That's class man. Gonna FSU
Thanks guys. I'm going to skim the belt groove down a touch (I can't go much as the disc pins are just beneath) which will hopefully make the belt a little less tight.
I have started with the wedge now, it's in place here, tomorrow I'll make up all of the spacers (and change the outer bolts, those ones aren't final) and grind the leading edge. Still got tons to do!
Some pics, please excuse how grubby it all is, white HDPE is the ultimate in making workshop crap visible. ;)
http://i1088.photobucket.com/albums/...0042shrunk.jpg
http://i1088.photobucket.com/albums/...0043shrunk.jpg
http://i1088.photobucket.com/albums/...0045shrunk.jpg
Thanks again to Mario for organising and welding up the wedge.
So swish man, flash git you.
So many awesome custom parts! Rango makes Conker look like she was bought off the shelf. This is just amazing! :-D How long have you spent building and working on Rango? 48 hours, 72 hours of solid work? More?
Looks a nice clean build
Will the wheels have some tyre or something on for grip?
Yeah, very interested to see those wheels with tread on; the huge contact patch should mean excellent pushing power.
Thanks guys. Yes, tyres are on. Did a very very brief test drive in the living room (front is too low to test properly) but in that time the ESCs got very warm. I haven't a clue why. The reduction is now rattly-loose-smooth, I really don't understand it. The 885s have got buckets of power demonstrated by the test, but even the 14awg wire was getting warm after just 40 seconds or so of barely touching the drive.
Don't know what else can be done, I'm amazed that the amp draw must still be so incredibly high. Almost undoubtedly, the tz85s will implode half way through fight 1...
Are you sure the battery isn't shorting eg. Across the motor casing? Or is the reduction from the motors too high? Are you running off 6s? Do the motors get at all hot?
It sounds like something must be wrong! Have you tried running with the belts taken off?
No issue in the wiring for sure, have checked. Running 5s. With the belts off there's no load and it goes fine, but that doesn't really help, it kinda needs the belts :b
Motors barely get warm.
I wonder whether this is the first bot to be running relatively low reduction (5.75:1 on 75mm wheels is more than many) with tz85s. It rolls to a stop rather than stops suddenly like T2 always did. Perhaps the braking function of the tz85s is fighting the forwards momentum of the bot, and because grip is so high with the phat tyres, they're being overridden, and as such are shunting power around constantly with no where to go but back into the ESCs.
Aaron? Any ideas?
edit: to clarify, that is indeed what is happening in terms of visible behaviour. It rolls to a stop whereas our other bot, T2, running 24:1 planetaries, stops dead.
In all honesty I think it's your ratios that are way off. What sort do RPM are those 885 motors rated for? On my astro's, which are about. 620rpm per volt I used to run 15:1 with 75mm's as it was fast (9mph on 24v)) with bags of torque. I've lowered the ratio to 16:1 on Killer Joule with the same wheels. If your motors are a similar speed to those then that will be your issue. It's only the Genuine speed 900BB Torque motors with a low enough RPM to run that kind of ratio.
I had speed 900's in 540 with 80mm wheels on 7:1 and even without magnets the motors kept blowing...bonx is 9:1 I think and his motors still get warm with 2wd...
Satanix 1.66 uses Graupner speed 900@5S on a 6-1 gearratio to 130mm wheels.
No blowing motors.
Skyfall ran S900s on 7:1 with 120mm wheels on 6S, motors got warm, but never the TZ85s
Have you checked all your drive shafts are straight and that everything is running true? There may something that is causing lots of friction which could be messing things up.
What about a dud TZ85?
Those robots are 2wd with so gle stage spurs though so hardly any resistance to turning. At just over 5:1 and 4wd with bevel gears and belt drive I think that's the problem. To reduce the strain it might be worth really narrowing your tyres to reduce the friction when turning and see if that helps at all.
Another suggestion that Alan just mentioned (discussing it now over dinner) is to leave the tyres on the front wheels and leave the back slippy. That will give you skid steer like venom/360 etc and majorly reduce the current draw when turning.
Considering the ESC's ran Tormenta 2 fine I don't think that is the problem.
If the escs were fine previously then it's for to be the new drive... Tormenta was only 4 drill motors... Big difference!
Is there much heating when you run the bot with the wheels off the ground? if there is still heating, then the problem will be friction in the bearings, if not, then the reduction is too low. The critical thing is to find the specs on those motors.
Specs, as far as known. 18V 15 Krpm 18A nominal.
I make that 26 miles per hour assuming 15krpm, 5:1 reduction and 75mm wheels.
Sounds too fast to me especially for a machine with so much grip.
But my calculations could be wrong!
OK, so the KV is about 883 giving about 18,500 rpm on a 6S pack. divide that by 5.75 and the axle speed is a whopping 3,217 rpm - there's the problem!
Hi guys. The motors aren't that fast. They are no load 10,700rpm @ 18v, commercially rated as 600w, idle draw under 3a and stall amp draw of 65a, max torque of 541 mNm - according to the site from which I bought them. Through the 5.75:1, at 5s, with 75mm wheels, that's give or take a maximum theoretical of 16.7mph. The rev per volt is only a little higher than the graupner BB speed 900s.
I based my reduction on robots such as Satanix, which, being geared for a theoretical over 25mph, and others being geared for even more, seem fine. I'm not directly comparing to those setups - different motors etc, realise that. There is no longer any resistance to speak of in the reduction, it's smooth and rolls to a stop. It might well be a combination of things, the grippy tyres and the low reduction, plus the motors having to run at near-stall much of the time. But the reduction isn't that nuts. If the motors were straining so hard I'd expect them to get hot and they never even got warm, whilst the speedos did.
