Re: Oh No!!! It's VRW 5!!!
What he's saying is ask for less robots.
Also, I'm using All Bar One and something I've named Frustum when I can make the parts fit and the stats have been checked.
Name: All Bar One
Weight: 100 kg
Shape: A very wide paralelogram wedge
Colour: Battleship Grey
Dimensions: 33cm * 110 cm * 14 cm
Drive: 2 * LEM 130 (95S) on 49.5 V with 6 * 15 cell A123 ANR26650M1 battery packs
Locomotion: 2* 15cm diameter 5cm wide titanium hubbed wheels covered in urethane rubber
Armour: 7mm hardox on the wedges, 5mm hardox top and bottom, 10mm hardox on the ends and heavy shock proofing to protect vital components
Speed: 29mph
Ground Clearance: 0mm at the wedges, varies along the sides to 5mm at the back although technically more due to inverted wedge
Turning Circle: 0 cm
Weapon: Translational spinner and rammer dishing out 8.4 KJ when top speed ramming
While spinning:
18.2 KJ @ 500 rpm
73.1 KJ @ 1000 rpm
(now it might kill itself)
164.5 KJ @ 1500 rpm
292.5 KJ @ 2000 rpm
Srimech: Invertible
Notes: A bar shaped translational spinner that can ram if stopped spinning due to it having two wheel drive.
The robots innards are pushed as far as possible to the sides to maximise weight there with the center being hollow.
I pretty much just said what you said.
True :P but Mark doesn't understand anything when I say it
alright then. All you have to enter is 4 vapours(you can use realies if you don't have enough vapours), and I'll automatically eliminate 2 robots from the 3 people entered. Mainly the lower-ranked robots, as they aren't necessary.
Samuel Park
1: Theseus
2: Paralyzation 3 (11)
3: Mecha's Revenge (3)
4: Return of Black Death
Jack Orr
1: CrOoKeD eVo (9)
2: I.A.N
3: O.I.D
4: Pickaxe of Doom
Lian Walsh
1: Merry Hampton
2: The Servant
3: Dr. Thwack
4: Druid
Jordan Brown
1: All Bar One
2: Frustrum
3: ???
4: ???
mark i have a bit of a problem with the percentage rule
because it might become a shouting match over who should have won
if i were you id stick to fights so its more of a fair way of dealing with it
im not saying its a bad idea but jordan is right about the intercontinetal shouting match :uhoh:
without meaning to offend, this is just an accident waiting to happen,
what i would do: write fights rather that percentages, but TAKE YOUR TIME! write nice long fights (which means the fights are longer than the intros!) im not saying making them as long as the likes of kody and aj etc but make them long anough to make them entertaining :mrgreen:
cos the percentages will just end in disaster :wink:
Fine then, but if people start pointing out that I'm making major errors, then I'll switch to percentages. I don't want to ruin what's left of my career.
Je voudrais Tough As Nails et Terrorhurtz comme mon deux autre entres svp.
what?
