Sumo: Hurricane.
Annihilator - Hurricane
Tag - Yes Matty, I will use The Wedge
House Robot Rebellion -
Wedgie 3d.
Sumo: Hurricane.
Wedgie 3d.
Nice one Dave! Do you mind it being TaoLin or would you rather it was someone else?
Sumo: TB87
Annihilator: If in time, Montys Pass
The other events, probably full by now, arent they? If they are, Ill enter the above events.
SUMO
SD IV
El Persistance
Windiest Killer
Hypertension
RPS XPN1
Ramthrax
Hurricane
TB87
ANNIHILATOR
Whirliging 4.0
Ankle Biter
Ripper Roo
Angle of the Abyss
Hurricane
Montys Pass
TTT
Ankle Biter and Disco Dancer
Taolin 2 and The Wedge
HRR
Wedge Devolution
Deep Impact
TOC2
Slaying Mantis e
Sorry Dave, you were too late
Steven, can you confirm which robot you will be using in the TTT?
Tom, you can still enter the TTT.
Ok, for TTT, Impact Weapon & Crusha.
TAG TEAM ENTRIES:
Seeing as Dave and Haka are allowed to pair up, I propose that Alex and I band together with Chameleon and Angel of the Abyss :)
Thank you every one. I have thrown in some real robots to make up for the number
HEAT 1
Ankle Biter vs RPS XPN1 vs Angel of the Abyss
Marabunta vs Wedge Devolution vs NJACC 2.2
HEAT 2
Hurricane vs Storm 2 vs Return of Roadblock
Ripper Roo vs Slaying Mantis E vs Crusha
HEAT 3
Chameleon vs ALVD vs Big Nipper
El Persistance vs Tengu 6 vs Montys Pass
HEAT 4
Hole in the Armour vs Chalkie vs Barbaric Response
Hypertension MK2 vs Indisctructable vs Eagle
HEAT 5
WAFT(sw) vs Jack the Slammer vs Ramthrax
Clawdius Decimus Murderous vs Bulldog Breed vs Achillies
HEAT 6
TaoLin 3 vs Killotine EVO vs The Wedge
Windiest Killer vs SD IV vs Ripper
HEAT 7
Slammer 4 vs Jamster vs Impact Weapon
Tornado vs Whirliging 4.0 vs T.O.C. 2
HEAT 8
Disco Dancer vs Destruction vs Wedgie 3d
Phoenix from the Flame 2 vs Deep Impact vs TB87
SUMO (against Jakamoko 2)
SD IV
CDM
El Persistance
Windiest Killer
Hypertension
RPS XPN1
Ramthrax
Hurricane
TB87
ANNIHILATOR
Whirliging 4.0 vs Ankle Biter vs Ripper Roo vs Angel of the Abyss vs Hurricane vs Montys Pass
TAG TEAM TERROR
Ankle Biter and Disco Dancer vs TaoLin 2 and The Wedge
Impact Weapon and Crusha vs Chameleon and Angel of the Abyss
HOUSE ROBOT REBELLION
Wedge Devolution, Deep Impact, T.O.C 2 and Slaying Mantis E vs Cholera, Irritator, Smudge Revamped and Fluffitor 3n a lil bit more
SPECIAL SURPRISE
Matilda vs Cassius Chrome vs Growler vs Dead Metal
Shunt vs Sir Killalot vs Sgt Bash vs Mr Psycho
Tactics and Predictions please.
Alex, wanna gang up, its a 10kg disc, which is well over-estimated against a flipper, that according to his measurements, would actually flip 824kg 39cm into the air, which is lower than the height of the fence. Between us, we should be able to cut, spin, scoop and axe it.
As for the other fight, Marabunta to go out.
Heat 2
Return of Road Block to go out.
Ill be going for Slaying Mantis, Tom, wanna gang up? The crusher is vulnerable from the rear, and the chances of them getting close enough to shred us with a spin up speed of 6.5 seconds is unlikely. If Crusha can hold them, then well bash them into very very big submission
Heat 3
Chameleon and El Persistance out
Heat 4
Barbaric response out.
Well go after Indistructable, shunting it aorund, and using our flipper to fire it 3 feet up and under
Heat 5
JTS to go out
BB out
Heat 6
Dave, want to gang up on Killy? It shouldnt withstand the drum for long and the axe wont do much
Steve, wanna team up? Get rid of the Ripper so my wheels survive to fight Dave again! (Hopefully!)
Heat 7
Jamster out
Steve, Tornado? You should be able to hit it, whilst we shove, flip and crush it around the arena.
Heat 8
Destruction Out
Deep Impact Out
Sumo
Windiest Killer will grab Jakomoko with the pincers, pushing him of the edge.
Hypertension will flip him out!
RPS XPN1 will try and get Jakomoko embedded on the screws, beofre shunting him of the edge with help from the axe.
Anhihlator
Well go after Montys Pass, the flipper being innefective, and us trying to rip and bend the flipper
TTT
Dave, can I suggest you take DD and Ill take on Ankle Biter seeing as the disc wont work and the flipper will be innefectual against an axlebot
HRR
Well take Fluffitor on, flipping it over and thowing it OOTA
SS
Growler to beat Psycho and Bash on a judges decision
Looks like a good draw, I just hope you do it justice! :) Good luck and I hope that this is all as well organised as it is at the moment :) And Matt M, dont even bother ruining this thread as well.
Heat 1
Go for RPS XPN1 and either disc it of flip it. Avoid AOTA at all costs!
Heat 2
(Fancy teaming up Dave against the real bot?)
Heat 3
El Persistance will go for Montys Pass and shove him around into the wall and into Tengus weaponry (want to team up Alex?)
Heat 5
Go for whoever is nearest and thrash them with the axe.
Heat 8
Disco Dancer vs. Destruction vs Wedgie 3rd
Disco Dancer will take advantage of Destructions weak armour and chew him up with the disc. Hopefully avoid Wedgie 3rd (any chance of teaming up Dave?)
Deep Impact will go for Phoenix from the Flame and trash it as much as possible
SUMO
El Persistance vs Jakamoko 2
El Persistance should push it around all day!
ANNIHILATOR
Ankle Biter will team up with Ripper Roo and go for Montys Pass.
TAG TEAM TERROR
Disco Dancer will go for The Wedge and trash it up as much as possible and Ankle Biter will go for TaoLin 2 (flip it as high in the air as I can!)
Deep Impact will go for Cholera and disc it around a bit.
HEAT A
Marabunta vs WEDGE DEVOLUTION vs NJACC 2.2
Here, Ill just use the normal flipper blade and get around the sides of Marabunta. One flip and the weapons are useless. One more flip and its out the ring for you :proud: Same goes for NJACC if it gets in the way :wink:
HEAT WINNER: The Angel to slice RPS in the Final
Other tactics when the Heats get nearer.
