Re: VRW Series 4 Sign-ups
Pete(The mysterious guy who came up with the new Hyper Death IC) has decided to enter the competition, so there are 2 spaces left.
Samuel Park
1: Next Stop, Jupiter
2: Whiplash (1)
3: Walk Don't Run 5
4: Neo-Mecha
5: Blue Hurricane
6: The 2nd Revenge of Black Death (8)
7: Envy
8: Storm II (2)
Jack Orr
1: CrOoKeD (10)
2: Pickaxe of Doom
3: Oh! I'm Dizzy! (O.I.D)
4: Boxx
5: Behemoth
6: 259
7: Terrorhurtz
8: Mythras
Liam Eliot
1: Apocalypse II (3)
2: Maximum Genocide (6)
3: Lockjaw v3 (15)
4: Brutalis 2.1 (7)
5: System Shock V: Hex (5)
6: Elizabeth
7: Ringmaster
8: Gyrobot
Pete
1: Hyper Death IC
2: Deathyboy
3: Razer
4: Typhoon 2 GS
5: Firestorm 5
6: Tornado
7: Bigger Brother
8: Vader
1:
2:
3:
4:
5:
6:
7:
8:
1:
2:
3:
4:
5:
6:
7:
8:
Actually, because I was bored out of my head, I decided to resurrect some(one's) vapours (which are actually mine)...there are only 6, though. So...I'm *GASPSHOCKHORROR* entering! But under a different team name:
TEAM TITANS
Robin the 4th
Shape: Voltronic with angled curved sides, but invertible.
Colour: Red, green, and yellow.
Weight: 100kg
Drive: 2 Jiang Minis run @ 42v
Power: SLA batteries
Motivation: 3WD inner
Speed: 25mph
Armour: 7mm carbon fibre on the front wedge, 12mm Hardox everywhere else
Ground Clearance: 5mm (0 for the wedge and forks)
Turning Circle: 360
Dimensions in CM (LxWxH): 95 x 100 x 25
Weaponry: Huge lifting forks that take up the length of the wedge and more, powered by the same linear actuator system Darth Dread used for its hammer before the stats got changed. Can hoist 500kg.
Srimech: Forks, but it can run inverted.
Strengths: Fast, pushy, powerful.
Weaknesses: Slade
Starfire the 4th
Shape: Box with curvy upper edges
Colour: Magenta, orange, blue, bit of green, yada yada...
Weight: 99kg
Drive: S28-150 MagMotors run @ 36v
Motivation: 2 inner
Speed: 10mph
Armour: 10mm Lexan with an aluminium boron carbide chassis
Turning Circle: That of a pizza machine.
Dimensions in CM (LxWxH): 105 x 95 x 35
Weaponry: A 20kg vertical spinning disc (powered by a LEM200 motor) that is on an arm that can lift the disc 180 degrees, from below to up top, linear actuated.
Gimmicks: A lightweight pneumatics system powers 8 rams that punch out from underneath Starfire to send her into the air and on top of another robot.
Srimech: Arm
Strengths: Destructive, versatile, has the power of gloorg on her side!
Weaknesses: Mustard
Raven the 4th
Shape: Mauler 5150
Colour: Dark blues, dark purples, blacks
Weight: 99kg
Drive: 2 Sinclair C5s run @ 24v, very reliable motors
Power: Motorbike batteries. But small ones so they can fit
Motivation: 4 omniwheels, so she can move wherever she wants to in a hurry
Speed: 11mph
Armour: 20mm tiriliumcarbonate alloy shell, with 6mm plasma nitrite on the top and bottom
Ground Clearance: 10mm
Turning Circle: you spin me right round baby right round like a record baby right round round round
Dimensions in CM (DxH): 100 x 20
Weaponry: 50kg spinning ring; has 20 hardox teeth to rip and tear. Powered by two petrol chainsaw engines, it can give out approx. 800kJ per hit! Is shockproofed with 10cm of PU foam to absorb blows.
Srimech: Invertible
Strengths: One-hit KO potential, empathy
Weaknesses: Being Satan's portal
8645T The Beast Boy 4 (or Beast Boy 4 if you're feeling lazy)
Shape: A T-shape like Ij of Ran 2
Colour: Green with silvery purple
Weight: 3386 oz
Drive: 2 D41-400 MagMotors (they actually exist; they put out 1.47 hp) and a series wound MagMotor for the weapon
Power: 6 old car batteries in mint condition. Mmm, minty fresh.
Wheels: The wheels are somewoot exposed but only if someone like PsycloniZer was coming right at his wheel. The wheels are covered by a very good plank of 7mm Weldox, revealing €œWTF€ on them.
Speed: 12.17 knots
Armour: 3.2mm Kevlar (good old Kevlar)
Ground Clearance: I€™m not too worried about this, but it€™s 2.59mm
Speed Controller: An IBC. Like IBM, but without the M and a C added.
