Cheera Alex for the realie list and I believe that is now 196.
May I still enter robots?
I see that Steve has registered Biohazard before I did, so Id like to go ahead and replace my Biohazard with a little robot called Aces and Eights.
You can Kevin :)
And OK Alex
what about my realies?
which real robots have been taken and how many robots can I enter?
Is reading just a few posts up such a grueling task?
I guess not.
Wolf
Mass-100kg
Weapons-front hinged flipper running at 175psi
Dimensions-95cm length/80cm width/40cm high
Shape-low wedge shape/sloped rear with skirts on the side
Wheels-Four inner wheels
Top Speed-22mph
Armour-6mm titanium all round
Motors-2x LEM130s at 36v
Power-4 x 48v NiCD 3600Mah Packs
Ground Clearance-0mm around the whole body.
Strenghs-Nippy around the arena, dependable armour, good weapon, can get under anything.
Weakness-Flipper cant get robots OOTA all the time (it can some times)
Enterprise
Dimensions-95cm length, 80cm width, 40cm height.
Weight-100kg
Shape-low wedge/sloped rear with Biohazard like side and rear skirts
Wheels-4 inner wheels
Speed: 19 mph
Weapon:A rear-hinged flipper. There is a strip on the bottom of the flipper, allowing the flipper to get under bots with skirts. The flipper is 1000psi. There is the option of removing the strip and putting a small titanium plate that extends the flipper out 15cm. It could be used against dangerous spinners. Spikes at the back to prevent the robot from flipping itself over.
Motors-2 LEM-COs running at 36v
Power-4 x 36v 3600mAh NiCD packs
Armour-7mm titanium all around
Ground Clearance-0mm front, 0mm around the sides/back with skirts.
Turning Circle-0m
Strenghts-Powerful flipper, nippy around the arena.
Weakness-Flirts with Matilda.
Firefly
Mass-100kg
Weapons-front hinged flipper running at 1000psi, with a back attachment so you can flip robots from the back. Need any pics, just ask.
Dimensions-90cm length/80cm width/35cm high
Top Speed-20mph
Armour-7mm titanium all round
Ground Clearance-1mm around the whole body.
Strenghs-Nippy around the arena, dependable armour, fast weapon, can get under anything.
Weakness-Flipper cant get robots OOTA all the time, but it can send a robot far.
I counted 10 new HWs from when I last entered [revamp for clusters may happen, espically for 4 Swords]
http://farr.proboards21.com/index.cgi?board=Hitmenhttp://farr.proboards21.com/index.cgi?board=Hitmen
Vlad 2
Deathstar [Hey, its cool]
Towering Inferno [Again, coolness]
Mechavore
Omega 13
Hexadecimator
