Pussycat Tribute Tournament 3...continued!
HEAT P - THE STORY SO FAR:
ROUND 1
SPUNOUT 3.0 (2) AND THE TEAM THAT WASN€™T THERE won their battle after Charybdis was pitted by two members of the Team...after KOing a 3rd member
BIGGER BROTHER (18) AND FALCHION won their battle after Hammerer was flipped out of the arena by the No.18 seed
ROUND 2
SPUNOUT 3.0 (2) knocked out one of Falchion€™s drive motors
THE TEAM THAT WASN€™T THERE pitted Bigger Brother (18) using three of its five segments
LATER ON:
HEAT P
ROUND 3
HEAT FINAL
SPUNOUT 3.0 (2) Vs THE TEAM THAT WASN€™T THERE
Thoughts? Tactics? Did you enjoy Round 2?
Thank you! :)
Great last Round 2 there Steve-o! :proud: I canna wait for the semis!
Predictionaries:
I think SpunOut will win, mainly because of the discs power. It should sent the little wedges flying all over the arena.
And off we go again! :)
Our final Heat is about to draw to a close, but before Hector and Tom scrap it out once more in the PTT€™s history, let€™s use our last time travel trip :proud: to take a look back at their previous meeting...the Grand Final of PTT2! :proud:
PUSSYCAT TRIBUTE TOURNAMENT 2
GRAND FINAL
SPUNOUT (Tom Roper)!!!!!!!!!!
(has beaten Disc-Turbed, Forthgill, Bigger Brother, Slam Job, The Matador(10) and Pure Evil)
Vs
THE BUSINESS ENDS (Hector Gilbert)!!!!!!!!!!
(has beaten C2, Son of Ripper 2, Hypno Disc(2), Wheely Big Cheese(14), Biohazard and Razer(11))
House Robots- Sgt. Bash, Mr. Psycho, Sir Killalot, Growler
Roboteers Stand By......
3...2...1...
ACTIVATE!!!!!!!!!!
Right away, The Business Ends and SpunOut charge towards each other!! But as the two approach the arena centre, TBE veers off to one side and reverses into SpunOuts rear!! The axe fires and the arm attached to the rear raises!!! But SpunOut is merely lifted off the ground and lands back on its 6 wheels!!! Now the pusher slams into TBEs rear, carefully avoiding the arm, and shunts the hammerbot into the arena wall!!! TBE tries to get away, but SpunOut starts to ram into it!!! As it backs off, TBE quickly darts away and SpunOut just about ends up crashing into the wall!!! After a very quick recovery, SpunOut charges disc-first towards TBE!!! But as it approaches, TBE slams into reverse and the two crash into each other in the arena centre!!! As the two collide, SpunOuts disc meets TBEs arm, but the lifter holds up with little more than a scratch, while the disc seems to have been temporarily stopped!!! The rear arm of TBE manages to just get under SpunOuts disc and, with one fire of the axe and a lot of reversing, successfully flips SpunOut over!!! Being invertible, SpunOut takes this with little bother!! But as it tries another shove, TBE drives under the rear of the machine and with some more reversing, fires the axe and sends the robot over again!!! Now facing TBE disc-first, SpunOut charges with all its might, slams into TBEs front ram and pushes it so hard that the section of the arena wall the two hit almost comes loose!!!! Now SpunOut is reverting to the Tornado tactic...ram it, ram it, RAM IT!!! But after taking a few nasty shoves, TBE successfully manages to turn around, allowing a charging SpunOut to meet the spinner head-on!!! The disc hits the ram and, although the spike is now rather bent, the disc has stopped again!!! TBE seizes its chance and manages to drive under SpunOuts currently static disc!!! The now legendary axe activates and SpunOut, who seems to be pinning TBE to the arena wall, is suffering blow after blow after blow!!!! Despite having stronger top and bottom amour, the hammer is making a fair few dents!!! Blow after blow rains down on SpunOut, who is still keeping TBE against the wall!! Refbot intervenes by approaching the two and, while carefully avoiding TBEs hammer, pries the robots apart!! The two separate and TBE zooms to the arena centre with SpunOut in hot pursuit...the disc and spike had become stuck together!!!! As SpunOut hits TBEs side and starts to shove it to the arena wall again, TBE quickly pulls forwards and darts away as SpunOut very nearly hits the wall again!!! Now quickly getting into reverse, TBE drives under SpunOuts exposed rear and nearly flips it over again!!! As the pusher tries to get some room and shunt TBE away, the hammerbot drives under SpunOuts rear and lifts it again!!! The pusher is almost turned over...and very nearly propped against the wall!!! With SpunOut pinned sideways against the barrier, TBE reverses into SpunOuts rear and manages to get underneath, while also hitting a wheel!!! The axe fires, the rear arm goes up, TBE pushes with all its might, the sideways SpunOut goes up...and the pusher is now beached on its side against the wall!!!!! The Business Ends has done it!!!!! Its plan worked!!!!! As the mighty hammerer backs off and watches the pusher try desperately to get off the wall, Refbot approaches and begins to count out the marvellous, destructive, but finally conquered SpunOut!!!!!
