Robot SMASH!! III: Lock3d and Load3d
Actusally, swap Reventon for Shredding Madness.
Stats:
Shredding Madness (Previously Turbo Shredder)
Body Shape: Box
Weight: 100 kgs
Top Speed: 15 mph
Dimensions: 96 X 93 X 42
Armour: 3.25mm Hardox All Around
Ground Clearence: 5mm all around
Wheels: 4 X Wheels Inside (Aluminum Hub)
Power: 2 X LEM-130s running on 36 volts
Battery: 4 X BPK-3600-36 BattlePacks
Weapons: A very nasty 25kg, 3000RPM horizontal spinning disc made out of titanium, and 4 X Hardox Teeth. powered by a LEM-130 on 36V, Heavily Shock-Proofed as well
Srimech: Invertible
Strengths: Powerful Weapon, Great Pushing Power
Weaknesses: None Hopefully
1) Joey McConnell
a- Nidhogg Evo
b- Gabriel III
c- Eye of Ran
d- No Consequences
e- Stiltskin
f- Hex Appeal
g- Lights! Camera! Traction!
h- Gemini (RW5)
2) Paul Cuomo
a- Knyfe
b- Heyght II
c- Inferno
d- The Rock
e- Nitro-Gene 5.0
f- MeCannibal 3.0
g- WORCK-ER
h- Storm II
3) Christopher Mason
RESERVED
4) Martijn M Benschop
a- Back to Rock III
b- Flick of the Wrist 2
c- Liar 2
d- Axe to Fall 2
e- Sheer Heart Attack 2
f- Under Pressure
g- With or Without You
h- Razer
5) Richard Southworth
a- ???
b- ???
c- ???
d- ???
e- ???
f- ???
g- X-Terminator (RW7)
h- Nightmare (BB5.0)
6) Samuel Park
a- Deadbeat
b- Paralyzation 2
c- Bubonic Palgue
d- Fatality
e- Walk Dont Run 4
f- Shredding Madness
g- Ramminator 1 1/2
h- Tsunami (RW7)
7) Kody Kunz
a- Wedginator Devilution / Wedgin8or
b- Super Gore Revo
c- Seung Mina V
d- Tira IV
e- Killobite Hex
f- Macduff the 3rd / 4th
g- Intriguer
h- Envy
8) Daniel Stickler
a- Supreme
b- Dervish: The I337 Generation
c- Monsoon Magnum
d- Pure Evil: Back to Basics
e- Squish Reincarnated
f- Macbeth
g- Requiem
h- Terrorhurtz (Most recent)
9) Ben Read
a- Robo-Hedgehog
b- Robo-Mosquito
c- Robo-Platypus
d- Robo-Mammoth
e- Robo-Bee
f- Robo-Panda
g- Robo-Sheep
h- Axe Awe (RW5)
10) Alex Holt
a- Black Panther
b- Achilles
c- Tengu VII
d- Dante
e- Darkestar
f- Slammer VI
g- Baldur Gamma
h- Supernova
11) Steven McGregor
a- Wedge Devolution
b- Killotine: EVO
c- Spin Dash Unleashed
d- E Clawdius Unum
e- Turbo Tails
f- Whirligig 4.5
g- Traffic Warden
h- 13 Black (Extreme 2)
12) Danny Bailey
a- Crimson Thunder
b- Cat with Wheels
c- Sithis
d- Leviathan
e- Lethal Execution
f- Blue Sparks
g- Death Threat 0.2
h- Chaos 2 (Extreme 2)
13) Frank Goacher
a- Cobalt
b- Dead Horse Beater
c- The 6isc
d- ISDSFA
e- Sakura
f- Masamune
g- The May Tracks Has You
h- Firestorm (RW7)
14) Leo Van Miert
a- Mantis
b- Sideswipe
c- Eternia
d- Holepunch 2.0
e- Splinter
f- Obsidian
g- Symmetry
h- GBOD
15) Andrew Jackson
a- PsycloniZer
b- Axeon 3.0
c- SOR X
d- Ge5orce
e- Monolith
f- Rupture
g- Exertion
h- Tornado (RW7)
Just realised I counted Martijn twice by mistake, (sorry!) so there is a place still left in, and thankyou to those who are lending HRs :)
The open spots will become realie teams if they are still open when I get stats from Richard and Chris
Here are my six vapours:
Agro 3.5
Battle Raptor V
Dendroaspis
Drilla Killa VII
MORD2
SYNDOS
AGRO 3.5
Weight: 100kg
Shape: Low invertable wedge with a low square hinged plate at the front
Dimensions: 85 x 65 x 40 (cm; l x w x h)
Speed: 17mph
Ground Clearance: 0 at front due to hinged plate, 1cm at sides and rear
TC: 0
Armour: 4mm Hardox
Wheels: 2, inside robot, and RC gyro for added control
Power: 2 Perm 080s motors on 24V powered by 24V @ 12amp batteries
Weapon: The hinged plate at the front allows 0 ground clearance - it can surpass skirts with a good push. At the rear is a 10kg 3000RPM X Terminator-like vertical spinning disc at the rear, made of titanium and powered by a D-Pack.
