Velociraptors Fanfic Tournament - Series 6!
HEAT K
1) Annoying Box Rush (12) VS Firestorm 5 VS Flea 2.0 VS Mr Nasty
Ill pick Aaron to slice open Mr Nasty and Nick to flip n dump the Stormer
2) Disconstructor VS El Persistance VS ForcePower Turbo VS THE RAVEN
If Andy cares for a team-up, I suggest he tackles Mr Robinsons rammer, while I grapple Disconstructors angled disc and take it on a tour of the Warzone Hazards :proud:
On form as always, Richie :proud:
Uh... Did we all have to pick a real robot in this tournie? If so was Firestorm mine?:lame:
Yes and yes, Frank! And thanks for the nice comments, AJ and Steven!
Why would ANYONE want to write such horrid comments about you? Youre a great writer AND a fair judge.
Thanks. I get confused sometimes:proud: ...This tells you all why i never enter real robots if I dont have to:lame:
Firestorm tactics: First go after Mr. Nasty. I can get under him from anywhere, and the spike shouldnt do anything to me thanks to Firestorms nice low shape. Ill just drive him to the arena wall and leave him beached there. Either that or flip him into the arena disc until hes no more.
After that... Dont think I can do much to Flea, so Ill flip ABR around. Firestorms nippy and manoeverable so I should be able to toss it around a bit, unless Nick fancies teaming up and pitting Flea?:proud:
Ram into the sides of The Raven/Force Power/ El Persistance to cause pretty sparks and to rip away any skirts/side lumps/bolts to cause damage.
If I knew the stats for Flea, perhaps I wouldnt be swayed as easily. Excuse me whilst I render the ablative armor for the fight. :)
Its the old old flea with the hydraulic powered spinning bar. Nothing too fearsome, since most of the weight went into the hydraulic drive system and jumping system. Maybe its time we saw a return of the flea...
Oh, its OK, Aaron. Leave it as it is. :wink:
Do you want the stats for Flea then, Nick?
Flea 2.0
Motivation: Wheels
Weight: 99.31kg
Height: 290mm
Length: 800mm
Width: 600mm
Speed: 0-25MPH
Clearance: 3mm
Weapon: Flea has a new type of weapon that hasnt been used in Robotic Combat. Flea has two 100mm pneumatic rams powered by pneumatics at 145psi. These rams make Flea jump 5ft into the air due to the 795kg of force from the rams. This can be used to evade flippers, flywheels and House robots. This can be put together with good driving to make a crash tackle on an opponent. The pneumatics is powered by a compressor that takes the exhaust via a catalytic converter from the 160cc Chainsaw motor and pumps it into a 1kg CO2 canister. This gives Flea unlimited amounts of pneumatics.
Flea now has a 10kg spinning bar powered by a hydraulic motor at 4000rpm.
Drive: 160cc Chainsaw (6hp, Electric start) powering a Hydraulic pump which then feeds it to the 4 drive motors. To speed control, the drive pressure dumps back to the reservoir is used with stepper valves.
Armour: Flea has a 25mm hard compound rubber that surround the whole shape of the robot. On the top there is 4mm Hardox (Terrorhurtz was unable to put more than a dint in 4mm Hardox).
Batteries: 20 5000mah NiCad cells put together to form 12v 10A for the electric start)
Notes: Flea is Invertible.
