The Killer Toad Tournament Special
Mad Dash
Weight: 100kg.
Body Shape: Box with a front scoop.
Color: Chartreuse Body, Pure Black Scoop.
Dimensions: 100 X 90 X 36
Drive: 2 X LEM-130€™s @ 36v powered by 4 X NiCad Batteries.
Top Speed: 20 mph.
Tyres: 4 X Vulkanized Tyres.
Armour: 5mm Hardox Monocque for the scoop and 5mm Grade 5 Titanium for the base.
Ground Clearence: Completely 0mm on the front and 6mm anywhere else.
Turning Circle: Zero, what does it look like?
Weapon 1: Static Scoop to deflect other spinners.
Weapon 2: In the middle of the scoop, there is a Tornado-esque drum thingy powered by S28-150, spinning at 3220RPM.
Srimech: Invertible, Side spikes prevent it from getting beached on its side.
Strengths: Can run both ways up, EXTREME Pushing Power, Deadly Drum, Can get under anything, Shock-Proofed.
Weaknesses: Armour other than front is not the best.
Who are you challenging to a fight Samuel?
Chris.
(Message edited by samuel3764 on August 07, 2008)
And does Chris accept your challenge to a grunge match?
Meh, might as well...but youll be facing the largest, toughest, most powerful robot Ive got...
MEGA MASHER 2
Weight: 100 kilos
Body Shape: Minion with skirts.
Speed: 12mph
TC: 0
GC; 0 at front, 1mm at sides due to skirts, 10mm underneath.
Wheels; 4 inner.
Armour: A nice 3.25mm Hardox
Power: 3x 12v batteries, plus Bosch 750s at 36v.
Colour: Red and yellow.
Weapons; The front is a wedge, and the back has a nasty vertical disc, powered by its own LEM130 motor and spinning at 2000 rpm. It can probably flip as well as damage. A side Minion style bar, pneumatic CO2 powered, comes out from the side.
Srimech: The aforementioned bar rights the robot, even though it can run inverted.
Strengths: Power, weaponary
Weaknessess: A little bulky, not as heavy as the body would suggest.
Grudge Match 1
Slammer vs The 6isc
Grudge Match 2:
Systematical Shockerlarity vs Achilles
GM3:
Spin Dash Unleashed vs. SOR X
GM4:
Tira IV & Fling vs. Trojan/Virus/Worm & Fairground Killride
GM5:
Supreme Glory Omega vs. Knyfe
GM6:
Mega Masher 2 vs. Mad Dash
Room for 1 more match I think
Alright - a rematch of the Fight Against The House Robots Revisited: Nitro-Gene 4.0 vs. Seung Mina IV.
I said wed fight again at some point Kody :proud:
Why? You won that one, why do you need vengeance. :proud:
At any rate, getting 2nd in that wasnt too bad for me so I wouldnt consider that a grudge anyway. What I WOULD, though, is...
Wedginator Devilution vs. All Scoop & No Stab Make Steve a Dull Boy
Rematch of the Fowler Fic War 1 Grand Semi-Final. What do you say, Steve? :proud:
