Creepy!
Creepy!
Would this do to go on my bottles a on/off?
http://www.screwfix.com/p/full-bore-...lve-15mm/80413
F.P.?
NO..there's no indication of a pressure rating which will be a LOT less than 60 bar.
No lp 10 bar system and ok thanks
just use one of these for LP http://www.technobotsonline.com/pneumat ... alves.html
I got a feeling that ninja will turn to a 2WD rambot and my second bot a pneumatic one made from plastic ( we have given up welding and doing bolts and stuff like that) so expect more work soon! :proud:
The bot will have a swap of weapons later on in it's life: a drum spinning, a blade and some spikes :twisted:
just to warn you. i tried something similar and its difficult! before you even start cutting anything, make sure your designs are perfect!
Update!!:
First the frame is done and yes i could of had it done alot sooner if I did some in may, June, July but hay ;) base plate and one side Panel are on. Base was from a old boiler And the side panel was from a cooker plate thing ( u know what I mean!). The top and other side will be done tomorrow. Side again the cooker thing and top a different old boiler. So far it weight 4kilos and with that I'm thinking of 4wd =)
Good day (haat films there( minecraft peeps)
*pictures up tomorrow
How many amps does a 14.4v motor draw under fighting use?