Srimech: Invertable.
Tactics: Try to get under opponents and shove, or use the rear disc on them.
Strengths: Fast, manouverable, dangerous weaponry
Weaknesses: A little tricky to control, high ground clearance
BATTLE RAPTOR 5
Weight: 100kg
Shape: Invertable box with Tornado-like central bars on sides and rear (to prevent it resting there), painted orange with black stripes like the raptors in Jurassic Park
Dimensions: 80 x 50 x 30
Speed: 17mph
Ground Clearance: 0 at front due to low plate, 3mm at sides and rear
TC: 0
Armour: 4mm Hardox, with holes drilled in it to reduce weight
Wheels: 4, inside robot, poke out the top so the robot can run inverted, uses skid steering
Power: 4 Perm 080s motors on 24V powered by 24V @ 12amp batteries
Weapons: On the front are two electrically powered Vlad the Impaler-style lifting forks - attached to their tips is a plate which runs flat along the floor for 5cm, to get under skirts. On top is a titanium pneumatic axe with a Terrorhurtz-style blade, which pivots at a point about 1/4 of the robots length from the front.
Srimech: Axe can act as srimech. Axe blade fits inside the robot and doesnt poke out the top, so can run inverted if axe fails in resting position.
Tactics: Try to lift opponents while hammering them.
Strengths: Dual weaponry, invertable, fast and manouverable due to skid steering and lack of skirts
Weaknesses: Limited CO2 for axe, no weaponry at sides and rear, easily flipped
DENDROASPIS
Weight: 97kg
Shape: High wedge with two large enclosed wheels, painted black
Dimensions: 80 x 50 x 45
Speed: 20mph
Ground Clearance: 0 at front due to hinged plate, 0 at rear due to skirt, 1cm at side and behind skirt
TC: 0
Armour: 6mm Hardox - rear skirt is 3mm titanium
Wheels: 2 stuffed tyres inside robot, and RC gyro for added control
Weapon: Two electrically powered arms with stabilising wheels, one on the top wedge and one on the bottom, similar to Cuad the Crusher - the arm at the bottom lifts the whole wedge to overturn a robot thats on it. There is also a static spike on the left and right sides, which can be used when the robot raises itself and spins on the spot.
Srimech: Invertable
Tactics: Get under opponents with the hinged plate at the front, and lift to overturn them. Can also try to cause damage with the spikes by spinning, or push with the rear skirt.
Strengths: Fast, manouverable, versatile
Weaknesses: Lack of damaging weaponry, easily flipped from sides
DRILLA KILLA 7
Weight: 99kg
Shape: Low invertable box, painted red, with a Tornado-like low wedge at the front, and an upside down one at the back for when the robot is upside down, and skirts at the sides fixed at the centre so they work whichever way up the robot is
Dimensions: 110 x 40 x 25
Speed: 17mph
Ground Clearance: 0 at front due to wedge; 0 at sides due to skirts, 3mm behind skirts, 25cm at most at back due to inverted wedge
Turning Circle: 2cm
Armour: 5mm Hardox
Wheels: 6, inside robot
Weapon: Each wedge has a hole in the centre - inside each hole is a diamond tipped drill, spinning at 600 rpm, which comes out of the hole using a motor. It can come out to cause damage when an opponent is on the wedge, or can stay out and cause damage when the robot rams opponents.
