No it's a different one. I got the lower snail cams machined out last night so more pics to follow!
Who did the machining? The pics don't match your workshop.
lol proves how much machining u did when u were there :P
Kane and Ant machined the bulkheads for me as they're just a tad too big for my small mill. All the rest and all te pics are done by me at our workshop. Gears on the rotary table in the Bridgeport and the rest on the CNC and manual lathe.
Thanks! Do appreciate the help, I'm definitely no engineer so it's a lot to figure out otherwise haha!
It definitely sounds like those are the ideal for bulkheads then, best of both worlds! Going to have a look at getting some of that in then and machined into some decent bulkheads for HardWired when I can. Definitely a lot better than the 3mm aluminium I'm using at the minute, I'll say that much!
Really like this build, looks great!
Can you explain how the cam system works? Looks really interesting and im guessing its something to do with saving switching the motor back and forth?
I spent abit of time yesterday machining out the lower cams. I think they came out quite nicely.
Attachment 4151
Attachment 4152
Its taken a reasonable amount of manual machining aswell, and the modification of a cutter to finish them off. When the cylindrical grinder doesn't work - gaffa tape an angle grinder to the lathe :)
Attachment 4153
Grinders and gaffa tape, my kind of engineering!
Looking great man, how you're going to build this in time I have no idea but I wish you luck!
Dave, I machined once... with you... remember? All trying to put a hole in the centre of that steering column.
I've been doing a little more work on my robot and managed to get it working in time for filming on Thursday.
The only material I could get for the axe handle itself was a 3m long, 71mm x 44mm price of 7075 aluminium. It added a fair amount of time having to mill it down to the 40mmx30mm size I needed.
Attachment 4161
I spent a number of hours lightening the axe and machining it to fit nicely :)
Attachment 4162
Most the components are machined ready for assembly.
Attachment 4164
And a picture of the weapon mech mostly assembled.
Attachment 4163
I had to make a very bodged base, drive and armour for it intime for filming, so excuse the bad looks!
Attachment 4165
I've got a video I posted on Facebook that I will try posting on here of the testing. I ran it on 5S lipos and only 1kg on the axe head and I'm quite happy with the results :)
