I read, but aotas my first thing and it is still in so we im waiting for the rest, a conclusion to this very big, very good battle, the only thing would be prehpas a couple of paragrahps, just to make it easier on the eyes.
Ill be sure to put the battle into paragraphs from now on :)
I found the old document for this on my college computer, and decided I had better finish it, but all the robots in the Rumble have evolved, so Im going to start over. First, I need 30 robots from the rumble, 2 from each competitor, and then another 20 for the Robot Battle Royale (20 robots in the ring at once)
Ok, i take it that that means i cant enter the Rumble, unless you meant for and not from the rumble.
For the Battle Royale, i choose Love Bite V 2.0 and if im allowed two, 360
If i am allowed to enter the Rumble, Natural Selection and Going Crunch. 360 will replace Going Crunch if im not allowed two in the Battle Royale
I meant to say for, as in I need 30 new ones for the Rumble. I forgot to mention, the Battle Royale is 1 vapour and 1 real per person
The Rumble, Natural Selection and 360
The Battle Royale, Love Bite V2.0 and Storm 2
Okie Dokey
Stats ASAP please
If possible, Id like to enter the following :):
THE RUMBLE:
1) Wedge Devolution
2) Killotine: EVO
THE BATTLE ROYALE:
1) Whirligig 4.0
2) Behemoth (RW7)
Stats & pic can be found here: http://thdcrobotics.proboards33.com/index.cgi?board=Bravehearthttp://thdcrobotics.proboards33.com/...ard=Braveheart
Should be another smasher, Davey :proud:
ooh good
Rumble
baldur and kali
battle royal
tengu and razer
I think...
RUMBLE
Leprosy Infection
Mega Masher 2
BATTLE ROYAL
Die Ceratops Invertus
Dantomkia (RW7)
Weight: 100kg
Dimensions (LxWxH):120x80x30
Shape: Full body invertable spinner.
Weapons: It IS a weapon all over. 28 KJ power
Armour: 4mm Titanium
Top Speed: 20MPH
Main Tactics: Circle until spinner is going full speed then attack. Careful to avoid hazards though.
Colour: Red with black writing
Strengths: High powered weapon.
Weaknesses: The ping effect and when its upside down the controls change (up becomes down) so that has to be kept track of. Also, being invertable, its wheels are vulnerable to axes.
Name: Natural Selection
Paint scheme: Green
Wheels: Four, inside
Shape: Boxlike. Scoop on the front, skirts around the sides, the back is rounded to help with self righting.
Dimensions (cm): 80/40/20 (L/W/H)
Weight: 100
Armour: 4mm ti
Weapon: A hydraulic lifting arm with vertical pincers. These are made of titanium and powered by a linear actuator, giving 400 KGs of grip. The arm is 70 CMs long.
Motors: Two Bosch motors.
Batteries: Natural Selection is powered with Hawker Genises batteries, which are placed in the rear to act as a counter-weight
Top speed: 15 mph
Turning circle: Zero
Ground clearance: 10mm (There will never be a completely flat arena floor, 0 would be unrealistic imo)
SRIMECH: The arm.
Strengths: Crushing power
Weaknesses: Slow to self right.
Robot Name: Love Bite V 2.0
Length/Width/Height: 120/30/20
Weight: 100KG
Motivation: 4 inner wheels
Speed: 30MPH
Weapon: €œWeapon type and specs€ Hydraulic pincers at 2000 psi, can damage light-moderate armour. At the front is a Firestorm type flipping arm, CO2 powered, really just a SRIMECH but it will get other bots over, not really meant to be an OOTA flipper seeing as it€™s speed and the pincers do most of the damage.
Drive: €œMotors used and voltage, style of reduction€ Bosch motors at 36 volts, gear reduction
Power: €œBattery type and Voltage & Amps€ 2 x 36 volts at 3 amp NiCD packs
Armour: €œMaterials and thickness, method held on€ 4 mm hardox, welded.
Ground Clearance: 3MM
Turning Circle: 0M
Notes: It is a double wedge with skirts around the two sides. The paint job is black with Love the Bite in red down the skirts.