Srimech: Invertable; cannot rest on sides due to skirts
Tactics: To get under unskirted opponents, slam them around and bring out the drills to damage their underbellies; to ram skirted opponents with the drills out and try to cause damage
Strengths: Good pushing power
Weaknesses: Drills may not penetrate very thick armour; high ground clearance at back
M.O.R.D2
Weight: 110kg
Shape: Box, with sides that slant outwards from the top and bottom edges to form triangles, like Tornados rear (hopefully this will lower the effectiveness of spinners)
Dimensions: 90 x 32 x 35
Speed: 20mph
Ground Clearance: 0 at front due to plow, 0 at sides and rear due to skirts, which are fixed to the points of the triangles and can work either way up, 4mm behind skirts
TC: 5cm
Armour: Body is 4mm Hardox; scoop is 4mm titanium; skirts are 3mm titanium
Movement: Camshafts like Drillzilla
Weapons: At the front is an electrically powered scoop which operates through 180 degrees, so it can work when the robot is inverted. Behind the scoop is a 20kg spinning drum with 8 titanium teeth on it, spinning at 2000rpm and hopefully able to flip robots as well as damage them. The drum comes into play if the scoop is lifted.
Srimech: Invertable; triangles at sides and rear prevent it resting there
Tactics: Shove opponents with the scoop; then lift the scoop and attack with the drum
Strengths: Fast; good traction; powerful drum
Weaknesses: Less manouverable than wheeled robots
SYNDOS (SLICE N DICE ON STEROIDS)
Weight: 96kg
Shape: Invertable box with rounded sides and rear
Dimensions: 60 x 60 x 45
Speed: 12mph
Ground Clearance: 4mm at front, 0 at sides and back due to skirts, 4mm behind skirts
TC: 0
Armour: 4mm Hardox
Wheels: 2, inside robot, with RC gyro for extra control
Weapon: 25kg 3000rpm titanium vertical spinning disc at front
Srimech: Invertable
Tactics: Mash with big-a** disc, and try to flip as well.
Strengths: Powerful weapon; low ground clearance
Weaknesses: No weapons on sides and rear; a bit on the slow side
Right! All spots filled, just need entries from Chris and Matty :)
My realie will be Hexadecimator, most UTD version.
ORKA MK4
Weight: 100 kilos
Body Shape: Behemoth
Speed: Some 15mph
TC: 0
GC: 8mm, 0mm at front.
Wheels; 6 inner
Armour; 7mm titanium
Power; 3x 12v batteries, powered by S28-400 Magmotors, at 24v.
Weapons; A Behemoth like bucket scoop, made from titanium 5mm thick, and quite capable of lifting 300 kilos. It has a claw like device, also pneumatic, to grab an oppodent, like the claw on Mantis. The scoop is pnumatically powered by CO2, and has about 45 odd flips.
Srimech: It has a pneumatic dorsal fin piston that self-rights the robot, ala Vlad The Impaler.
Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
Strengths; Weapon
Weaknessess: Hard to turn
DIE-CERATOPS RE-INVERTUS
Weight; 100 kilos
Body Shape: Wheely Big Cheese
Speed; 15mph
TC; 0
GC; 0mm at front, 10mm at sides and back.
Wheels; 4 inner, the back two sticking out only slightly,
Armour; 8mm titanium
Colour; Green, with Killer Carrot style wrinkles, mouth and eyes. One of the eyes has a plaster over it, the other is a black eye. A few bandages are painted on this time.
Weapons: A huge Wheely Big Cheese style pneumatic CO2 flipper, capable of flipping a tonne or so.
Srimech; As the name suggests, the robot runs inverted. Bars prevent side strandings, and the back is rounded, so stranding THAT way is outta the question. The flipper works upside down.
Inspiration; Ive always liked Dinosaurs. This is a pun of Triceratops. The Invertus part is pretty obvious.
Strengths; The ability to work upside down and still be able to use its weapon, now easier to control.
Weaknessess: Facing more agile vapourbots
CYCLONE FORCE 3
Weight; 100 kilos
Body Shape; Storm 2 without the wedge (at first, see set-ups for more detail)
Speed; 20mph
TC; 0
GC; Side is 0mm due to skirts. Otherwise, 10mm. See set-ups for front GC
Wheels; 6 inner
Armour; 11mm Titanium.
Power; LEM130s at 36 volts, ala Storm 2. 3x12v batteries.
Colour; A blue-ish grey tone all over.
Weapons; The robot has 3 set-ups...
SET UP 1...An electric lifter device, similar to Storm 2. In theory, it can lift 190 kilos. The front makes a wedge and results in a 0mm GC. However, the wedge is useless upside down.
SET-UP 2...Two large 30 centimetre long spikes, powered by their own pneumatic system and running off CO2. The front with this GC is 10mm.
