WEAKNESS: Hard to control
D.V.D: THE SEQUEL (Death Via Drum)
€ WEIGHT: 100kg
€ ARMOUR: 5mm Hardox body and 6mm Hardox wedge.
€ SHAPE: An invertible box shape with triangular sides and rear.
€ MOTORS: 2 x LEM130€™s at 36V = 18HP
€ LOCOMOTION: 4 Vulcanised Wheels on top and bottom ala Big Nipper.
€ DIMENSIONS: (L) 70CM (H) 23CM (W) 70CM
€ COLOUR: Black for the drum, white for the body.
€ WEAPONRY: At the front is a 15kg drum, made of Titanium with 3 sharpened tool steel teeth. The drum is powered by 2 x LEM130€™s on a ratio of 1.5:1, giving a spinning speed of 6500rpm! 65kj of energy per hit, and if flipped, the drum can be reversed to help it spin the right way - upwards. Behind the drum, there are massive amounts of Vulkalon rubber to avoid self-destruction. To help with pushing other robot around, I€™ve added an invertible wedge to the front made of 6mm Hardox to make it ultra low. The wedge is hindged at 30*, so getting under things is no problem, and it can also lead the opponents onto the drum.
€ SPEED: 13mph
€ GROUND CLEARANCE: The ground clearance is no longer the same all the way around, due to the Hardox wedge at the front - its 6mm on the sides and rear..
€ STRENGTH: Good all-rounder.
€ WEAKNESS: Low speeds.
THE ROCK
€ WEIGHT: 100kg
€ ARMOUR: 6mm Hardox monocoque on the rear, top and sides. 4mm Hardox on the base and front. Inside, I have 4cm of Vulkanised rubber to make sure its good when facing spinners.
€ SHAPE: A box-wedge shape with the front slanted at 60* in order to flip things when slamming them against the walls. All the sides are slanted at 42* INWARDS, so if it balances on any sides, it will deffinately fall back onto its wheels.
€ DIMENSIONS: (L) 80CM (H) 29CM (Without the point of the axe, the height is 26CM) (W) 75CM
€ COLOUR: The body is coloured grey to match the colour of Rocks, and the axe is red, including the axe-rod.
€ WEAPONRY: A VERY powerful CO2 axe. The axe is 750mm long axe, completely made of Hardox, and the axe mechanism is mounted 10cm up from the front of the robot to avoid it suffering damage. The entire thing weights 5kg, with 3kg in the axe head - the axe head is shaped like a cone with the point cut off to cause more dents. The axe runs on a rack-and-pinion system through a 250mm stroke, 100mm bore pneumatic cylinder at 200psi! This allows me to give 1125kg of force per hit! I have 30 hits, and I can cause some harm.
€ SPEED: 15mph
€ GROUND CLEARANCE: On every side except the front which is 0mm, the clearance is 5mm.
€ STRENGTH: Powerful weaponry.
€ WEAKNESS: Unknown.
I hope these are OK. In addition, can I ask if there are any robots that Kody doesnt know the stats for?
Jamie- You can choose a team name, I have no ideas at all!
Your vapours are great, I have some suggestions for our pairings, feel free to point out anything diabolical!
Pussycat/Robochicken
Kronic/Alpha-Rex
Drumroll SR/Hatchet
Dr. Acula/LockJaw
Firefly/System Shock
Sewer Snake/Gulp
Tough as Nails/Henry VIII
Big Nipper/Marwolaeth
How does that look to you?
(Message edited by Robot_Warrior on April 25, 2008)
I should have them...but I will get the list sorted once everybody is in. :)
Can I say something to Liam, just as a bit of advice - those skirts are a bit flexible at 1mm thick. People get under those types of skirts quite easily, Id make your skirts around 5mm Titanium, as its tough for robots to get under skirts of that thickness.