After rereading the rules (no shufflers? DAMN!), Ive decided to replace Whirligig with Toby. Stats in the same place. Also, increased battery power and CO2 permitted by da rools.
Curse your fussiness, Davey :proud:
rumble
disco 5 boosted
and someone else
royal
disc-o-inferno
panicking
stats when there found/made/finished
Sorry, but thats the way its gotta be to avoid confusion.
BTW, Extra CO2and batteries have to be declared, or you may fail mid battle.
UNDERSTAND ?!
ok, Love Bite V2.0 will have 10 KG worth of extra CO2 and extra batteries, the others will have as many extra batteries as i can fit in 20 KG
Come on, I resurrected this thread for me to write a big-ass fight. I need more robots !
for the rumble both machines have around twice the weigght in batteries, in both machiesn this weight is achieved by takign weight off the wheels which make up a large proportion of thwe weight
Tengu gaisn an extra 5 kilos by dropping 2.5 kilos from each 7.5 kilo blade
kali should have ample co2 to last the fight, because the gas is stored at high pressure but released much lower it means i should get in excess of 150 flips before havign to refill
Ok Alex, Ill bear that in mind
Me and my entries
Pie of Doom HWBE - stats later
Anti-Spin
Royal
Quocunque Jeceris Stabit
Ewe 2
Anti-Spin and QJS can be found here -
http://farr.proboards21.com/index.cgi?board=TeamSolarizedStatshttp://farr.proboards21.com/index.cg...SolarizedStats
Replacing Pie, cos its a LW and looks like a pie, here is Brucie :proud:
Robots name - Brucie Bonus
Mass - 120 kg
Weapons - Long-lasting low pressure nitrogen flipper
Can it self-right - Using flipper and it can run upside down all day
Velocity - 10 mph
Turning Circle - Skid Steer
Ground clearance - Front is 1mm, rear is a massive 2 cm
Skirts - Nah
Wheel Type - Solid, 4 on same axle.
Motors - A common of Bosch 750s at 36 volts
Body Shape - Wedge front, box rear
Armour - Titanium,
Colour - Grey
Batteries - Enough to last ~ 30 minutes
Summary - Old school
Strengths - Designed to last for long fights
Weaknesses - Bit Boring
Cool, ok, added to the list
who else ?
^^The most w00tiest and Epic bump in FRA history^^
David is interested in writing this again, folks :proud:
:P You absolutely had to resurrect the oldest thread in the whole of fanfic, didnt you? :proud:
Ill enter if I still can...
Hehe, thanks Kody
Ok, starting from Scratch, I need 15 builders to enter 2 bots each, shufflers get no additional weight advantage, however all robots get an additional 20% weight allowance for CO2 or higher capacity batteries, one of which must be stated beforehand
Lets see those bots, fellas
reserve me a spot
3 friggin years...
Righty...give me Phoenix Down (with claw and saw setup) with 22kg extra in batteries, and No Exceptions, with 20kg extra.
Stats: http://strickenone.proboards99.com/index.cgi?board=chevhwhttp://strickenone.proboards99.com/i...i?board=chevhw
20 kg extra of what ? CO2 or batteries ?
Well, seeing as there are no pneumatics in the robot whatsoever...batteries, plzkthx. :proud:
Also, FYI, I will allow the 10kg addition for Tracked robots
30 robots, down to 1...its gonna be freakin carnage!
Ok then, Ill enter Symmetry with 20kg worth of A123s. That will keep me going for an hour at least. :proud:
For the second one Ill use Sideswipe, also with 20kg extra batteries.
For stats:
http://www.insaneclown.nl/vapourbots/http://www.insaneclown.nl/vapourbots/
save me 2 spots
Reserve me 2 spots as well please. :proud:
Slammer and Baldur
Increase on batteries for both
http://www.alexjholt.tkwww.alexjholt.tk
Bad Temper Jr and Spring-BOK! please.
STATS UNDER NORMAL CIRCUMSTANCES...
BAD TEMPER JR
Weight: 80 kilos
Body Shape: Rectangular, long and low. Similar dimensions to Tornado, but not invertible.
