looking good AJ
looking good AJ
Looking awesome AJ :) Looks very professional! Keep up the good work mate.
It is looking rather cool.
Also off topic but gonna say it - was looking at peoples profiles - Kenny your heavy weight is looking cool dude! And Aaron, that picture of your nicads like that scares me. LOL. Just waiting for someone to touch the wires together :proud:
Mr Stu
Lol, that was a long time ago, I dont build shrink wrap packs any more, dont like how weak they are, check out my profile now with one of my intercooled poly packs. I can now throw my battery packs at the brick walls on my house with no problems :proud:
New carrot feather is a 4 motor drive too... just welded the gearbox cages onto the chassis.. see profile..
Is that the planetary ring gear youve welded to the chassis????
yep
planetary gear cages welded, drive shaft bushed through 50x25 2mm ERW chassis, no more of that floppy motor mounting business with jubilee clips..
cant remember if i posted this before or not but hey ill do it anyway lol
Drive: 2x 18v dewalts with the complete team delta setup at 24v, 2x 3 x 1.5 colsons and home made bearing blocks
Weapon: as if it needs one :p
Battery: 24v CP2400scr nicad packs
Speed controller: victor 885
Armor: 6mm mild steel angled all over, base lid and wedge are 3mm, the inside pieces are all 4.5mm stainless as are the wedge mounts.
Status: just about ready
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02428.jpghttp://img.photobucket.com/albums/v3...s/DSC02428.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02437.jpghttp://img.photobucket.com/albums/v3...s/DSC02437.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02439.jpghttp://img.photobucket.com/albums/v3...s/DSC02439.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02460.jpghttp://img.photobucket.com/albums/v3...s/DSC02460.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/DSC02462.jpghttp://img.photobucket.com/albums/v3...s/DSC02462.jpg
Drive: 2x 9.6v drills at 12v with dual 95mm wheels
Weapon: 115kg crusher
Batteries: 12v cp2400scr pack
Speed controllers: umm basically just some lego IR controllers that fire off relays... its an interesting setup ill tell you that :p
Armour: 12mm MDF held together with 3mm ali L bracket and m6 bolts. the crusher is all 4.5mm stainless.
Status: just needs final wiring and drives mounted.
http://img.photobucket.com/albums/v357/Cobrarobotics/Woodzilla/DSC02262.jpghttp://img.photobucket.com/albums/v3...a/DSC02262.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/Woodzilla/DSC02421.jpghttp://img.photobucket.com/albums/v3...a/DSC02421.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/Woodzilla/DSC02422.jpghttp://img.photobucket.com/albums/v3...a/DSC02422.jpg
http://glen.botclips.net/Woodzilla test%202.wmvhttp://glen.botclips.net/Woodzilla test%202.wmv
Drive: 18v drills at 24v, 95mm custom polyurethane wheels. these gearboxes are hand modified by a good friend to have bigger pins and theres 6 on the output and supported on both sides, BULLET PROOF.
Weapon: 260mm saw blade. 850g in weight driven staight off a giant fan motor that has a spinning plate. ~ 4000rpm
Batteries: 24v 3000mah nimh pack
Speed controller: IBC
armour: 10mm 5083 ali everywhere 12mm wall thickness pipes on the sides
notes: came second at our last event, woohoo
http://img.photobucket.com/albums/v357/Cobrarobotics/Kang/DSC02471.jpghttp://img.photobucket.com/albums/v3...g/DSC02471.jpg
http://img.photobucket.com/albums/v357/Cobrarobotics/Kang/DSC02010.jpghttp://img.photobucket.com/albums/v3...g/DSC02010.jpg
http://glen.botclips.net/Kang%20vs%20BoB.wmvhttp://glen.botclips.net/Kang%20vs%20BoB.wmv
http://glen.botclips.net/Plan%20F%20vs%20Kang%20vs%20Retread.wmvhttp://glen.botclips.net/Plan%20F%20...%20Retread.wmv
/end
(Message edited by Glen on December 08, 2005)
Just finished uping the power on Kishar from 12v to 24v for the Disc. Small vid on http://www.teamdragon.org.ukwww.teamdragon.org.uk bottom of Kishar page
Hmm. Very Nice Tony.
That reminds me why im in no hurry to get my feather finished any time soon!!
