Well Joey, he didnt have to be go God-Damn-In-Your-Face about it. If hed politely noted me, it would have been fine.
Ill think about the armourment. I just dont wish for it to lose all of its toughness.
Hows this, Its a SHW
Shape: Anarachnophobic (S3) with spikes on the side to stop strandings
Colour: Brown and white patches
Speed: 13MPH
Weight: 175KG
Armour: 4MM Hardox
Drive: 2 C40-300 Magmotors @ 48V
Power: 6 NiCad Batttlepacks @ 48V
Locomotion: Hardox tracks with an Asmaprene/Urethane/Vulkalon coating
Ground Clearance: 0 at front, 4MM at sides and rear
Turning Circle: 0
Weaponry: 1) A lifting arm at the front of the robot hinged in the center of the robot, it can be either be powered by a pneumatic ram (120X180), a linear actuator or a hydraulic ram, it can either have 2 spikes or a semi-circular spatula at the bottom of the arm
2) At the rear of the robot there is a 20KG spinning drum powered by a B42-500 Magmotor and spinning at 7000RPM dealing about 110KJ with 32 curved teeth designed to rip and
flip
Srimech: The arm
Another SHW
Overall Weight: 150KG
Part 1: Komodo
Shape: A cylinder on its side
Colour: Dusty brown/Khaki
Speed: 12MPH
Weight: 80 KG
Armour: 5MM Titanium
Drive: 2 LEM170s @ 36V
Power: 4 Nicad Battlepacks @ 36V
Locomotion: 6 Solid domed Aliminium wheels with a Urethane Coating
Ground Clearance: 0 at front, 5MM everywhere else
Turning circle: 0
Weaponry: 1) a set of electric lifting forks
2) an electric clamping arm
the whole system works like complete controls weaponry
Srimech: The arm
Part 2
Shape: Judge Shred 3 (S7)
Colour: Light Khaki
Speed: 15MPH
Weight: 70KG
Armour: 4MM Titanium
Drive: 2 LEM 130s @ 48V
Power: 5 NiCad Battlepacks @ 48V
Locomotion: 2 small vulkalon coated wheels
Ground Clearance: 0 at front, 2MM at sides and rear
Turning circle: 0
Weapons: a flipping arm powered by 2 50X70 rams, powered by a 3KG Co2 tanks
Srimech: Jelly babies, I mean come on its obviously the flipper
I believe the traditional SHW weight limit is 154 kilos (it was in Battlebots anyway), throwing Robo-Rat over the limit.
Anyway...
MEGA MASHER 2
Weight: 100 kilos
Body Shape: A Triangle shape, a bit like Inshredable (from Series 6). 1.5m in length, 1m in width and 0.5m at its highest point. There are minature ploughs at the rear where the blade is, to guide robots into it.
Speed: 15mph
TC: 0
GC; 0 at front and back, 6mm at sides
Wheels; 6 inner, aranged in a 3-wheel-a-side formation. This means that four wheels are always on the ground at any one time.
Armour: The front is 2mm Hardox, the back and sides are 5mm Titanium and the base is 2mm Polycarbonate
Power: 3x 12v batteries, plus Bosch 750s at 36v.
Colour: Red and yellow.
Weapons; The front is a wedge, and the back has a nasty vertical titanium 45cm in diameter disc, powered by its own LEM130 motor and spinning at 2000 rpm. It can probably flip as well as damage.
Srimech: The robot can run inverted, with the sheer angling at the sides making stranding near impossible.
Strengths: Power, weaponary
Weaknessess: A little bulky.
The big problem now is the thickness of the armoury and theres STILL the issue of the teeth on the disc.
(Message edited by Dinowarrior on September 14, 2008)
I like your sense of humor Ben :)
I think for a SHW those stats are viable. I think Bearded might be a little overweight due to the batteries, but aside from that, cool :)
I think Chris the only armour problem is because of the sheer size of the robot. 150cm x 100cm x 50cm is unnessearily large, I would go more along the lines of 85cm x 85cm x 20cm, which would probably allow the 3.2mm hardox armouring and you would still fit it all in :)
But then remember to change the diameter of the disc... :)
So, if I said the disc was 15cm in diameter, would that be OK?
I guess the only reason I had Mega Masher so big in the first place was to see how a heavyweight would look in a superheavyweight body.
MEGA MASHER 2
Weight: 100 kilos
Body Shape: A Triangle shape, a bit like Inshredable (from Series 6). 0.85m in length and width, and 0.2m at its highest point. There are minature ploughs at the rear where the blade is, to guide robots into it.
Speed: 15mph
TC: 0
Armour: A nice 3.25mm Hardox, all over.
Weapons; The front is a wedge, and the back has a nasty vertical titanium 15cm in diameter disc, powered by its own LEM130 motor and spinning at 2000 rpm. It can probably flip as well as damage.
Weaknessess: New and untested design.
I think 15cm is OK, if a little small. You could probably double or even triple it
All very well, but a 30/45cm disc on a 20cm high body...wouldnt that prevent it from being invertible?
Oh yes, yuor right, sorry