Speed: 12mph
TC: 0
GC: 7mm
Wheels: 4 inner
Armour: 6mm titanium
Power: 3x 12v batteries, powered by S28-400 Magmotors, at 24v...the usual.
Colour: Red underbelly, black sides, grey top, white weapon.
Weapon: Pneumatic knife blade, powered by CO2. Theres about 40 odd hits in it. Basically, it looks like someone stuck the blade of Overkill onto the axe arm of Dominator 2.
Srimech: The weapon goes that.
Notes: I have a little Lego model if you need pictures.
Strengths: Persistant.
Weaknessess: The arm is fairly long, so it has to be a distance away to work effectively.
SPRING-BOK!
Weight: 100 kilos
Body Shape: Firestorm.
Speed: 12mph
TC: 0.
GC: 0 at front, 7mm at sides.
Wheels: 2 inner.
Armour: 8mm titanium, covered in 2mm orange fur.
Power: 3x 12v batteries, powered by a couple of Magmotors (S28-400s).
Colour: Orange, thanks to the fur.
Weapons: A launch pad. Heres how it works...basically, the robots drive up the wedge, then the front panel, which is attached to four large car springs, fires outwards via hydraulics. A miniture piston device is attached to the panel to prevent it getting fired off, and also re-sets it. Should that fail, it does have a back-up plan (see notes).
Srimech: Two arms that extend around the side of the body, a bit like that of Philliper, only bottom hinged rather than top hinged, act as the Srimech.
Inspiration: Its named after an antelope.
Notes: This is the re-make of the former comedy yet highly sucessful robot Fluffitor, who won a previous Children In Need special. Has an in-built police siren which it activates if the going gets tough. The idea is that the oppodent will think hes about to be arrested then run off.
Strengths: Experience, unique weapon.
Weaknesses: Untested, Flammable, back-up plan probably wont work.
STATS FOR FRARRR PURPOSES...
Bad Temper Jr will have 20 kilo extra in CO2 to power his knife blade, whilst Spring-BOK! will have an extra 22 kilos of weight in batteries. I say 22 because his fur is ALSO being removed (yep, you read that right!).
I think Ill give this a miss....
PSYCH!! :proud:
Ill enter Supreme and Noo Monsoon, both with 20kg of extra battery power. :)
Stats can be found here:
http://strickenone.proboards99.com/?board=teambv&field=ordertime&order=desc&page=2http://strickenone.proboards99.com/?...rder=desc&page =2
THIS SHOULD BE GOOD!!
I am so pleased with the response thus far
Alex: Which weapon set up do you want?
Id like to enter my first two vapours
Twister and Drumblebee, stats and pictures up soon
Here are the stats on Twister Evo my first vapour
Shape: Circular, with optional skirts
Colour: Yellow for the body, grey for the wedge, blue for the main section of the arms, red for the small angled sections of the arms and black for the 2.5 KG hammers
Speed: 10MPH
Weight: 100KG
Armour 5MM Hardox, skirts are 6MM Hardox
Chassis: 4MM steel box section
Drive: 2 NPC 1200s @ 36V
Power: 4 36V NiCad battlepacks
Locomotion: 2 aluminium wheels with vulkalon treads, 5MM in diameter and 3MM in width, with 2 front casters, all wheels are partially inside the body
Ground Clearance: 2MM without skirts, 0MM without skirts, 0mm at front and sides of wedge
Turning Circle: Zero thanks to 2 front casters
Size: Bodys diameter is 45CM, main part of wedge is 20CM wide and 40Cm long, side parts of wedge are 10CM wide at widest point
Weaponry: 4 arms leading to a 2.5KG hammer on each arm, plus a complicated gray fur-covered wedge to scoop up PREY!, sorry victims, I mean opponents, the fur is to hopefully either trap the opponent or provide a spectacular fire show
Srimech: May self-right when it spins upside down
Strengths: Will obliterate anything it touches, strong armour, everything should hopefully stay far away
Weaknesses: May not self-right, battery life may be short
BIO, OBLITERATION!!!!!!!!!!, nothing else, worse than a nuclear bomb
not bad for a first try huh