1...2...3...4...5...6...7...8...9...10!!!!!!
As Mr. P approaches the beached SpunOut, TBE backs into the arena centre and starts to bash the floor with utter joy!!!!! Hectors done it!!! Hes won the 2nd Pussycat Tribute Tournament!!!!! Mr. P meets the abandoned pusher and picks it up with his hideous claw!!! As Bash kindly releases the Pit for him, and while TBE continues to bash the floor into sawdust, Mr. P raises SpunOut as high as possible, turns to the Pit and trundles over!!! Once at the edge, Mr. P releases its grip and all watch as the great SpunOut tumbles into oblivion!!!!! One €œBANG!€ later and the smoke begins to rise from the Pit!!!!! We have a new PTT champion...and his name is THE BUSINESS ENDS!!!!!
CEASE!!!!!
WINNER OF THE PUSSYCAT TRIBUTE TOURNAMENT SERIES 2:
THE BUSINESS ENDS!!!!!!!!!!
FINAL RESULTS:
1st- THE BUSINESS ENDS (Hector Gilbert)
2nd- SPUNOUT (Tom Roper)
3rd- PURE EVIL (Daniel Stickler)
4th- RAZER (11) (Martyn Forsyth)
Of all the fights I€™ve written, I think this is one of my personal favourites. :)
Now, it€™s back to the future to see our last Heat Final (and to get rid of this machine - the CIA have been tracking me for a while, you know :proud:)
It€™s been a long while...a long, long, loooooooong while :proud:...but we€™re finally about to fill the last place in our Series Semi-Finals! Once again, Gilbert and Roper meet in another Clash of the Titans, but who will triumph this time - the 5-way newbie clusterbot or the ram-happy 2nd seed? Our Final Heat Final will provide us with an answer... :)
HEAT P
ROUND 3
HEAT FINAL
House Robots- Matilda and Growler
3...2...1...
ACTIVATE!!!!!!!!!!
SpunOut 3.0 gets off to the quicker start with its serious acceleration, but already, the Team That Wasn€™t There has begun to start separating!! With the disc revved up, the No.2 seed darts forwards and rams right into the middle of the line of Lightweights!! Although this attack has put a great slice into one of the members, this charge has also managed to smash the mini rammers free from each other!! Now all five are beginning to roam the arena!! Disc back up to speed, SpunOut takes a dart towards an advancing segment, but as it does, another member shoots across the ring and under the No.2 seed€™s side before it can swing round and retaliate!! As the powerful cluster piece merrily pushes Tom€™s machine across the arena, another Team member darts over and into the Pit Release Button!! However, as the siren blares and SpunOut is smacked into the arena wall, the blow knocks the No.2 seed off the €œsnagging€ ridge of the cluster piece€™s wedge!! Back in action, Tom quickly sends SpunOut dashing off the front wedge and back into the arena!! As two more segments come on the attack (one of which Tom crippled earlier on :proud:), the No.2 seed tries a new tactic - as the 2 Lightweights get closer, the PTT2 runner-up uses its six wheels to swing right round and strike both cluster pieces with the dreaded flywheel!! While one member is scarred, but safe, the already wounded segment looks worse for wear...due to the fact that only one side seems to be working!!! SpunOut revs up the disc again and dodges another joint assault, as Refbot starts to count out the half-immobile Lightweight!!!
1 down, 4 to go!!! Disc back up to speed, the No.2 seed just dodges a second twin onslaught and twirls round for another go at that unpleasant pair!! But just as Tom€™s machine prepares to attack the two advancing Lightweights, another Team member darts over and slip underneath the No.2 seed€™s side!!! When the fourth remaining segment trundles over as well, SpunOut tries to shoot free...which is tricky when the €œsnagging€ ridge is locked onto the outer cage protecting the wheels!!! Delighted with his little manoeuvre, the triumphant cluster piece makes its way over to the Pit, the other Team members clearing the way!! SpunOut€™s disc spins wildly - but there€™s nothing to attack!!! The wheels twirl desperately - but it can€™t release itself from the ridge!!! Tom tries to wriggle his machine loose - but it€™s too late!!! The little Lightweight has reached the Pit edge, abruptly halted and shaken the No.2 seed into the eternal darkness...
CEASE!!!!!
SpunOut 3.0 couldn€™t survive the big push! :proud: The No.2 seed falls victim to the quintuplets€™ ruthless teamwork and misses out on the title a second time!
THE TEAM THAT WASN€™T THERE GOES THROUGH TO THE SERIES SEMI-FINALS!!!