Dimensions in CM (LxWxH): 63 x 101 x 42
Weapons: It has a 360 degree double sided axe-like bludgeons, but in the middle of them is a 6000rpm spinning disc made of aluminium boron carbide, powered by another series wound MagMotor. The bludgeons are not really damaging internally, but they sure give a pounding and can damage externally.
Srimech: It€™s an axlebot, figure it out€¦
Summary: Beast Boy has switched from being a h-disc axlebot with pounders to a h-disc axlebot with pounders and better motors
Strengths: Versatile, powerful, tofu products, the fact that these are actually realistic stats
Weaknesses: Somewoot exposed wheels if someone like PsycloniZer came right at them, can't stand steaks.
Notes: Thanks to AJ for helping with this one. The stats may be messed up a bit but I'm sure you can understand them.
Cyborg 4
Shape: Low box(er) with kilts - I mean skirts.
Colour: Metallica blue silver cyan stuffs with implant textures and stuff like that, he's basically some kind of monster.
Weight: 100kg
Drive: Perm Press 132 motors run at @ 72v
Motivation: 10WD, but he's wide so he should turn easily
Speed: 30mph
Armour: 14.7mm titanium/vanadium alloy with a 10.1mm ti/v chassis
Ground Clearance: 0mm under kilts, 25mm otherwise
Turning Circle: BOOYAH!
Dimensions in CM (LxWxH): 110 x 110 x 20
Weaponry: 2 row of 10 spikes at the front, all made of tungsten. He rams opponents with them.
Srimech: Invertible.
Strengths: BOOYAH!
Weaknesses: BOOYAH!
Terra the 2nd
Shape: Biohazard(ous Waste of Time, which is a real bot)
Colour: Yellowjacket
Weight: 110kg
Drive: 4 LEM130s @ 36v
Power: 6 NiCad Battlepacks
Motivation: Eurypterus-style tracks (yeah, THAT version of Eurypterus, Alex MW, if you're reading this)
Speed: 15mph
Armour: 25mm plywood bolted on with hardened rubber bolts. Never underestimate the power of wood.
Ground Clearance: Check Biohazard's.
Turning Circle: :elcriC gninruT
Dimensions in CM: Check Biohazard's.
Weaponry: A very large lifting arm working similar to Biohazard's, powered by an M-Mac actuator. It can lift approx. 10000oz.
Srimech: Arm(ed and dangerous).
Strengths: Based off a winning design, good weapon, metabolism
Weaknesses: Mediocre control
Plunderbird 5 (he rules into RW:ED)
Mega Hurts: LT (for comedy relief)
Now then...credit goes to AJ, Joey, and Dan for verifying all stats, so they should be okay.
And Mark, FVAL2 was resurrected, so you weren't really banned from it, but the spots still filled up before you could get in, I apologize. And I take back a lot of stuff I said earlier. No hard feelings?
...I can't remember 'verifying' those as such :P
I sent you the Notepad file, mon frere...
hi :)
1: dantomkia
2: gravity
3: iron awe 5
4: anarchy
5: pussycat
6: tilly evo
7: cabakan
8: tsunami
thanks
harry
*pushes harry off computer*
mark: can the cRoOkeD used be cRoOKeD EvO?
jack
OMG OMG OMG!!!
Kody, I accept your apology. I'm willing to admit I was being rotten and harsh to you before, and I'd like to apologize for that as well.
And lucky guys who entered FVAL2 Resurrected. I understand I wasn't quick enough.
Jack: Yes it can.
Samuel Park
2: Whiplash (1)
3: Walk Don't Run 5
4: Neo-Mecha
5: Blue Hurricane
7: Envy
8: Storm II (2)
Jack Orr
1: CrOoKeD eVo (10)
2: Pickaxe of Doom
4: Boxx
5: Behemoth
6: 259
7: Terrorhurtz
8: Mythras
Liam Eliot
3: Lockjaw v3 (15)
4: Brutalis 2.1 (7)
6: Elizabeth
7: Ringmaster
8: Gyrobot
Pete
1: Hyper Death IC
2: Deathyboy
3: Razer
4: Typhoon 2 GS
5: Firestorm 5
6: Tornado
7: Bigger Brother
8: Vader
Kody Kunz
1: Robin the 4th
2: Starfire the 4th
3: Raven the 4th
4: Beast Boy 4
5: Cyborg 4
6: Terra the 2nd
7: Plunderbird 5
8: Mega Hurts L.T.
Harry Orr
1: Dantomkia
2: Gravity(I'll assume this is Gravity 5: The latest one)
3: Iron Awe 5
4: Anarchy
5: Pussycat
6: Tilly Evo
7: Cabrakan
8: Tsunami
Okay. Since the entrant spots are filled, I will open the draw in a new thread.
