which?
which?
Which rammer? Theres several for you to choose from, boxy ones, pointy ones, wedgie ones :proud:
In all seriousness (and at the risk of looking stupid by being rational), Id advise you just get two drill motors or even wiper ones and get a rolling chassis of some sort together to confirm that you can actually build something before starting on the robot proper, itd save you quite a bit in parts youd buy and then realise you couldnt use.
Do a bit more research into these things as well, thread archives are there for a reason...if you do your research on things like motors and robot designs rather than just asking the most obvious of questions, you endear yourself to people more and they become a lot more willing to help you :)
thinking of using 2mm diamond plate as armour
What are you on about? Like Kody said, think about a simple design with as few moving parts as possible. The more complex your design the harder it will be to get it to work and the more there is to go wrong. People on here are always willing to help, just ask sensible questions.
no I mean which crushers
Venom, and another one is being built by (?) the Psycho Fling Team
There is also dragonclaw that tony built.
Ben and Ed: I think diamond plate means that patterned aliminum used for things like outside stairs
best crusher that i have come up against with 4 4 toon is without a doubt major damage, left my chasis totally twisted after Guildford this year..
lol Clive, MD doesnt quite make the FW weight limit. Dave got it, checker or tread plate. I just cut up 5 2500x2000 of 7.5mm last week.
.. checker plate is different to dimond plate;
check plate;
http://www1.istockphoto.com/file_thumbview_approve/4607365/2/istockphoto_4607365_checker_plate.jpghttp://www1.istockphoto.com/file_thu...kphoto_4607365 _checker_plate.jpg
Diamond;
http://diamondplatestore.com/library/DiamondPlate-Silver1.gifhttp://diamondplatestore.com/library...te-Silver1.gif
I think I meant checker-plate
Plus Dragonsclaw is being made into a lightweight
(Message edited by neontetra23 on August 30, 2008)
