quote:
it does look to me as if the discs blades are going to hit the self righter quite a bit :P
Illusion. Your eyes must be deceiving you. Theres about 30mm of space in-between. :P
If you ever get bored (:proud:) you can always do an image for me Kody
You sure? Looks more like the blades intersect the self righter by 30mm :proud:
Im quite sure. :P
And even if it looks that way, CADs arent always perfect. :P (I did a horrible one of Envy before realizing the dimensions were all off XD)
Okay, I shall bow to the person whose pictures are infinitely better than mine (I was going to do all of mine in Paint but I suck at curves) and not mention the missing third tooth :P
Its blocked from view, you git. :P
Okay, whatever. Ive adjusted it a bit so Joey can be assured that his eyes are fine. :P
http://i276.photobucket.com/albums/k...c/TiraIV-1.png
...I see very little difference :proud: j/k
Jackass. :proud:
By the way, Joey, ffffff>your secret request is halfway done. :)
Can you do a CAD of Knyfe for me please? Stats are on your board.
Its not really that secret :P
Its an interchangeable robot; Im not too good with those, but I will try. Soon. :)
EDIT: Woot, 3000 posts :proud:
(Message edited by kodster on May 16, 2008)
Obligatory champagne and sadness badge, sir? :proud:
And the Macduff robots turned out alright, didnt they?
Nearly over taken Frank - and Ive noticed something as well - Ive got 1000 posts! (Technically its 1002, but given I didnt notice it before hand, Il just say woot :mrgreen:)
YAY: Im a senior vapourboteer now!
lol, Macduff the 2nd has passive interchangeable weaponry, so that was easy. And Macduff the 3rd I only did one CAD of, and that was for the lifting spikes, and none of the other weapons. :proud:
Which brings me to the question: Paul, do you want Knyfe pictured with all its attachments? (like Slammer V on Alexs site)
And yes, Id quite like that sadness badge. :proud: Champagne, Ill pass on, though. The bubbly hurt me throat at the moment.
Ill have it pictured like Slammer, but set-out like you did for MacDuff the 2nd - a picture indicating Knyfe with each of its different set-ups.
(Message edited by paulc on May 16, 2008)
Could someone please do an image of Apocalypse? I feel its my best vapour, so an image would help.
http://strickenone.proboards99.com/index.cgi?board=teamww&action=display&thread=212http://strickenone.proboards99.com/i...isplay&thread= 212
Given my massive headstart, Kody deserves that badge much more than I do:proud:
I mass produce them, so you can all have as many as you want...happy? :P
Incidentally, for posts compared to amount of time active I may have you both beat...
(Message edited by joeychevron on May 17, 2008)
Whatever. Heres your vapourbot:
http://i276.photobucket.com/albums/k...V.pngIsolation
The front and back views are the wrong way around :P and I somehow imagined it being quite a bit different (lower for example), but still good. :)
I always try and make it to scale with the dimensions, and theyre as accurate as the ones you stated, so...yeah. lol
By the way Kody - hows Knyfe coming along?
Right...I meant those dimensions to the top of the weaponry, not the top of the machine, and the sloping of the sides is...*goes into MS paint*
Sorry, Paul, I got backlogged with requests before you asked for that and I still have some to do (another one by Chezza for example), and also including a redesign of my benchmark vapour, Wedginator. When I get those done then I will start on Knyfe, okay? :)
Wedginator Devilution, coming to a tournament near you...
Oh, and Joey, the weaponry doesnt reach up to the top of the machine as far as I can tell. The disc is just a little bit off. :P
:uhoh:
Kody, check your forum.
Heh, Ill redo it.
Hence...
Okay everybody, when requesting a 3D drawing of your vapourbot/robot, if you want it as accurate as possible, do what Shane Swan did and give more specific dimensions, such as the length of a flipper, or width or a rear panel, or something, so I dont mess up due to inadequate information. :P
Thanks to Joey in advance.
Yeah...sorry about that, I kind of messed up there :P
Im scared :uhoh:
:) Looks extremely cool, Kody...kind of like Facet from S3.
Thank ye, thank ye...stats for it shall be up soon, and then I will modify Isolations CAD...no, probably redo it since its so far gone. :P
*Sees Wedginator Devilution*
EEP
*Runs away*
I really want to know more about this Kody. Are the stats ready yet? Is the flipper all around like 6.0, or more traditional? It looks EVIL
Stats in Eye of the Robot 5. :)
*reads stats*
EEP AGAIN
its a very effective front-hinged flipper Mr Kody!
Meh, its got a polycarb base. :P
yeah,watch out for my base piercin vapour!