But looking at AlphaRex - it looks SCARY! At some point in the future Id love to see a match between Nitro-Gene and AlphaRex - thatll be AWESOME!
Liam, those pairings seem fine to me :)
Some nice vapourbots there, Ill need to build up my squad for future tourneys now as only having three original vapourbots is a bit boring of me but the five realies will have to do for now.
As a team name:
Operation: Total Devastation?
The Viscious Vapours?
Tequila Mockingbird?
Team Tremour?
Team Electro Fusion?
The Cursed Pirates?
Team Aztec Gold? (Ive been watching Pirates of the Caribbean recently :))
Team Vengeance For All
1. Baldur Gamma/Whirligig 4.5
2. Black Panther/E Clawdius Unum
3. Tengu VII/Killotine: EVO
4. Achilles/Wedge Devolution
5. Salamander III/All Scoop & No Stab Make Steve A Dull Boy
6. Slammer V/Metal Sonic Spin Dash
7. ArchAngel of the Abyss/The Botles Reunited
8. Darkestar/Turbo Tails
Team Various Dinowarriors
9. Orka MK4/Another Night at the Bar
10. Leprosy Infection/Axe to Fall
11. Die-Ceratops Re-Invertus/Liar 2
12. Mega Masher 2/Back to Rock III
13. Axe-O-Lotl/Sheer Heart Attack 2
14. Obliteration/Flick of the Wrist
15. Crash Bandi-bot 3/With Or Without You
16. Spring-BOK/Diotoir
Team Chevron Insanity
17. Nitro-Gene 4.0/The Quaestor
18. MeCannibal 2.0/Phoenix Down
19. Autoism 2.0/No Objections
20. D.V.D The Sequel/147
21. Tri-Tainium/Gabriel II
22. WORCK/Nidhogg
23. The Rock/Life & Death
24. Storm 2/13 Black
Team Dunno
25. Supreme Glory Omega/ISDSFA
26. Manic Monsoon/The 6isc
27. Dervish V/Dead Horse Beater
28. Squishiest/The May Tracks Has You
29. Dennis the Meance/Tempest Evil-est-oution
30. Sonic Boom/Door Stops
31. The Woodpecker/Acronyms FTW
32. Wheely Pure Evil 2/Sakura
Team After-Life
33. Death Threat 0.2/Death Wish
34. Axes of Evil/Terrorhurtz
35. Cat With Wheels/Turbo Shredder
36. Crimson Thunder/Walk Dont Run
37. Sithis/Tornado
38. Lethal Injection/Paralyzation
39. Bigger Brother/Shrederator
40. Wild Thing/Black Death
Team SpunOut
41. Infusion Alpha/???
42. Infusion Beta/???
43. Infusion Gamma/???
44. Infusion Delta/???
45. Infusion Forza/???
46. Infusion Helix/???
47. Infusion Torsen/???
48. Infusion Faux/???
Jamie McHarg and Liam Eliot (need team name)
49. Pussycat/Robochicken
50. Kronic/Alpha-Rex
51. Drumroll SR/Hatchet
52. Dr. Acula/LockJaw
53. Firefly/System Shock
54. Sewer Snake/Gulp
55. Tough as Nails/Henry VIII
56. Big Nipper/Marwolaeth
Team Jimbob
Namies Style
Secret
Razer
Typhoon 2
Turbulence
Mechavore
Dantomkia
Hexadecimator
Push-Ish Fundamental
We All Face the Same Way (It Takes All Day)
Calm Down Dear (Its Only a Robot)
Son of Wedgie
Cuffy
Flipping Mad 7
The Circle Revisited
Van Tango
Need Dave and Chezza to pair their bots, Liam and Jamies team name, and AJs entries, and I can start this. :)
Okay here are my pairings with David. Sorry it took sooooooooo long! _
Namies Style with Son Of Wedgie
Secret with Cuffy
Turbulence with The Circle Revisited
Typhoon 2 with Calm Down Dear (Its Only A Robot)
Mechavore with Flipping Mad 7
Dantomkia with Push-Ish Fundamental
Razer with Van Tango
Hexadecimator with We All Face the Same Way
There ya go. Ugh my head.
