i was thinking that, i would be impressed if that all fits into 13.6kgQuote:
Originally Posted by harry hills
thats going to be a real pain in the proverbial to turn, mabey shorten it and add curved edges/not so flat, as a spinner will just rip into those flat edges, also make it look cooler 8)
looking great so far though!
Jack
oh bugger, my feather is mostly flat edges :?
Just to give you it's size at this time, it's 21 inches long, 15 inches wide and 9cm tall.
It may have a lot of air space but think about it, it will be difficult for robots with axes or crushers to get at my components.
I was never going to leave my edges flat, I'm going to put them in a angle, somewhat like sloped armor.
And with all the components and armor (5mm Aluminium Plate) in place, it weighs 11.7kg.
its twice as long as mine!!
no inuendo intended :proud:
my feather is only 32cm long (not inc claws) but all the parts weigh around 13 kg
if you can gut it all in the weight limit then go for it, but i would bring the wheels closer together if you can because that will be a nightmare to turn
mine is about the same size but only 4kg :oops:
just shove on a load of hardox
thats your awnser to everything nowadays :(
double post
