Harry, do you want to pm me with a list of stuff you want because i don't fancy fishing through here to find things. :proud:Quote:
Originally Posted by harry hills
Hi. I'm not completely familiar with some of valves you have here. I'm interested mainly in anything that releases instantly with as little obstruction for air passing through as possible. I am building an air gun, and slow releasing butterfly valves no longer cut it. Please enlighten me if you can on exactly how these valves work, are the electrically driven? What kind of pressures can they handle? Quick releasing? Standard plumbing style fittings?
Thanks. :)
OK, last little bits for the moment:
Two, 1mm stainless steel folded chassis. Probably pretty good for kilobots and stuff. Dimensions are 180mm wide x 160mm long x 30mm deep - £7.50 each.
http://www.teamhydra.co.uk/wp-conten...69-300x225.jpg
Five pieces of 1mm stainless steel
1 of - 235mm x 160mm - £3.00
2 of - 185mm x 320mm - £4.00
2 of - 480mm x 170mm - £4.50
http://www.teamhydra.co.uk/wp-conten...70-300x225.jpg
The 5/2 valves are suitable for low pressure pneumatics (10bar). They are electrically driven and operate in about 300ms. They use 1/4 fittings not standard plumbing fittings. A 5/2 valve allows a double acting cylinder to be used (push/pull cylinder) but you can blosk off one of the ports to make a 3/2 valve which will allow you to use a single acting cylinder.Quote:
Originally Posted by Relentless
list of stuff on ebay http://shop.ebay.co.uk/andy5555555555/m ... ksid=p3686 would be happy if people want to make me an offer for stuff. Can only say no can't I :proud:
OK, I know I said that was it for a while but I found a bit more today:
Three 20oz paintball bottles with screw type C02 valves - £30each
http://www.teamhydra.co.uk/wp-conten...79-150x150.jpg
Six Robochallenge drill motor mounts - £12.50 a pair
http://www.teamhydra.co.uk/wp-conten...81-150x150.jpg
Fire extinguisher valve - £7.50
http://www.teamhydra.co.uk/wp-conten...76-150x150.jpg
24V featherweight Gold motor - £20
http://www.teamhydra.co.uk/wp-conten...75-150x150.jpg
Featherweight drive gearbox. With 2 x 24V gold motors, mod 1 gears and 75mm wheels fixed to a piece of aluminium. Good base to start a feather - £70
http://www.teamhydra.co.uk/wp-conten...72-150x150.jpg http://www.teamhydra.co.uk/wp-conten...73-150x150.jpg
Featherweight drive gearbox. With 2 x 24 gold motors, mod 1 gears and 63mm wheels fixed to a piece of aluminium. Come straight out of our featherweight Cylon. - £70
http://www.teamhydra.co.uk/wp-conten...87-150x150.jpg http://www.teamhydra.co.uk/wp-conten...85-150x150.jpg http://www.teamhydra.co.uk/wp-conten...86-150x150.jpg
Set of Mod 1 gears fitted to 75mm wheel and 8mm hole for motor gear. Meeds making up into a gear box. Will fit any motor with 8mm shaft - £15
http://www.teamhydra.co.uk/wp-conten...71-150x150.jpg
Modified Argos 9.6v drill motor - £7.50
http://www.teamhydra.co.uk/wp-conten...77-150x150.jpg
i get the feeling that clive will be interested in those 24v golds
Well he best be quick then hadn't he!! Two already sold.