Congratulations to Hector Gilbert!!! :proud:
And with that, we finally have our 16 PTT3 Semi-Finalists!!! :proud:
1) No. 1 seed and reigning PTT champion THE BUSINESS ENDS (Hector Gilbert has beaten Dantomkia, AWOL and Stratus 2)
2) No. 3 seed PLATINUM PURE EVIL (Daniel Stickler has beaten Big Fred, Pyro II and The Robot That Wasn€™t There)
3) Newcomer DISCTRUCTION EVO (Aaron Knight has beaten Turbo Falcon, 21st seed Double Killa and 5th seed Voltronic)
4) Newcomer CRANKSHAFTED (Tom Roper has beaten Storm 2, 23rd seed Thermidor 2 and 7th seed Biohazard)
5) No. 9 seed and PTT1 champion BETA (Karl Fletcher has beaten Dervish Mach 2, Junkyard Maw and Electro)
6) No. 27 seed DISHONOURABLE DISCHARGE (Hector Gilbert has beaten Clustram, Suicidal Tendencies and 11th seed Chaos 2)
7) Newcomer ULTRAVERTER (Tom Roper has beaten 13th seed 259, 29th seed Slammer 2 and Battle Raptor)
8) PTT2 veteran SPINVERTER 3 (Tom Roper has beaten 31st seed Cassius 2, Snakebite Evolution and 15th seed Hypno Disc)
9) Newcomer MASS DISCTRUCTION ULTIMATE (Aaron Knight has beaten Vlad the Impaler, 32nd seed Firestorm 4 and 16th seed Behemoth)
10) No. 30 seed TORNADO (Karl Fletcher has beaten Axe-L-Bot X 2, Achilles and Flea 2.0)
11) No. 28 seed TENGU 4 (Alex Holt has beaten Kat 3, Blade Runner and 12th seed Wheely Big Cheese)
12) Newcomer THE CRASHING BORE (Frank Goacher has beaten 2 Bell & Back, Armageddon Mk 2 and 26th seed Flip-O-2)
13) No. 8 seed SON OF RIPPER 0.2 (Andy Jackson has beaten Robocake 2: The Upside-Down Cake, That Good R&D and Kan Opener)
14) PTT2 veteran HEIR TO BLACK PANTHER (Alex Holt has beaten Baird, 6th seed The Matador and Bad Cluster)
15) No. 4 seed RAZER (Martyn Forsyth has beaten BackSpin 2.0, Dragonfly and Supreme Glory Beta)
16) Newcomers THE TEAM THAT WASN€™T THERE (Hector Gilbert has beaten Charybdis, 18th seed Bigger Brother and 2nd seed SpunOut 3.0)
Although I am still to do the draws for Round 4 yet, I can tell you into which Semi our top 16 machines have been placed:
SEMI-FINAL 1
The Business Ends (1)
Disctruction: EVO
Beta (9)
UltraVerter
The Team That Wasn€™t There
Heir To Black Panther
The Crashing Bore
Tornado (30)
SEMI-FINAL 2
Platinum Pure Evil (3)
CrankShafted
Dishonourable Discharge (27)
SpinVerter 3
Razer (4)
Son of Ripper 0.2 (8)
Tengu 4 (28)
Mass Disctruction Ultimate
Draw up ASAP :)
We€™re now only 16 fights away from the PTT drawing to a close once again. With all our qualifier Heats now swept under the rug, it€™s time to face the FRA Firing Squad and ask...how wiz that, Jimmy? :proud: (roughly translated as €œHow are you finding the tournament€™s writing up until now?€Â) Pros, cons, the good times, the bad times, the top fights, the plop fights :proud: - ANY views on the tourney thus far will be more than welcome! :)
Thank you! :)
Fantastic stuff so far Steve-o :proud: I really cant ait for the semis! :proud::proud::proud:
Keep up the good work, and show us all why you won that best tourney award:)
Steve, this is a fantastic tourney, and you know it! :proud:
Robots I do not want to fight:
CrankShafted
MDU
Tengu V
SpinVerter 3
Son Of Ripper
Robot I want to destroy:
Razer (rematch from PTT2 :proud:)
Youre a wonderful audience, you really are! :)
Anyway, in amoungst Chemistry revision, I bring you the long-awaited PTT3 Semi-Final draws!
SEMI-FINAL 1
ROUND 1
Tornado (30) Vs UltraVerter
Beta (9) Vs The Crashing Bore
Disctruction EVO Vs The Business Ends (1)
Heir to Black Panther Vs The Team That Wasnt There
SEMI-FINAL 2
ROUND 1
Razer (4) Vs SpinVerter 3
CrankShafted Vs Mass Disctruction Ultimate
Son of Ripper 0.2 (8) Vs Tengu 4 (28)
Platinum Pure Evil (3) Vs Dishonourable Discharge (27)
The fights may not be posted for a while, but at least youll have plenty of time to add comments and tactics.
Thank you:)
OMG! *Grabs front row seat and hard hat :proud:*