Okay, lets just see if Dave agrees with that though.
Didnt you get Andys bots a while back?
Hes working on an all-new squad, or so hes told me.
I have seen rough versions of PsycloniZer (just did a CAD of it for him lol) and Axeon 3.0 on his forum.
Right. Tell me when hes got them in, so I can get out of the nursing home, find my glasses and get down to an internet cafe to do my tactics :proud:
Will do. XD
I like the sound of Team Operation Devastation Jamie:)
First of all, I apologise to everyone for the delay. Here, finally, is a confirmation of Team SpunOuts random entries! :proud:
Infusion Alpha / http://teamcode14.proboards24.com/in...d=12&page=1#26
Right. Now for Dave to confirm Chezzas team-ups and I can start with the line-ups. :)
Cool Liam, lets go for that then shall we? :)
Right you are Jamie!To make it easier for Kody Ill do our finalised team name and line-ups:
Pussycat and Robochicken
Kronic and Alpha-Rex
Drumroll SR and Hatchet
Dr.Acula and LockJaw
Firefly and System Shock
Sewer Snake and Gulp
Tough as Nails and Henry VIII
Big Nipper and Marwolaeth
They will do :)
Okay, the teams are:
Steven McGregor
Alex Holt
Christopher Mason
Martijn M Benschop
Paul Cuomo
Joey McConnell
22. WORCK/Nidhogg
Team Dunno
Daniel Stickler
Frank Goacher
Team After-Life
Daniel Bailey
Samuel Park
37. Sithis/Tornado
Team SpunOut
Aaron Knight
Andrew Jackson
41. Infusion Alpha/GeForce 4.0
42. Infusion Beta/Wedgas Revenge
43. Infusion Gamma/Exertion
44. Infusion Delta/Rupture
45. Infusion Forza/Axeon 3.0
46. Infusion Helix/Monolith
47. Infusion Torsen/PsycloniZer
48. Infusion Faux/SOR X
Jamie McHarg
Liam Eliot
Team Jimbob
Chezza
David Sheppard
57. Namies Style/Son Of Wedgie
58. Secret/Cuffy
59. Turbulence/The Circle Revisited
60. Typhoon 2/Calm Down Dear (Its Only A Robot)
61. Mechavore/Flipping Mad 7
62. Dantomkia/Push-Ish Fundamental
63. Razer/Van Tango
64. Hexadecimator/WAFT
And thus, your complimentary line-ups :proud: are...
Heat A
Firefly & System Shock vs. Sonic Boom & Door Stops
Achilles & Wedge Devolution vs. Orka MK4 & Another Night at the Bar
Infusion Helix & Monolith vs. Bigger Brother & Shrederator
Mechavore & Flipping Madd 7 vs. The Rock & Life and Death
Heat B
Namie€™s Style & Son of Wedgie vs. Slammer V & Metal Sonic Spin Dash
Infusion Alpha & GeForce 4.0 vs. Tough As Nails & Henry VIII
Sithis & Tornado vs. Crash Bandi-bot 3 & With Or Without You
Autoism 2.0 & No Objections vs. Wheely Pure Evil 2 & Sakura
Heat C
Dr. Acula & LockJaw vs. Axe-O-Lotl & Sheer Heart Attack 2
Supreme Glory Omega & ISDSFA vs. Turbulence & The Circle Revisited
Axes of Evil & Terrorhurtz vs. Baldur Gamma & Whirligig 4.5
MeCannibal 2.0 & Phoenix Down vs. Infusion Gamma & Exertion
Heat D
Manic Monsoon & The 6isc vs. Tengu VII & Killotine: EVO
Cat With Wheels & Turbo Shredder vs. Infusion Delta & Rupture
Obliteration & Flick of the Wrist vs. Secret & Cuffy
W.O.R.C.K. & Nidhogg vs. Pussycat & Robochicken
Heat E
Nitro-Gene 4.0 & The Quaestor vs. Black Panther & E Clawdius Unum
Infusion Torsen & PsycloniZer vs. Dennis the Menace & Tempest Evil-est-oution