SET-UP 3...A simple bucket scoop, like X-Terminator. The scoop is static, but can get underneath virtually zero ground clearance. Its front is 0mm.
Srimech; The robot runs inverted, the sides are protected by the skirts and back stranding is impossible.
Inspiration; The original Cyclone was named because it is the name of a storm and it sounds threatening. The force came later, after it became a pusher.
Strengths;Raw power
Weaknessess;Limited control.
LEPROSY INFECTION
Weight; 100 kilos
Body Shape; Tetanus Booster
Speed; 18mph
TC; 0
GC; 6mm
Wheels; 4 inner, top sticking out. Hinged mini-skirts hang from the side, and these protect the wheels from low lying discs.
Power; 3x 12v batteries, powered by S28-400 Magmotors. LEM130 motor for the drum.
Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this explained below. By the drum are two hindged wedge type devices, which drive oppodents onto the drum.
Weaknessess; Wheels may be vulnerable to axes
MEGA MASHER 2
Weight: 100 kilos
Body Shape: A Triangle shape, a bit like Inshredable (from Series 6). 0.85m in length and width, and 0.35m at its highest point. The sides are heavily angled, a bit like UFO in S7, only more so.
Speed: 15mph
TC: 0
GC; 0 at front, 6mm elsewhere.
Wheels; 6 inner, aranged in a 3-wheel-a-side formation. This means that four wheels are always on the ground at any one time.
Armour: A nice 3.25mm Hardox, all over.
Power: 3x 12v batteries, plus Bosch 750s at 36v.
Colour: Red and yellow.
Weapons; The front is a wedge, and the back has a nasty vertical titanium 35cm in diameter disc, powered by its own LEM130 motor and spinning at 2000 rpm. It can probably flip as well as damage.
Srimech: The robot can run inverted, with the sheer angling at the sides making stranding near impossible.
Strengths: Power, weaponary
Weaknessess: New and untested design.
AXE-O-LOTL
Weight: 100 kilos
Body Shape: Comengetorix
Speed: 20mph
TC: 0
GC: 6mm
Wheels: 4 inner
Armour: 3.25mm Hardox all around.
Power: Same stuff as Storm 2 and Cyclone Force uses.
Colour: Has interchangable panels. One set is pure black, the other pure white with pink tinges.
Weapons: A very nasty pneumatic axe, with the power of Dominator 2. The head is diamond tipped, and the whole weapon is VERY persistant. It can fire about 40 times in one fight.
Srimech: The axe rights the robot. The robots body is designed so it cant be side stranded.
Inspiration: My favourite amphibian, the axolotl.
Strengths: Powerful weaponary
Weaknessess: Obviously a limited CO2 supply.
And for the sake of having fun, which any Robot Combat tournament should be about...
SPRING-BOK!
Weight: 100 kilos
Body Shape: Firestorm.
Speed: 12mph
TC: 0.
GC: 0 at front, 7mm at sides.
Wheels: 2 inner.
Armour: 8mm titanium, covered in 2mm orange fur.
Power: 3x 12v batteries, powered by a couple of Magmotors (S28-400s).
Colour: Orange, thanks to the fur.
Weapons: A launch pad. Heres how it works...basically, the robots drive up the wedge, then the front panel, which is attached to four large car springs, fires outwards via hydraulics. A miniture piston device is attached to the panel to prevent it getting fired off, and also re-sets it. Should that fail, it does have a back-up plan (see notes).
Srimech: Two arms that extend around the side of the body, a bit like that of Philliper, only bottom hinged rather than top hinged, act as the Srimech.
Inspiration: Its named after an antelope.
Notes: This is the re-make of the former comedy yet highly sucessful robot Fluffitor, who won a previous Children In Need special. Has an in-built police siren which it activates if the going gets tough. The idea is that the oppodent will think hes about to be arrested then run off.
Strengths: Experience, unique weapon.
Weaknesses: Untested, Flammable, back-up plan probably wont work.
Would it possible Matty if I could just have a list of names for draw purposes? :)
Boxed In
Heimlich
Ha-Ka
PTT5
Roo
Hypo
BIACS-LE
259
all stats can be found at http://vapourbots.crystalnode.net/forum/viewforum.php?f=8&sid=5ef792b51c508979d3ac619967e9 c985http://vapourbots.crystalnode.net/fo...92b51c508979d3 ac619967e9c985
Thank you all, draw will be up soon!