The problem has changed. Amp draw before was high because of the belts being too tight for the unsuitable wheel bushes, but now that is out of the equation. I do expect amp draws to be high considering it's a hungry drive setup, and it might well simply be too steep, but not in the amount of time I was poking it to like 1/4 throttle for about 1 minute before stopping, to feel the speedos. I didn't even turn much lol. Unless the amp draws are truly insane then surely the 85s would take it in their stride whilst the motors ate themselves?
^Which is why I suspected the braking function might possibly be related. It definitely rolls when it should brake, and it brakes when off the floor, so related to this or not the speedos are probably not very happy. I can see if this is relevant when I get the V2 tz85's and test them come Wednesday/Thursday.
Speed 900s have a no load speed of 6500rpm, so the difference is a bit more than you might think!
Edit: derp, that's at 12v :P
Anyway, at 10,700rpm through a 5.75:1 gearbox and 75mm (2.95") wheels, I make the max speed 32.7mph... there's your problem.
Edit 2: if you double the rpm of a S900 you get 13000rpm; as I was running them at 6S on 7:1 through 120mm wheels, shouldn't that give a top speed of about 50mph!? It can't be right, the setup goes about 25mph as the rpm quoted on the S900 data shows... I'm confuse.
I think your maths must be a bit weird... you're getting roughly double the theoretical max speed for both setups. :P
Ellis, according to my calcs your 10700rpm with 75mm wheels with 5.75 reduction does give 16 mph
If you put some loses into that then the top speed should come down a little
Do you have a torque graph for the motors to see where they are operating in their performance curve?
I think you were putting in 2.95" in the tyre radius box- 2.95" is the diameter so the radius is 1.475". This then gives an answer of 16.3mph.
It sounds like it must be the motors struggling if it works fine on the bench then gets hot on the ground. Maybe the specs you were given were wrong, like some of the fake s900 had unrealistic stats?
A Speed 900 can not do 10'700 RPM. When I ran them in Conker 1 and 2 as weapon motors the disc basically did the same speed at 6S ans 10S within I think it was 300rpm of eachother at around the 8000rpm mark. But when on 10S they had far more torque than 6S.
Going back, I agree with what Alan suggested abut removing the rear tyres and trying skid steering. Its far from perfect but may solve your drive issues. And it won't leave so many tyre marks in your swimming pool.
Have a little faith in Ellis, I think he is capable of working out speeds correctly.
Also these aren't "fake speed 900s" I think that was just used as an rough approximation as they are large motors.
Maybes we need to look at fan cooling rather than just spamming numbers?
I think these are the data sheets:
http://www.pollin.de/shop/downloads/D310507D.PDF
They say 21 000 rpm no load,
10 700rpm 67A at max torque
and 132A stall
Hi Max. Yep that does look like the specsheet, actually from the site I bought the motors, and indeed, you're right, it says 20,000 odd rpm and a massive stall draw. Well, crap. Pollin.de on their selling page list the motors as 10,700rpm @ 18v as did another source from which we purchased last year. Their selling pages are wrong then, and that is where the problem lies, they're misinformed and as such so was I. I never even saw the button to see the datasheet but of course it's obvious as day now.
So I built this around what I believed to be motors running at 10,700rpm @ 18v as per the listed specs on the website. Lol. People will have to believe me when I say I would not have built this like this if I had seen that specsheet sooner. It's of course, way way off, 6:1 is nothing like enough. I'm now surprised it even moves under its own power. It does, and very well, wheel spin was easy for the short time I tested on rustic grippy tiles. I'm still kinda surprised the ESCs get hot whilst the motors are pretty much room temperature.
Well it's way too late to help now, robot is kinda doomed haha.
Thanks again for the help. I had fully intended to run different motors for next year anyway, looks like that upgrade process will be a rapid and automatic one.
This whole project was an experiment and an exercise, so I could learn as much as possible for my first featherweight build. It has succeeded in that respect. Shame it'll probably eat itself in fight 1! Blarg!
edit: 21000 @ 18v, no bloody wonder
edit2: anyone got any speed 900s :D :D :D :D with access to the right tools they could be dropped in quite quickly.
i have 1 of the cheap ebay 1s if you can find another, shaft seems to be 5mm
I have one I found in a box, I think it was a spare from Conker 1 that I lost. It smells fine, I will bring it to GSL.
Would something live this do? http://www.cornwallmodelboats.co.uk/...mfa1114_1.html
Here is the Data sheet: http://www.mfacomodrills.com/motors/800.html
And here are some real Speed 900's: http://www.westbourne-models.com/Mod...-2084-ext.html
I am sure if you ordered them to have them rapidly posted to the Robochallenge building that Grant could bring them in for you on the morning of the event.
We're looking at similar things now. Would using one and using the dual rates/fancy arse magic on the DX6i make those a viable choice?
spotted these on ebay
http://www.ebay.co.uk/itm/MODEL-BOAT...item2ec7531693
The 885s are 49mm in diameter and the width between bulkheads is 100mm, so to fit larger motors (the torpedo 800, 850s, or any 900 size can) the main bulkheads would have to be pocketed a bit and the bolt pattern in the mounting plate moved/slotted to the side a few mm. So not something that can be done on the day sadly. A powerful enough 775 could work but I can't find many that are between low revving and gutless and the fast ones such as the banebots ones.
Will try the existing setup on radically reduced rates from the tx as Harry suggests and see what effect that has.
What brushless motors could you run? There must be something with the same mounting points that you could use. Question is getting the parts in time.
Unfortunatly, no 900's without gears available atm.
But, adding a few grams of dry ice to cool the TZ's can't be that big an issue.