Razer & Van Tango vs. Wild Thing & Black Death
Leprosy Infection & Axe to Fall vs. Sewer Snake & Gulp
Heat F
Death Threat 0.2 & Death Wish vs. Mega Masher 2 & Back to Rock III
The Woodpecker & Acronyms FTW vs. Tri-Tainium & Gabriel II
Darkestar & Turbo Tails vs. Infusion Faux & SoR X
Hexadecimator & WAFT vs. Kronic & Alpha-Rex
Heat G
Infusion Beta & Wedga€™s Revenge vs. Dervish V & Dead Horse Beater
Storm II & 13 Black vs. Salamander III & All Scoop & No Stab Make Steve A Dull Boy
Drumroll SR & Hatchet vs. Die-Ceratops Re-Invertus & Liar 2
Lethal Injection & Paralyzation vs. Dantomkia & Push-Ish Fundamental
Heat H
Spring-BOK & Diotoir vs. Big Nipper & Marwolaeth
ArchAngel of the Abyss & The Botles Reunited vs. Infusion Forza & Axeon 3.0
Squishiest & The May Tracks Has You vs. Typhoon 2 & Calm Down Dear, It€™s Only A Robot
D.V.D. The Sequel & 147 vs. Crimson Thunder & Walk Don€™t Run
Tactics, predictions, comments, thoughts, and a retcon please. I think Ill need it. :proud:
Kody, could you use the new names for my bots?
Alright, Ill do that when the fights start. Sorry about that.
TACTICS
Tactics for Tag Teams dont usually work. They just end up going out of the window after two seconds, either by both members of each team coming out at once or by one of the partners breaking down or doing something stupid.
Ill wait for Martijn to see what he thinks we should do. For now, Im taking things one Heat at a time. For Orka/ANATB, I dont mind going out first.
Some Tactics for Team Operation Devastation:
A:
I think me and Jamie will be OK here. I can easily shove Doorstops around, Ill try to pit them, and I think SS can deal with Sonic Boom as well. Firefly can take out Doorstops with no problem either.
B:
Were screwed here, Jamie! Maybe TAN could try and pit GeForce while Henry has a bash at Infusion.
C:
Im actually happy about this draw. LockJaw will home in on SHA2s tracks, I think Dr. Acula can cope well with Axe-o-Lotl.
D:
Once again, no hope wahtsoever. Pussycat may have a chance against Nidhogg, but Robochicken will be useless against both of them... RUN AWAY
E:
A really tough one, but not all hope is lost. Gulp may be able to knock Leprosy OOTA by stacking it then lifting again. Sewer Snake should be able to roll Axe to Fall around, and if Leprosy falls I can come to help.
F:
No probs. Go for a double OOTA, Hexi-Decimator is TOAST, then we can team up on WAFT Jamie.
G:
I think this is another loss, but I think Drumroll should go for Die-Ceratops while Hatchet tries to pit Liar 2 by ramming him from the side.
H:
I like the look of this one very much! Big Nipper can lift Diotoir onto its back so Marwolaeth can destroy Spring-BOK.
Any other ideas Jamie?
Word of advice Liam...at least find a flame pit and put BOTH of us on it. I didnt create Spring-BOK and pair him with Diotoir for nothing.:wink:
OK Chris!
New tactics for our Heat H battle:
Big Nipper can grab them, lift them and toast them, then Marwolaeth can destroy them!!:-)
mkay Chris, Orka can go first in this flipper-orientated match of us ;)
